Question about Nespresso Coffee Makers & Espresso Machines
Brand new Nespresso Inissia M105 won't heat the water
Hi everyone! I just bought a Nespresso Inissia (the Magimix M105 model), did the first use step (just make coffee without using a coffee pod three times), and then started making coffees. The first three coffees were fine, so I know I'm not screwing up : press either of the buttons, wait for them to stop blinking so that the machine heats the water (25 seconds), then when they stop blinking, press the button corresponding to the amount of coffee you want. It worked for three coffees. And then, still on the very day I bought the machine, it just stopped. When I press the button, the buttons start blinking, and keep on blinking. Forever. I got the machine just there, it's been blinking for 20 minutes + (the time I went to nespresso.com, magimix.com, checking if there was an active nespresso subreddit, and so on.) Let me just tell it to make a coffee... [...] ...it's not cold enough for me to call it "cold", but it's definitely not warm. After 20+ minutes of "heating" instead of the 25 seconds promised. So I don't know what to do. Nespresso.com tells me that I have to make sure that my cups are pre-heated (1- really?, 2- I don't see how it will help, you can't make coffee with cold water), magimix.com tells me to descale it (really? It's brand new, so you mean to tell me I have to descale my machine every three coffees made?), and the obscure user manual is obscure as f*ck (just a bunch of icons that are incomprehensible at best). Any help would be appreciated.
  • 2 more comments
  • Cha Del
    Cha Del May 15, 2014
    Hi again. Just found in the manual the "Reset to Factory" thing, just press the right button for 5 seconds and wait 30 seconds. Now my coffee machine works fine again.
  • Cha Del
  • Mark channing
    Mark channing Nov 30, 2014
    I phoned help desk. The mode above is descaling. Hold both buttons for 6 seconds and then that should fix it. Did for me anyhow
  • Antonia Meshko
    Antonia Meshko Jul 06, 2017
    Neither of the above worked for me :(
  • 2,509 Answers
Just a brief addition, I don't have the Magimix model, but I have a similar one. It loses it's programmed settings if it is unplugged or switched off at the wall, but if you leave it plugged in but turn it off with the switch at the back it keeps the settings you have put in. It draws virtually no power when it's switched off with the switch on the machine, (I checked it with a power meter).
Just thought I'd share that with you.
Posted on May 15, 2014
The 2 buttons keep flashing & the water won't heat up
You must re press both buttons at once again sow you will remove mashein from descaleing mode
Oct 09, 2016 | Nespresso Coffee Makers & Espresso...
Can I use vinegar and water to descale the machine instead of the expensive kit? What proportion water to vinegar?
You can use vinegar freely, just wash your coffee maker when ready.
Vinegar only descales, won't damage metal and rubber parts.
Sep 29, 2015 | Nespresso Inissia
My Nespresso inissia is not working. the lights come on and when i press either of the buttons to run the coffee through the button flashes but the machine makes no noise and nothing happens. Please Help
I would imagine the main pump/heater unit has failed. Probably better to buy a new one, unless you can take it back to the outlet where it was purchased.
Feb 17, 2015 | Nespresso Inissia
Inissia keeps blinking
Thios could indicate the machine has returned to factory settings. Other than that it requires repair - check the user guide..
http://www-media.nespresso.com/ecom/websites/manuals/inissia/inissia_C_krups.pdf
Sep 23, 2014 | Nespresso Inissia
Why too little coffee
The machine is calibrated to produce a certain amount of water depending on which button is pressed (Lungo or expresso - larger or smaller cup). This can be altered by holding down the relevant button - check this manual..
Aug 23, 2014 | Nespresso Inissia
Hi, i cannot get water to go through the machine through the coffee capsule. The machine makes the pump noises etc but no water comes through from the jug at the back. Any suggestions of what to do? We do...
You can download the instruction manual from various places online; the instructions for the automatic and manual versions are slightly different but you can find them here:
www.eirvik.is/gogn/L/m100.pdf
www.eirvik.is/gogn/L/m100_automatic.pdf
As a first step I would suggest checking that the water can get out of the tank (just touching it with your fingers (over a sink!) should let drips out). It not, try cleaning that. You could also try descaling it (as in the manual). By the way, if the machine is less than three years old and you still have proof of purchase the Nespresso club will honour the warranty and fix it free of charge; if not, give them a call anyway and see what you can get them to do for you.
Aug 22, 2011 | Magimix L'Expresso Espresso Machine
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Nov 14, 2010 | Nespresso Essenza C100 Espresso...
The steam wand keeps throwing out water and making my milk watery
Call the Nespresso Club, they will hepl to solve it in no time
0800 442 442
Good luck
Frog
Dec 28, 2008 | Nespresso D300 Espresso Machine
Coffee Makers & Espresso Machines Logo
1,500 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
