Question about Sony DAV-SB100 System
Volume does not go up to 100 but 39 (with or without speakers) , what is that means ... is it only visual or something is broken
    Problem Solver:
  • 19 Answers
I believe that 39 or 40 is the maximum.
Posted on May 15, 2014
Testimonial: "I have this problem with other sony devices before they got to "random number" they was going to 100 ... it's always 100 because it's percentage"
My teac ag-v1200 audio/visual receiver isn't
check speaker connections - unit might be going into protection
Sep 03, 2014 | Audio Players & Recorders
Broken connector in subwoofer connection on receiver
The only thing you do is to open your receivers,then locate the output connector if you see the female RCA jack ,then push it out the broken piece ,that's it
Jul 27, 2008 | Audio Players & Recorders
Lost sound in speakers, but sound will play with earphones.
That means one thing.
Your speaker is broken but lucky for you, the driver is still intact.
You can bring your laptop to your nearest repair shop and ask them to replace the speaker. It happens. A lot. Maybe due to prolonged used or low quality audio played with high volume, or it can be something else but changing to a new one can assure you that sounds can be played through the speaker again.
Either one of it or both are broken but they count the speaker as a unit. So, good luck.
Aug 26, 2014 | Acer Aspire Computers & Internet
My crossover on Behringer speaker cab ba-115 (15" bass driver plus tweeter) is bad. Does anyone have the schematic before I tear it apart?
There is very little to an inspeaker crossover that could go bad unless it was SEVERELY overdriven. I recommend checking the speaker individually on a wire from a stereo or something powered to verify this. A crossover is nothing more than a capacitor (high cutoff) and an inductor.(low cutoff). The 600 watts rating of the cabinet is an RMS rating, meaning, .707 actual peak value free of distortion. This means that you can only drive it about 71% of that without distorting or damaging it. You said, "very little signal gets to the speaker", which sounds like "very low volume" meaning, magnet stuck, speaker not moving much, meaning warped voice coil. Check that the speaker will move back and forth with your hand freely without interference or scratchy noise. If it doesn't, the voice coil is warped and the speaker needs to be reconed or replaced.
Mar 12, 2013 | Music
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
My macbook volume is not working.the volume is not working until i use earphones i cant skype or listen to music without using earphones please i need your help on this thank you.
I think that your speakers are probably broken, maybe you should try installing drivers first, if this doesn't help you can jump to the conclusion that they really are broken.
Mar 16, 2011 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
How do I change the volume on a visual land v-touch?
When you are listening to music or watching movie press the speaker icon. Then press the + or - button to change the volume.
Oct 03, 2009 | Visual Land V-Touch Digital Media Player
Generates buzzing noise even when only cable is connected to it. No cable - no noise.
If you are saying that you are plugging a guitar cord into an input on an amp without the guitar on the other end and you are getting a hum or buzz with the volume turned up ; that is normal. If you are getting the same results with a guitar plugged in it means the ground wire to your output jack on your guitar is broken. Check your cord with a volt ohm meter for continuity on the tip on one end to the tip on the other end. Do this for the sleeve on one end to the other. If you were getting the buzz without a cable it would mean that your input jack in your amp has a broken ground connection. Hope this helps.
Jul 04, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
Unable to receive calls without using speaker
While receiving a call press < or > on the side of the phone this will turn the earpiece volume UP or DOWN a visual bar will appear on the screen. Do this during a call.
Dec 28, 2007 | Sony Ericsson K800i Cellular Phone
Sony DAV-SB100 System Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
