Question about Car Audio & Video
Why cant i programme the radio? - Car Audio & Video
  • 2,509 Answers
Because you aren't doing it correctly. Read the instructions.
I would try to help you further but for 2 reasons
1. Your question is far too vague, explain what does and does not work,what you have tried so far and what you are trying to achieve
2. People on here are not mind readers, you did not specify a make or model
Posted on May 15, 2014
What radios are compatable with motorola rdm2070d
The Motorola CP110 MURS VHF is a nearly identical radio. Most 2 watt programmable VHF radios are programmable to the MURS frequencies.
Jul 20, 2014 | Motorola Radio Communications
Cant sync radios
The MU21CV radio is user programmable. Hold in the PTT button while turning on the radio. It will announce the frequency. Use the PTT button to count it up to the frequency you desire. Press the smaller monitor button to lock in your freq. Then the radio will announce the code number. Once again using the PTT button count it up to your desired code or the word OFF if you are not wanting a code. Then press the monitor button to lock in the code. At this point you can turn off the radio and turn it back on normally (without holding in the PTT). Your radios should be programmed to match one another. If you are still having trouble you may have a radio which needs repair or a bad/low battery.
Best regards.
Aug 05, 2013 | Motorola MU21CV (1 Channel) 2-Way Radio
I bought a Motorola HT1250 Radio off Ebay from japan and cant program it
You will likely need the same version or newer of the software used to originally program the radio. You might check with your local Motorola dealer to see if they have the most recent Radio Service Software (RSS) and give it a try. Or a nationwide repair facility for after-warranty radio repair might have some idea how to get it to program properly.
The software is proprietary to Motorola and only available by subscription to Motorola Solutions dealers and certain other user types.
Best regards.
Feb 26, 2013 | Motorola Ht1250 Vhf 136-174mhz 128 Channel...
Turner only selects odd numbered radio stations
this is the frequency settings that programmed in your audio system, reprogramming will be done your problem, if it cant be programmable install a device on antenna output(frequency modulator changer) you will pick-up all station you want but the problem is... the digital cant be set to appropriate radio station
Jul 22, 2010 | Yamaha RX-V663 Receiver
I have a motorola Ht 1000 i need to no how to program it with the keypad only...
The HT1000 is not keypad programmable. The HT1000 is dealer programmable using a radio interface box (RIB), cable, the appropriate Motorola propietary software. A sister radio named the JT1000 can be made keypad programmable with an accessory called a programming key.
Best regards.
Nov 29, 2009 | Motorola HT1000, MTS2000, MTX8000/9000...
Motorola BPR40 how to clone
How To Clone a BPR40 Radio
Cloning duplicates the contents of your radio (master radio) into the new radio (slave radio). Tuning and alignment information are not affected by cloning.
Set Up the Master Radio
1. Turn off the radio.
2. Press and hold Programmable Button 1 (the top programmable button) and turn on the radio. Keep pressing the Programmable Button 1 until beep is heard twice.
3. Release Programmable Button 1. Notice the LED changes to RED
Set Up the Slave Radio
2. Press and hold Programmable Button 1(the top programmable button) and turn on the radio. Keep pressing Programmable Button 1 until the beep is heard three times.
3. Release Programmable Button 1. Notice that the LED changes to GREEN
BPR40 Radio to Radio Cloning Procedures
1. Connect the cloning cable to both the Master and Slave radio.
2. Press and release Programmable Button 1 of the Slave radio.
3. Within 2 seconds Press and release Programmable Button 1 of the Master radio.
4. The LED for both radios show flashing orange during cloning.
5. Once cloning is completed, an
Mar 24, 2009 | Radio Communications
1998 mbs e320 radio code
you need to find out who makes the headunit then go to them they will charge you but at least you have it its cheeper than buying a new one, or ask around see if anyone had perchased a radio code programme they sell on e-bey for about £20 i have one at home somewhere i cant get it to work
Dec 22, 2008 | Car Audio & Video
Compatability
Any programmable UHF 450-470MHz mobile radio could be programmed to the frequencies of the Spirit MU series radios.
Your radios are 2 watts, so you would probably want to stay with a 1-10 watt, or 10-25 watt mobile radio, to have the best success. The current compatible model for Motorola is the CM200 UHF radio. If you are looking at a used radio, just simply watch for it to be UHF 450-470 MHz.
Then when you are ready to have the mobile radio programmed, the dealer (or programmer) will need to know the settings of your MU radios. These are easily read out over the phone, or in person by an experienced programmer.
Dec 13, 2008 | Motorola MU21CV (1 Channel) 2-Way Radio
Car Audio & Video Logo
29 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
