Question about Pool & Spa
Why does ht ps-01 pump control not switch off automaticly
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Parking aid control module,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Data bus on board diagnostic interface
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Dual tone horn relay
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Radio/navigation display unit control module
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Hope this helps
--N
May 31, 2014 | 2010 Volkswagen Jetta
How do I get top off to clear Paper Jam on Fellowes PS-12Cs
FELLOWES SHREDDER
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the wastebasket; insert wastebasket and repeat jam clearing procedure.
May 23, 2014 | Fellowes Powershred PS-12Cs, 12 Sheet...
I installed the RTH 7400D thermostat according to wire direction for heat pump. I have wires C,G,Y,O,R,L AND THE L IS JUMPED TO AUX. THE BLOWER COMES ON BUT AFTER THE ROOM GET TO TEMPETURE THE UNIT SHUT...
did you set dip switchs on new stat for ht pump with electric ht back up if that is your type of heat. newer t stats might not have dip switchs but a sequence of programing steps to set up new stat to match your needs ps when set up correctly the fan will run for a few minutes after cycle over to discharge residual heat from unit n ducts .
Nov 04, 2013 | Heating & Cooling
How to connect a generic controller to a ps3
All you need to do is this,
Switch on the controller by pressing the ps button and then switch on the ps3 console.
It should sync up automatically.
Hope this helped you?
Dec 25, 2010 | Sony PlayStation 3 40GB System
Remote control failure with Onkyo HT-SR800
If you have several audio/video devices, which is probably the case if you have this system, you might consider buying a Logitech Harmony All in One remote.
I got one as a present - it now controls all my devices intelligently and is fully programmable to switch all boxes to the correct settings for a particular activity with one button. It connects to a pc with a simple but sophisticated GUI to set up, and codes for hundreds of devices are available and automatically downloaded.
Brilliant, and my wife can now use our systems without having to ask me what to do! It even has an on screen help function.
Jan 22, 2010 | Onkyo HT-SR800 System
My Samsung Home theatre shuts down automatically after working for around 30minutes. After 15minutes if I switch on works for 30minutes & shuts down again. When shutting down there is a disply PROTECTION.
sorry to telll you this mate, but i bought a samsung ht-tz 312 at
chrismas and that had the same problem,
only mine would switch its self off after about five mins
i took mine back and they swaped it saying it was a design fault
ps mine did this from new sjr2009@hotmail.co.uk
Apr 29, 2009 | Samsung HT-Z310T Theater System
Need region free codes
You can try this one it worked on my home threater system
  • Power On with empty tray (No Disc will be displayed in the DVD control panel)
  • Press the Enter button on your remote control
  • Press the buttons 8, 4, 2, 6, 9 and Enter button on your remote control
  • Tray will Open automatically
  • Close the tray on the DVD player
  • After 15 seconds have elapsed, power Off your player (switch the unit to stand-by mode) and then power On your player
  • Finished and ready to play all regions
hope this helps
Little Dish Fitter
Apr 20, 2009 | Samsung HT-TX72 Theater System
Euro codes
The new codes for 54 01
10/1/09
E7 D3 69 2E 6F 38 EA 78
E8 C9 E5 6E B0 49 53 F5
Enjoy ps Tottenham for the cup
Jan 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Hi does anyone have codes for eurovox max virgin west mids 09/01/09
Hope this helps
Chris (ziraffa)
ps tw codes for virgin
ps Remember to rate this solution as Fixya!
Jan 09, 2009 | StarTech.com StarView SV211K 2-port KVM...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
