Question about Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag
The power indication display is flashing with all colors visible.
There is no response from the joy stick. The chair was charged when the display went goofy. I plugged it up for a re-charge and still no difference. When the power button is pressed the display flashed continuously.
  • 175 Answers
The flashing will come on if the chair is in neutral or if the charger is still plugged in when you turn it on. Place the chair in neutral (freewheel) by shifting the levers out, then place firmly back into drive.
Unplug from the charger and it should fire up. Sometimes, the chair will also go into "sleep mode".
Check your owners manual for this. Note, some have sleep mode potential but it's not in the manual, and if someone inadvertantly hits the right series of motions with the joystick, you can inadvertantly put it to sleep. Try turning the chair off, wait three seconds and power back up, then immediately press the "horn" button. This wakes up most of them. Others you need to power off, turn back on and then move the joystick forward, backward then forward again.
Good luck
Posted on Jul 07, 2009
I had need to move the chair without turning the chair on so I released the levers that engage the wheels. That caused the display to flash wildly when the power button was pressed. Engaged the wheels and the display and Joy stick are fine!
Posted on Jun 24, 2009
Chair has 7 lights does not respond to joy stick ,new batts full charge, bought new joy stick no lights does not turn on at all help help iam lost
hi Dennis, i can help you but i need more info, firstly the name and model of the powerchair ?
Regards
Rob
Oct 23, 2015 | Health & Beauty
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
I have a metro 500 and it is about 14Yrs old i never had a problem. After i put the new batterys some thing went wrong with the cnnector cable . My batterys are fully charge but on the joy stick within 15...
loose connection on battery? if new batts then you must charge them for a full 24 - 48 hours before using. but posts must be tight. they never fully charged if connections were loose to start check all connections on chair
Oct 27, 2012 | Everest & Jennings Health & Beauty
Lights scroll from lt to rt ant lights around joy stick flash fsta when joy stick is moved forward but the chair will not move
The lights indicate you are in charge mode or inhibit. Check to make sure the charger isn't plugged in. If it isn't then the inhibit function of the chair is bad and will have to be repaired Hope this helped
Apr 15, 2011 | Pride Mobility Products Quantum Jazzy 500...
I had not used the chair in 2 months, when i charged the battery in my electric wheelchair, the lights near the top of the joy stick shows its fully charge, but when i unplug the cord, it go's...
Yep It sure does Why didn't you charge the chair for 2 months? Charge at least once a week if you don't use it daily. Always break in the new batteries by using the chair daily for 10-15 days charging everynite then charge once a week if it sits for that long without use. Always put up fully charged. Do this and your batteries should last 3 -4 years Charge overnite if you use daily and never charge more than 24 hours Good Luck
Nov 15, 2010 | Electric Jazzy 1115 Power Wheelchair
Does my Hoveround need to be on or off when I plug it into the battery? Does it need to be on so that the lights show up on the joy stick or do you turn the chair completely off and then plug in the...
Either way will work when charging the batteries and it wion't hurt the chair either way. If you can stand to have the lights scrolling all night when you charge the chair then leave it on If not turn the power off Your charger will tell you when its finished by turning the yellow light green. Hope this helps
Nov 11, 2010 | NRS Hoveround MPV 5 - Used Power...
Just bought sed Jazzy Select for my wife. Chair appears relatively new. No leakage or corrosion on batteries. Charger indicates full charge but within two minutes of operation both green lights on joy...
Yep you have a weak or bad battery. Even tho the chair looks new if they didn't take care of the batteries ie: charge regularly then the batteries went bad just sitting. I would check in your area for a battery warehouse or store that can get you 2 new batteries at a reasonable price. If there is an Interstate battery distributor or store near you the get your batteries there. Your Select uses 2 U1 batteries. Check out my tips on charging your batteries once you have the new ones put in. Hope this helps
Oct 24, 2010 | Pride Mobility Products Jazzy Select
The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Mar 12, 2009 | Jet Health & Beauty
Electric Mobility Power Electric Scooter Power Wheel Chair Safety Flag Logo
482 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
