Kodak 605 Why " Ribbon empty" is displayed when new Paper roll and new ribbon loaded
  • 113 Answers
SOURCE: Ribbon error 754
Your printer is not correctly configured for ribbon. Download the manual located at ftp://www.servisource1.com/user_documentation/9855/9855oh-ae.pdf
Go to chapter 4-1 to see the map of the menu system and change your printer to ribbon yes.
Make sure that your printer is loaded with supplies and the ribbon is set up correctly, as well as slack taken out.
You may see a couple of labels not print well, but after that, you shold have proper tension and good print. If you notice a lot of ribbon wrinkle, you probably need to reload your ribbon or adjust the tension bars.
This should resolve any issue you have with the ribbon.
Ohiotech
Posted on Feb 06, 2008
itdude4321
  • 13 Answers
SOURCE: TAKE UP RIBBON
I work with Zebra printers daily and I have found several ways to enable a stuborn ribbon motor. The S300 is the hardest to turn on but unless the belt has broken or come off it can be done. The S400 and S600 are much easier, below are a couple step that work for me.
Enabling/Disabling the Ribbon motor
Turn off the printer.
Disabling the motor – Press the FEED, CANCEL and MODE buttons while turning the printer on. Continue to hold the buttons until the lower two lights go out.
Enabling the motor – Open the printhead and retract the ribbon completely onto the supply spool. Leave the printhead open. Press the PAUSE, FEED and CANCEL buttons while turning the printer on. Continue to hold the buttons until the lower two lights go out. When the printhead light begins to blink, reinstall the ribbon and close the printhead.
The printer may or may not print out a ribbon sensor profile, this is normal. Cycle the power and you should be good to go.
Posted on Mar 30, 2008
SOURCE: Problem with Intermec 3400 ribbon supply
Just take the head of ink outside and clean it carfully and return it back it will work. use clean solution.
Posted on Apr 06, 2008
  • 85 Answers
SOURCE: MY SONY UP-10L SNAPLAB PRINTER GIVES ME THE
Hi
This sounds like the sensors are damaged. Best taking to a computer repair centre to be checked out as sony parts can be hard to acquire.
Thanks
Taz
Posted on Oct 23, 2009
  • 794 Answers
SOURCE: i have the same problem
Hi davecortazzo,
If you got 'Incorrect Ribbon ' error message in Kodak 6800 printer do the following thing :
1. First open the printer cover and clean the barcode sensor. The barcode sensor is right side of the thermal head.
2. If still same error message then you have to upgrade the firmware of your printer. You may download it directly from Kodak's website. Just kindly follow the instructions provided on the website. This should solve your issue.
Hope this helps.
Thank you for using FixYa.
Posted on May 30, 2011
Ribbon is empty in fax machine 575 what to do
Check if the thermal ribbon (ink) is finished . Open up the front panel and you will see the black film roll .
Sep 11, 2014 | Brother FAX-575 Plain Paper Thermal
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
Ribbon feeds out with label
Your take up spool isn't working properly, bad motor or belt.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
Datacard sp55 printer won't recognize ribbon
PR-01726 Ribbon Out
Out of print ribbon.
Possible Cause 1 : The print ribbon Cartridge is empty.
Solution 1 : Reload the print cartridge. Change the cleaning sleeve and replace the cartridge in the printer. Run a cleaning card as soon as printing is completed.
Possible Cause 2 : The printer ribbon is not loaded correctly.
Soultion 2 :Load the printer ribbon correctly and then close the cover.
Possible Cause 3 : This ribbon has been completely used.
Solution 3 : Use a new roll of ribbon.
Tips for Success
* When this message appears, replace the old ribbon with the new ribbon of the same type. The printer has already prepared the card data for this ribbon type. You can change the colors of monochrome ribbon (such as from dark blue to gold).
* If you must change the type of ribbon (such as (YMCKT to KT) when this message appears, install the new ribbon, cancel any cards waiting to print, and change the ribbon type settings. Finally, return to the card creation program to send the card data to print.
* If the ribbon was repaired, the wrong take-up spool was used. Repair the ribbon again, using the correct take-up spool.
If you cannot fix the problem contact your service provider for assistance.
FTB
Nov 23, 2009 | Datacard Group SP55 Card Printer
Sony UP-DR150 4x6 "ribbon error"
The black spool of the ribbon has a built in chip, If that chip is damaged it renders the ribbon unuseable. Be very careful if you take out party used ribbons and re insert them later.
Dec 15, 2008 | Sony UPDR150 Thermal Photo Printer
Printer constantly says Paper End
Yes I did find a solution but why should I tell you so you can turn around and charge someone else that may be having the same problem? It looks to me like any assistance from you would have cost me. Thanks for nothing.
Oct 01, 2008 | Sony UP DR100 Thermal Photo Printer
Error code 754
It's very possible you are not installing the ribbon properly.
When loading a new ribbon on a Monarch printer, you must save the plastic ribbon core (it's butter yellow in color) from the previous roll of ribbon. The core is what the ribbon is wound up on.
Do not throw away this plastic core - you need it for the next roll of ribbon you load!
You have to move this now empty core from the back ribbon spindle and slide it on the front ribbon spindle. You then load the new ribbon on the back spindle and attach the ribbon end to the empty plastic ribbon core on the front spindle.
You CAN NOT just tape the ribbon to the front spindle. You must have an empty ribbon core to attach the new ribbon to. The printer will give a 754 error unless you have two plastic cores on the two spindles. It can also give a 754 error if the ribbon is not loaded properly, and also if you have a bad motherboard. There are no ribbon sensors, so that's never going to be a problem...
Jul 28, 2008 | Paxar Monarch 9850 Thermal Printer
Ribbon empty
Winding technique:
To wind a new ribbon, take the cartridge housing apart and remove the old ribbon and two cardboard cores. The new ribbon is fitted with the larger roll (the ink ribbon supply spool) at the rear side of the cartridge (as the housing is viewed when it is normally installed into the machine). The ribbon winds over the topside of the rear spool (the supply side) and feeds into the underside of the front spool (the take-up side). Make sure the ribbon is wound neatly, evenly and is tight. If the ink film has become detached or is too loose on the front spool it will not wind on and cause a machine error. If required, use a small amount of sticky tape to secure the ink film to the front cardboard spool and then neatly wind it on to the take-up spool a minimum of five turns, making sure the film does not overhang at the edges. Now reassemble the housing and refit into the machine.
If it’s still not fixed:
If problems persist after fitting a new ribbon, try replacing the entire ink ribbon unit (cartridge housing + a new ink ribbon) using a new, genuine Brother unit before requesting a service; this will be less expensive as the actual housing may have been damaged and is causing the problem and this unit is readily available as a consumable item through sales outlets. If the machine still has problems, book your machine in to be repaired with an authorised Brother Service Centre.
Feb 17, 2008 | Brother FAX-575 Plain Paper Thermal
82 people viewed this question
k24674
jasbo
jasbo
