Question about Panasonic PT-AE700U Multimedia Projector
How to rotate Panasonic multimedia projector PT-LB1 screen at 180
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
  • 4234 Answers
SOURCE: cannot access menu screen on Panasonic PT-D3500U projector
If memory serves me correctly, there is an OSD button on the projector itself. Press that once. You may have turned off the OnScreen Display feature. If that fails to resolve the problem, please let me know and I'll look up your specific model.
Dan
Posted on May 28, 2008
SOURCE: Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Posted on Jan 04, 2009
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
keithd2704
  • 56 Answers
SOURCE: Bluish image appearing on screens
It sounds like the projection lamp is beginning to show its age. How many hours of use does the unit have on the bulb? The bulb are typically rated for about 800-1600 hours of use before they go bad. The bluish image on the screen image is a typical tell-tale sign that the bulb is going to need replacing.
Most of your better projection units will have an internal time counter of the bulb life from the time the unit is first used or when a bulb is replaced. Check to see if your unit has this feature, if so it will show you on the screen display what is the total number of hours on the bulb and the estimated remaining hours of life.
Be aware that the replacement bulbs are NOT cheap and usually will cost you several hundred dollars, I have seen bulbs for professional projection units used for large convention/presentations have bulbs costing as much as $500.00 USD.
One other last thing to check is to clean the lens of the unit both inside and outside. To clean the inside, you will need to remove the bulb (be sure to wear a rubber glove as the oils from your skin will cause the lamp to blow, (causes a hot spot)). Then using a cleaning wipe, just as one used for cleaning microscopes or glasses, wipe the lenses. The discoloration might also being caused by dirt and oils on the lenses.
I hope this shed some light on your church's projection problem.
Posted on Sep 19, 2009
Testimonial: "I was hoping that it would not be a bulb issue. I do not know at this point how much age is on the bulbs, but I am going to check tomorrow. "
I have a Panasonic PT-LM2U; when it is turned on, everything powers up fine but the image projected is upside down. I've looked through the menu but didn't see an option for flipping or rotating...
Every modern projector that I have seen has a setting that will allow you to flip the image for this.If you purchased it used it was probably configured as a ceiling mount in an upside down orientation or rear projection onto a translucent screen. (The projection method can be set from the "OPTION2" menu. in a Model LM1 so it should be similar. http://service.us.panasonic.com/OPERMANPDF/PTLM1U.PDF
If yours doesn't have this option, then you'll have to use mounts that require the projector to be upside down.
Jul 18, 2011 | Panasonic PT-LM2U Multimedia Projector
Just replaced bulb and Lamp red light still comes on when you plug in the Panasonic PT-LB1OU lcd projector. Screen display states: Replace Bulb
Replace power board: ETXMM519MBGB
Or replace transistor Q107 on this board with a typical pnp for switching power supllies,there's not a part number for it on the manual.
Dec 15, 2009 | Panasonic PT-LB10U Multimedia Projector
PT L711U + all my black colors are blue
Your projector needs to be aligned and serviced, normal occurrence
after 6 years since service.
Apr 18, 2009 | Panasonic PT L711U Multimedia Projector
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Cannot access menu screen on Panasonic PT-D3500U projector
Dan
May 28, 2008 | Panasonic PT-D3500U Multimedia Projector
Mustang projector mount required mounting projector upside down...
You may have figured it out by now... From the remote, you go into the menu and find the setting "Display Image" and the option is "Ceiling".
Dec 26, 2007 | Panasonic PT-AE700U Multimedia Projector
Panasonic PT-AE700U Multimedia Projector Logo
44 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
