Question about Cameras
My tv has a sluggish picture. It almost acts like everything is in slow motion. The picture is very blurry
  • 2,509 Answers
I already replied, but to add try a reset also make sure any motion settings or noise reduction settings are turned off.
Posted on May 15, 2014
Samsung 55" blurry picture and words are blurry...netflix comes in perfect...whats wrong
Is it a 3D TV. Try changing the refresh rate in the Picture Menu 60HZ is normally the standard but try others. Or if you're TV has Auto Motion Plus options you try turn it on it can be found in your television's menu under Picture Options. The Auto Motion Plus menu contains several options, including On, Off, Clear, Smooth and Standard. If changing your Auto Motion Plus options doesn't correct blur, call Samsung.
Jan 24, 2015 | Samsung Televison & Video
Why is the picture on my Sony KDL-55HX729 blurry? The right side of the screen is light and blurry like its in slow motion and retains the previous screen picture, it fades after a few secondboard may
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 19, 2014 | Televison & Video
I have a Sanyo DP42849 tv and the picture is real blurry almost seems like the picture is in slow motion but the sound is fine. When I shut the tv off it has a good picture for about 30 seconds then it's...
Try resetting, Not sure if this works for your model
Power off the TV, hold down the reset button on the remote and power up the tv with power button on tv while keeping reset depressed.
(Is there a restore factory setting or reset buried in the on screen menu? I couldn't find it in the manual, can you let us know if there is?)
here is the manual in case you don't have it
http://us.sanyo.com/dynamic/product/Downloads/DP42-46849-52449%20(331--)-15947801.pdf
May 15, 2014 | Televison & Video
Picture comes out blurry
There are three main reasons for blurry pictures.
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway.
Subject motion. If moving objects blur while stationary objects remain sharp then the shutter speed is too slow to freeze the motion. Try switching to the sports mode, and/or add more light.
Camera motion. This is the most common cause. Set your camera on a table or other stable surface and use the self-timer to take a picture. Take another one while holding the camera. Compare the two on your computer.
Feb 22, 2012 | Canon PowerShot SD870 IS Digital Camera
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
Picture on freeview appears to be in slow motion
Hello.
Connect DVD player to your TV and make sure that there is no "slow motion" while using it. If everything seems to be OK - problem has nothing to do with TV. It is outside of it and could have something to do with your signal source (like cable box, etc).
If DVD have same issue - main board in your TV have to be replaced.
Regards.
Russ.
Dec 01, 2010 | LG 37LC7D 37 in. LCD HDTV
Why are my pictures coming out blurry?
Pictures may come out blurry if they're not focused properly. If some objects are sharp and others are not, this may indicate focusing on the wrong subject. This is usually not a major problem with compact point&shoot cameras since they have such a wide field of focus that almost everything will be in focus anyway. However, make sure the macro/far switch is set to the appropriate position for your picture.
Jun 12, 2010 | Vivitar ViviCam 8025 Digital Camera
Toshiba 50HM66 DLP. Picture is blurry/slow motion.
Because of the price of the part it is a legitimate estimate. It is a bummer that prices drop like they do to buy new but as you can tell the manufactures are not too concerned about customers repairing 2-3 yr old TVs.
Sorry about the dad news,
Skyassoc
Jul 17, 2009 | Televison & Video
Olympus 720 SW blurry
slow the motion of taking the picture...by mashing hard the images in digital camera are always less the desirable
Jun 06, 2008 | Olympus Stylus 720 SW Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
