Question about Refrigerators
How to clean coils in Kenmore Elite Model 795.72063.112
I don't know where the coils are? Usually they are under the frig.
    Scholar:
  • 84 Answers
The condenser is behind the cover on the back of the unit, on the right-hand side if you're facing the back of it. It's probably shrouded.
The book says not to remove the cover, merely to vacuum the vent but I wouldn't trust that, clogged condenser is the #1 cause of compressor failure, far and away.
I would definitely unplug it before removing the cover. If there isn't room to vacuum it or brush it off, used compressed air to blow the dirt out, but be careful not to displace any shrouds (they're important to air flow.)
Posted on May 15, 2014
  • 1462 Answers
SOURCE: kenmore elite bottom freezer 596 serires
+4 degC for fridge and -18degC for free3zer
Posted on Sep 07, 2008
  • 531 Answers
SOURCE: We have a Kenmore Elite refrigerator top freezer
check damper control
Posted on Apr 07, 2009
Maytag317
  • 1136 Answers
SOURCE: Refrig is hot to touch
Hi, Have you checked to see if there is a frost build up in the freezer? How are the temperatures in the fresh food side or the freezer side? Check and make sure the evaporator motor is running in the freezer. Please let me know if you find any of these issues. When that area is hot, usually there is more going on and the temps are not right. Let me know so I can assist you further.
Thanks
Vic
Posted on May 13, 2009
  • 10 Answers
SOURCE: ge frig model 18-25, how to clean grills under the
If you're not satisfied with the job the brush does you may have to buy or borrow a small compressor and use air to blow the lint/hair clear of the cooling lines. Our buildup was due to pet hair (2 dogs & a cat so the $200 I spent for the compressor, hose and extended nozzle were used monthly (clean cooling system will reduce the unit's e;ectrical consumption) and paid for themselves.
Dave
Posted on Jan 06, 2010
heatman101
  • 43501 Answers
SOURCE: accessing and cleaning coils on Kenmore Elite Side by Side
To reach the back coils you need to pull the fridge out and take off the cardboard type cover...
I often use an air compressor with high pressure air to blow out the coils..makes a mess but oh, well, sometimes you got to do what you got to do...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Heatman101
Posted on Feb 07, 2010
Kenmore Elite Refrigerator 596.76253701 Looking inside the frig, I am unable to find the cubic feet fo this frig. Do you know what it is???
Should be a sticker on the back of the unit, most times they only state make and model number. You may have to enquire from Kenmore for cubic feet if it is not stated on the sticker.
May 27, 2015 | Kenmore Refrigerators
No air coming into refrig to cool
We pulled the back panel in the freezer and found the coils frozen. We defrosted the coils and the fridge started working. We will be getting a new timer. Thanks
May 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Thanks
Vic
May 10, 2009 | Kenmore 53542 / 53544 Side by Side...
How do I remove the grate on the bottom to clean the coils
They are usually held in with clips that snap in and out. This is especially true if you don't see any visible screws. Give it a good tug on one side and see if it pops out.
Dec 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Kenmore Elite Bottom Freezer Refrigerator Model 795.7554
the condenser coil on this is located in the back side and removal of the rear cover is need to get to the coil. It's on the right side looking at the back. make sure to unplug the ref before taking the back off.
Aug 09, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer works but frig is not cooling
I don't know this particular frig, but evidently the defroster doesn't work. Frost buildup has blocked the flow of cold air.
There is a defrost timer, under the frig, accessible from the front. You can turn it with a screw driver. Turn it till you hear a click. If the timer hasn't been turning, that should turn on the defroster, a heating element nested among the freezer coils. Wait half an hour and if it is defrosting, water should be dripping into the drip pan underneath the frig. If so, then replace the defrost timer and you're good to go.
If that doesn't make it defrost, then the problem is probably the defrost thermostat, in with the freezer coils. When the frig defrosts, the defrost heater stays on until the defrost thermostat gets warm. It should be open circuit while warm. But if it is open circuit while cold, it is bad and is the cause of your defrost problem.
If you open up the freezer coils, use a hair dryer to defrost. That is safer than hot water.
Hope you can fix it.
Aug 01, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Have 16 yr old Kenmore model 106.9537622. The heater strip at the center divider between freezer and frig gets real hot for a period of time everyday and causing frig and freezer to be too warm. The...
if this is a side by side refrigerator, then the space between the doors is not heated by an electric heater. it is heated by part of the condensing coil. so the excess heat is probably generated by a loss of adequate airflow under the machine. which would explain the temperature change in the refrigerator.
  • clean the coils under the machine and make sure the fan is working.
  • make sure the airflow is not obstructed in any way.
if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
Aug 01, 2008 | Refrigerators
Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Jul 18, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
