Question about Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower
How to level the deck - Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower
  • Ariens Master
  • 2,478 Answers
Go to owner's manual. Tells you everything.
Posted on Jun 16, 2014
What is the proper way to adjust deck of a gravely pro stance 52" fixed deck? Should deck be level or slightly pitched to front?
Ideally, the blades should be level when measured on a flat concrete surface. Otherwise, they'll cut shallow trenches - front if the deck is pitched forward, rear if the deck is pitched rearward. If the blades are level, they'll cut flat all the way across.
Jul 31, 2014 | Garden
Deck is not level and mower blades are not the same height
Usually you can solve this problem by leveling the deck. Many mowers have adjustment nuts on the ends of the brackets that attach the mower deck to the frame of the mower. First park your mower on a flat surface like a sidewalk or driveway. Then place a small level on a flat area of the mower deck, then turn the adjustment nuts until the deck is level.
Jul 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Husky yth1542xp. I've changed the blades, leveled
When levelling the deck, rotate the blades so that the right blade has one of its cutting edges at or near the right side center of the deck. Do the opposite with the left. Measure to the blades from the level ground, not to the deck. Try leveling that way.
Gary
Jul 03, 2011 | Husqvarna Garden
How to adjust the mowing deck properly?
Find a level surface (concrete garage floor for example) ... adjust front to back ... use a tape meadure to mneasure floor to deck edge ... then adjust side to side.
Jul 29, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I adjust the deck level on a Husqvarna riding mower?
Not sure if you are looking for the nuts and knobs or how to level? Most newer decks have knobs for adjuctments. I park my mower on a concrete level surface make sure all tires are at the correct psi then with tape measure check front left and right at bottom of deck for same measurment. You can also put a 2 ft level on the deck and adjust.
Mar 13, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a GX75 riding mower and the deck is not leveling out. No matter what level I put it on (1-4) it always ends up with the front of the deck lower than the back by at least 3/4 of an inch. This is...
if you have verified that the deck is level then you will need to replaced the spindle,if the deck is'nt level ,adjust the leveling nuts on the arms it hangs offf.
Sep 30, 2009 | Garden
I need to level the deck on my craftsman YS 4500 lawn tractor
I leveled mine by parking it on a level concrete area, dropping the deck down onto 4 short pieces of 2 x 4 laid on the flat sides and placed in each corner of the deck and the I adjusted the 4 linkage bolts so each one had just started to lift the deck off the 2 x 4's. this should get it as level as possible. hope this helps
Sep 08, 2009 | Craftsman Garden
Mower Deck not level
there is a geared bolt at the deck suspension un lock it and rotate it will raise and lower the deck
Jul 31, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Can't level deck.
try checking the blade spindle to see if there is any play (up,down,left,right) hope this helps
Jul 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Uneven cut
1-----------tire pressure? 14 front 10 rear
start with a level mower on a level surface
2------------deck level side to side?
3------------deck level front to back? (front can be 3/8 lower than back)
4-----------deck hangers bent or hung up?
5------------blades even when pointing at each other? no more than 1/8 high or low
6------------blades dull or upside down? turned up ends go towards deck
7---------------incorrect blades for mower?
8------------deck lifting mechanism should pick up deck evenly and drop evenly?
9-----------under the deck need cleaning because it is packed with grass?
Jun 15, 2009 | Garden
Ariens 42 in 17.5 HP 6-speed Riding Lawn Mower Logo
163 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
