Question about Tally Line Matrix T6050 Printer
T6050 printer i am geting paper jam problem - Tally Line Matrix T6050 Printer
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 80 Answers
Adjust hammer gap
Posted on Jan 10, 2015
3 Suggested Answers
  • 6 Answers
SOURCE: printer problem T6050 ( Tally )
this problem is occure due to logic card,pfmotor pfbelt,or the control pannel switch defective. upadhyay girish
Posted on Sep 29, 2007
  • 13 Answers
SOURCE: i want to set paper
fAQWfthjshbgfhbghb
Posted on May 21, 2011
Vibration in the paper ,as a result print is coming blurry in the T6050 printer.
release some gap by platen manually pull up. and calibrate hammer. for better printing
Jun 27, 2014 | Tally Line Matrix T6050 Printer
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
Mar 05, 2012 | Tally Line Matrix T6050 Printer
I have a lipi printer t6050. there is a problem showing shuttle fault. tell me what is this problem and how can i solve this
This error indicates the print mechanism is not able to move, in the first instance check;
There is no paper jams etc whcih may cause an obstruction
Check the ribbon is correctly installed and is the correct side of the ribbon shield
Check the platen gap to ensure this is not trapping the ribbon / paper and preventing the mechanism moving.
If the above actions do not resolve the problem the next thing to check is the Shuttle Mechanism,
Check the drive belt is in place and does not slip
Clean the rear side of the shuttle weight wheels, the sensor looks at the rear of the balanced wheels.
Check the shuttle motor to ensure it is working
Check for damage to the shuttle drive gears.
Dec 13, 2011 | Tally Line Matrix T6050 Printer
I WANT TO SET PAPER 15'x12' . KINDLY HELP SIR
Press START - Printers and faxes - right click Tally Line Matrix T6050 Printer - select Printing Preferences - find menu Paper size, select paper with size 15"x12". If not found, select used define or customize - insert paper size (width and height) - OK.
Set paper size on Microsoft office word 2007 - select Page Layout - Margins - Custom Margins - select tab Paper - on Paper size, select Custom size - insert height and width paper (15"x12") - OK.
Hopefully help
Sep 23, 2011 | Tally Line Matrix T6050 Printer
Printe paper jam problem for brother dcp135c
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 08, 2009 | Brother DCP 130C All-In-One InkJet Printer
Paper jam
it takes a little bit of disarming because you've got to clean the rubber rolls that "pull" the paper, a pair of grey rubbers almost cilindrical with a flat side located over the top of the paper, and happens that you cant clean them properly if you dont disarm the printer. These rubbers must mantain their "stickyness" to be able to pull the paper properly and with the use they become dirty.
That is the problem, so take your screwdriver and some isopropilic alcohol and ...........good luck.
Dec 04, 2008 | Kodak Professional 8500 Thermal Printer
Paper jam
Are you sure you have the correct size paper?
Also check and make sure the exit rollers are turning, if not then there is a broken gear in hte fuser
Jul 23, 2008 | Office Equipment & Supplies
Printer problem T6050 ( Tally )
This problem is occure due to Logic Card Problem or Paper feed motor Problem. Bhavin - India
Apr 06, 2007 | Tally Line Matrix T6050 Printer
Tally Line Matrix T6050 Printer Logo
41 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
