Question about Mint Automatic Floor Cleaner
Mint 4200 remains "on" an d will not do anything. It just bleeps one bleep when I push the button.
  • Steve Braddock
    Steve Braddock May 15, 2014
    Hi John , I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Are any of the lights on the the Mint 4200 on? The power, sweep and mop buttons have lights. please let me know if any of them are on, what color are they and if the flash in unison or in sequence or solid on. If no light at all are on then it needs to be charged. When fully charged the center power light will glow a solid blue. If it is blue then it may not be connecting to the cube. Make sure the cube is on. If it does not turn on automatically, turn it on manually. When it is on, a Blue solid light will be on in the opposite corner from the switch. If no blue light comes on then change out the two C batteries.
Vacuum not charging
I would contact dyson's service center. Make sure you have registered your vacuum first. Here is the website to find a service center near you. http://www.dyson.com/support.aspx
May 27, 2016 | Dyson DC44 Animal Cordless Vacuum
I bought at garage sale but it wont power on. sign says to push red button but red button is gone and
the problem with junk sales is that you buy junk
if the button is missing then doing anything may get you electrocuted
have it checked by an accredited repair shop but basically I would junk it as it will cost more to repair ( probably why it was sold in the junk sale in the first place)
Mar 25, 2016 | Vacuums
Why is there a red light
Is the red light blinking? Are there any beeps or tones? If so how many beeps?
Jul 07, 2014 | Mint Automatic Floor Cleaner
Heats up ok but no steam when temperature reached
Water indicator light keeps flashing and bleeping even when iron is full ,this is a brand new iron.
Sep 26, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
Dyson DC25- no suction
When you return the hose the wand will push the flap open, this is normal. if you were to take off your dirt bin youll see a clear dial with a grey arm attached to it. this grey arm is part of the piece your wand pushes open. This clear dial activates your change over valve. There should be a screw and plastic washer in the center of it. These sometimes work loose. You can try turning the dial by hand with the hose out and see if this changes anything.
If you need any help feel free to contact me,
Tim
TheVacCenter.com
Feb 17, 2013 | Dyson DC25 All Floors Bagless Upright...
Mint Plus Turbo Charging Cradle won't function properly
Cradle and contacts are fine. Cradle circuit is nothing but a reed relay and few wires, relay closes on proximity to robot's body, therefore no voltage on contacts before robot is close to cradle.
There is a thermistor inside of battery, and mine was bad. I removed it and now I am charging the battery from my bench power supply at about 220 ma current, overnight, and it works. Probably the solution is to get a new replacement battery, but the one with the thermistor inside (OEM), easily recognized by the third wire, and all should be fine, assuming that nothing else is wrong with charging circuit or power adapter (12v/1A)
Hope this will give you some ideas of where to poke.
Once successful, please post your solution.
Jan 19, 2013 | Mint Plus Turbo Charging Cradle
Electrolux d/w esl 6115,drains then fills and pumps straight and 50 degree light flashes all the time
NCORRECT PRODUCT CATEGORY
I'm sorry but you have this posted in the wrong product category. Please re-post the question in the proper category
Jun 29, 2012 | Vacuums
It bleeps 9 times, just go's around in circles help
Your bump sensors are malfunctioning. I had the same problem. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great..
Aug 28, 2011 | iRobot Roomba 530 Robotic Vacuum
Only goes in circle and shuts off.
Sounds like the dance of death. Run the diagnostics, and if it points to a wheel failure, it could be the sensors in the wheel are dirty.
There is a good tutorial on how to take the unit apart here:
http://mysteryroad.blogs.com/photos/fixthecircledance/xintroroomba_3549.html
Jun 14, 2009 | iRobot Roomba Scheduler 4230 Bagless...
Mint Automatic Floor Cleaner Logo
51 people viewed this question
Top Mint Vacuums Experts
Are you a Mint Vacuum Expert? Answer questions, earn points and help others
