Question about Dmm KWC K.24.41.61.000C28 Gastro Deck Mounted Single Hole Two Handle Kitchen Fa
33055 danco I need to replace how do I remove old one
  • 2,509 Answers
Turn off the water at the main stop, both hot and cold
remove pipes from below tap
remove nuts which hold tap in place
fit new one by reversing above operation.
Posted on May 15, 2014
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
How do I remove a 33055 faucet
www.danco.com
See if their website will be of any assistance.
May 15, 2014 | Danco 33156 Tub And Shower Faucet For...
How to install a danco 10472 4z-24h/c hot & cold faucet stem
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Feb 09, 2014 | Danco Faucet Stem
Need to adjust the water stop for a delta monitor tub faucet with a Danco 10347 replacement cartridge.
you have to disassemble your old faucet by using "Wrenches". than reassemble the new one
Sep 19, 2013 | Danco Faucet Cartridge
Remove old bathtub drain cover
There should be a screw holding down the cover. Have you tried Draino or similar product first?
Nov 19, 2012 | Danco 2" Polished Brass Snap-in Drain...
I bought the Danco replacement stem for a milwaukee faucet(part 4s-6h/c) it is leaking from the handle... do I need to replace the plastic part that runs back into the pipe? Is there an easy way to remove...
Sometimes on the stems on the side the handle attaches is a nut that can be tightened. Inside this nut is a rubber or other type of seal. tightening this nut stops the water from coming out of the handle. If the nut has already been tightened then possibly need to replace this rubber seal.
Sep 02, 2010 | Danco Faucet Stem
Does danco offer a replacement cartridge for american standard cartridge O28610-0070A
Danco is an aftermarket supplier of plumbing repair parts for almost all major brands. Look for a danco part that looks like the part you need then check the "compatible with" list on the package.
Apr 12, 2010 | Danco Faucet Cartridge
I bought a replacement Danko faucet cartridge for an american standard bathroom sink and the package said hot/cold but when I installed it on the cold side the handle turns the wrong way. How do I reverse...
Thae stem you got that said hot/cold were designed to fit old style cross handle faucets. So both hot and cold turned the same way. If the cold side you are replacing turns the opposite direction then you will need to get a cold stem. Danco does make them. Ask the retailer where you purchased the H/C stem. I hope this helps..
Dec 29, 2009 | Danco Faucet Cartridge
DANCO brand generic hose not connecting to supply
You have to buy a Genuine Delta Part because Delta uses a proprietary quck connect fitting at the end of the hose.
May 28, 2009 | Delta Faucet 470-DST Signature Diamond...
How does a 9s-4h/c danco stem install.
the spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
Apr 08, 2009 | Danco Faucet Stem
Dmm KWC K.24.41.61.000C28 Gastro Deck Mounted Single Hole Two Handle Kitchen Fa Logo
56 people viewed this question
Top Dmm Plumbing Experts
Donni Steen
Tom Chichester
Are you a Dmm Plumbing Expert? Answer questions, earn points and help others
