Question about Motorsports
Hi everyone Can i get help please ?
My Mazda 3 hatchback makes noise on passager side it do that when drive it also when I stated put it on R and D I changed the strut , control arms also the the link ... It's still making that noise
    Sergeant:
  • 181 Answers
Hello. Check the transmission munts. And just incase, check the motor munts just to be safe. Good Luck.
Posted on May 15, 2014
What would make a 2008 Mazda tribute 2.3law make a noise while driving as if the axle is bad
check brake pad thickness( have a indicator that runs on the disc when the pads are too thin
Jan 29, 2017 | 2008 Mazda Tribute
Hi.my mazda3 2005 2.0 did not cone with a manual. second hand buy.if I look for radio code problems everyone keeps on saying to put in a new code after using the master code I should check the manual. I...
Take the Mazda straight to a Mazda dealership and they will solve your problem in no time. Or email Mazda corporation and they will email back with the instructions, like I did. We have a 2005 Mazda SP23.
Feb 17, 2015 | 2005 Mazda 3 2.0
Serpentine belt diagram mazda
2012 Mazda 3 I touring Skyactiv - Takes a 38" 6 groove serpentine belt- Very hard to find. The only place I found besides the dealer it Advance Auto but they had to order from the warehouse. There are three grooved pulleys and a smooth tensioner. To relieve the Tensioner you will need a shallow 17MM socket, it is a bit difficult to see, but if you stand on the passenger side the mount point for the socket is to the left of the tensioner shock. The Tensioner shock is just above the smooth tensioner pulley. All the threaded pulleys' (Drive, A/C, and alternator are within the serpentine belt, the tensioner pulley is outside the belt pushing down on the belt. The easiest way to replace this belt, First remove the old belt by placing the socket on the mount point and pulling up on the ratchet towards the rear of the car, then pull belt off. Next remove socket, place the belt over the drive pulley (this is the one on the bottom to the rear of the engine. ( you will see there is another belt on this pulley on the back side.), then put the belt over the A/C pump bottom front. Keep tension on the belt so it stays in place. Now put that socket back on, push up to lift the tensioner pulley and slip the belt over the alternator pulley. Make sure the belt is sitting properly on each pulley and under the tensioner pulley. Good luck. I have run into quite a few problems finding parts and information for this particular model. Good luck. Hope this was helpful
Apr 11, 2014 | 2012 Mazda 3 i Touring 4dr Hatchback 2.0L...
Chat room
And what does it say? what's the code no.?
Jun 08, 2017 | 2007 Mazda Speed 3 Hatchback
How do you reset anti-theft control on 2001 mazda tribute
Hello everyone I had the exact same problem this morning. .antitheft light blinking rapidly unable to start . After screwing around with everything. I finally disconnected my battery positive connection left it off for a few minutes. Then reconnected it tried to start nothing happened.I then located my fuel pump reset located on my passage side of my 2010 mazda tribute reset it and it started no problem. Hope this helps anyone in the future with his issue.
Dec 05, 2011 | 2001 Mazda Tribute
Hi, The windscreen wipers on Mazda 3 hatchback 2008 have stopped working. I think it's the fuse, but I can't find the fusebox. And I have no manual.
One fuse box is at the feet of the passenger. all you have to do is undo 2 half-twist fasteners, and the other fuse box is under the hood right behind the battery. I hope this helps. as to what fuse, i have no idea.
Dec 04, 2010 | 2008 Mazda Mazda3 Hatchback
Hi i just wanna how and where can i put power sterring oil for mazda e2000
On the passager side down below you will see a plastic cap say power stering on the cap so take it off then put Power Stering only ...Good Luck
Sep 29, 2010 | Mazda MAZDASPEED3 Cars & Trucks
My mazda makes a clunking noise.
it sound as if your sway bar bushing is worn give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
Mar 27, 2010 | 2008 Mazda Mazda3 Hatchback
New battery in 06 mazda 6
1. Turn ignition switch to "on" position.
2. Open passenger window completely from passenger side window switch.
3. Close passenger window completely from passenger side window switch, and hold switch for an additional 2 seconds.
4. Turn ignition back to "lock" position.
That's it. Works like a champ. And here you thought it was more than just a battery dying....I did.
Aug 11, 2008 | 2006 Mazda 6
Motorsports Logo
271 people viewed this question
Top Motorsports Experts
_-__-___-_
_-__-___-_
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Are you a Motorsport Expert? Answer questions, earn points and help others
