I have a frigidaire front load washer it stop running water I replace the pump it spins it drains now it only runs water in for 3 seconds why
  • 3 Answers
Remove the lines and check for plugs. run water through and see if when removed it flows properly.
Posted on May 15, 2014
catriver
  • 878 Answers
SOURCE: drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Posted on Nov 05, 2006
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
  • 56 Answers
SOURCE: GE WBVH6240 Front load washer. Pump running while empty
you would need to go into the fault codes and read them. the tech sheet should be under the lid or in the kick panel
Posted on Feb 07, 2010
techbuster
  • 5081 Answers
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
Posted on May 21, 2010
rabbitbrains
  • 575 Answers
SOURCE: my frigidaire affinity front load washer stopped spinning
Your door lock switch assembly has gone bad. It is an easy fix.
Posted on Sep 27, 2011
Front loading model #FTFB4000FS1 is not draining....have to run the drain/spin a second time to get the water out....where i s the filter?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washer runs until rinse cycle, then starts making
pull problem code from machine. give knob a turn to wake machine-wait 5 seconds-then hold down start and cancel buttons at the same time. Your problem code will come up.
Nov 17, 2009 | Frigidaire ATF6000ES Front Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire front loading washer stopped at rinse cycle. 3 beeps
When in doubt check the easiest thing to check. The pump can cause a number of errors to come up. Since the unit stopped in rinse I would start but checking to make sure there is nothing obstructing the pump before going to the expensive parts.
Feb 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Atf 6000 front loader not spinning or draining
HI .you probably have a no drain problem. remove bottom panel. the pump is on the right. put drain hose on the floor, in a bucket, drain water out. check the pump. remove the hoses to the pump. clean out. thanks the appliance doc please rate my answer.
Oct 07, 2008 | Frigidaire ATF6000ES Front Load Washer
Drain pump starts and stops prior to final spin cycle
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
