Question about Baby Gear
Chicco walker I have taken apart the locking mechanism for the walker and now it`s back together, although the lock doesnt see to work and does not secure the position of the walker; it drops all the way down without locking securely in the desired position...
Kimi
  • 277 Answers
SOURCE: Door latch is in "LOCKED" position however the door is open!
It is possible that you have a problem with the door?s sensor, maybe it?s turned off or maybe some water fell on it. This is the reason why the micro controller interpret that the door is still open, and that?s why the washing procedure does not start. You have to find the manual and determine where is the location of the sensor and then see in what state it is (Turned off, wet, or damaged)
Posted on Jul 12, 2007
tbirdfan1
  • 3051 Answers
SOURCE: deadbolt stuck on lock position
hello there:
you will need to dissasemble the deadbolt there is a plastic piece that wears out over time and once this wears out it wont work right probably best just to replace the deadbolt (sorry)
Posted on Jul 22, 2009
  • 1986 Answers
SOURCE: PASSANGER DOOR LOCK WILL NOT LOCK ALL OTHER DOOR
You'll probably have to remove the door panel and look at the lock assembly. It sounds like one of the linkages may be broken or seizing...
Posted on Aug 11, 2009
mohammed387
  • 1952 Answers
SOURCE: feed dogs stuck in down position
that the feed dog lever is in the up position. When the lever is in the down position, the feed dogs will show on the top if there is no pressure on them at all. Make sure that the machine makes one complete cycle to check this. Just throwing the switch does not make them come to the surface.
If this does not work, then the feed gear is broken and you will need to take it to a mechanic.
Posted on Aug 26, 2009
SOURCE: I turned my nokia 1661 off. When I turned it back
The code is 12345
Posted on Oct 12, 2009
2008. Rear hatch window closes but why won't it lock?
That could be mechanical or eletrical either way take to a body shop or mechanic who can take it apart an put it back together an make it work.It needs special attention.
Nov 21, 2015 | Kia Sportage Cars & Trucks
Unable to open the driver side front door of my 1993 Buick Century Custom. I have taken the door panel off and have all of the linkage and locking mechanism apart.Having diffulculty remembering how it goes...
Your best bet is to remove the door panel from the other side and this will help you see how it goes together.This is in case you can`t find any other info.Hope this helps.Good luck.
Mar 24, 2011 | 1993 Buick Century
The drivers door will not lock or unlock with the electric door lock or key lock. How to repair?
I believe it is in your switch. A lot of the models the key works the inside switch when you turn it also so if the switch inside hascorroded contacts the key would make no difference.
I have taken several of these switches apart and sanded the contacts and put them back together with a 100% working record afterward. If you donot want to completely take the switch apart then pick yourself one up at the wrecking yard for 5 or 10 bucks. You'll need to remove the switch but you won't have to tear into it. I hope this helps you, The Raz
Apr 15, 2010 | 2002 Lexus Gs 300
Replacement console for chicco baby walker
Most likely! look through the items manual ,usually there would be anuber or web address! try those out!
Oct 15, 2009 | Toys
Need to buy one back roller (wheel) for chicco baby walker
check out their site: chiccousa.com and contact customer service. they should be able to help with parts.
Aug 18, 2009 | Chicco Toys
Chicco UFO baby walker seat damaged
go to your local retail store and find a baby walker just like the one that you have and explain your situation and ask for a copy of the manual. in the manuel, find and warrenty with the company and reapair/parts number and they will help you
Apr 21, 2009 | Baby Gear
Replacement seat for dj seventy baby walker
I would try contacting Chicco directly, or a local stockist of Chicco products. They should be able to get one shipped to you. I wouldn't have any idea of how much this would cost though!
Apr 01, 2009 | Baby Gear
Baby Gear Logo
242 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
