Question about HP LaserJet P2015dn Printer
Can you tell me what the buttons on the left hand side are I lost my manaul to my printer and I need to know which one is my cartridge on my hp laserjet p2015dn
  • 78 Answers
Printer says "Open Door Clear Cartridge Jam" How
You might wanna try removing and reinserting the cartridges and make sure that they are properly fitted in.
Sometimes cleaning the cartridge and the carriage where you took out the cartridges from with a damp lint free cloth does the trick.
If you still have that message, open the cartridge access door.
If the carriage is stuck at the right side of the printer, move the carriage to the left side by hand. If it's stuck on the left side, try moving it by hand in the right side of the printer. Then while the printer is turned on, unplug it from the wall outlet and then plug it back in.
If the printer does not turn on, use the power button.
Try printing again.
Feb 03, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I have an hp laser printer 2550. all os a sudden
What has wrong is the toner cartridge holder has jumped a tooth and thats what is causing it. It is a easy fix but very hard to tell you over fixya. Steven 818-888-0006
Mar 12, 2010 | HP Color LaserJet 2550n printer + HP Color...
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
The printer prints on right hand side while left hand side is blank
Reinstall the printer driver, for starters. failing that take the toner cartridge out, give it a gentle shake end-to-end so that the toner powder inside is fluffed up, and then put it back. You may need to change the cartridge completely. HP lasers are usually pretty good.
Jun 27, 2009 | HP LaserJet 2820 Printer
Cartridge stuck in Printer! HP OfficeJet 5610
I Got it! I just did something similar, black ink in color slot. At first I tryed prying and yanking and wiggling all to no avail. When I actually stopped and looked at it, I could see a little lip sticking up on the back left side of the cartridge, the chamber is made for a little lip CENTERED-so used my left hand on the side of the ink to push it to the right so that the lip would slip through the slot in the chamber while I pulled with my right hand-IT WORKED!!!! Came right out! If you put the color in the right (wrong but (R)) side-try pushing from the right to the left while pulling out. The key is to LOOK and guide the lip on top of the cartridge through the little slot opening in the chamber. Good Luck!
Jun 17, 2009 | HP Officejet 5610 All-In-One InkJet...
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp Lj 2430TN Printer
We ran into this problem a lot when this series first came out. There is a simple sensor on the left hand side of the toner cartridge area inside the printer that physically detects that a toner is installed (or not). With the left cover off, there is a plastic bracket that holds a lever; unless it is not, then it tells you that you have no toner installed. Lame.
Jan 16, 2008 | HP LaserJet 2430dtn Printer
Hp 2420 printing light on left side of page
take out cartridge and look at roller on bottom of printer, clean with clean cloth and try, also there is a slit ( or hole on the inside ( put your hand inside and try to touch the top of printer there is a hole there where the images go to the laser clean with clean lint free cloth.
Nov 01, 2007 | HP LaserJet 2420 Printer
Change ink cartridges
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
532
Oct 21, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Ink Cartridge installation
At leaset tell us what is your printer model. On your Left hand side Color and black on the right.
Oct 06, 2007 | Epson Stylus CX5400 All-In-One InkJet...
HP LaserJet P2015dn Printer Logo
177 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
