Sonysa-wmsp1 subwoofer manual
Remove front panel instructions
What cord do I need to hook subwoofer up
You need the power cord that should already be attached, plus a single RCA patch cord to connect to your source. You could use just one of a typical RCA pair, if that's all you have.
Nov 18, 2013 | Sony SA-WMSP1 Subwoofer Speaker
Replace subwoofer 2001 chevrolet suburban
Should be a standard 8" sub, located in the passenger rear side. Remove the plastic interior body panel, the sub will be located behind. Remove the 6-or-so screws holding it in, disconnect the wires, making note of which wire connected to which terminal. Connect the wires to the new subwoofer, replace screws in new sub. Test the audio system to make sure everything is working properly, and re-install the plastic interior cover panel.
Jan 06, 2013 | 2001 Chevrolet Suburban
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
My Sony model SS-MSP1 , SA-WMSP1 , AC120V , 60HZ , 50W hums.
If it hums on the audio side on all channels it might be the 60hz mains hum getting through. This is caused by the failure of the large Electrolytic capacitors in the power supply.
Another cause of hum (not in the audio) is the transformer. Also parts that hum should be replaced. If you can't pin down a huming part IE where it is. Then use a drinking straw as a stethoscope, by putting one end in your ear and the other over the PC board.
Feb 14, 2010 | Sony Audio Players & Recorders
The required fuse is 1.6 A / 125V an is blown, I wen to radio shack and bought a 1.6A/250V and it has blown 2 already, what can I do or check to fix it? This is a Sony Sub-woofer model sa-wmsp1.
If power transformer T1 got shorted or its output voltage got shorted for some reason, fuse will blow in Sony SA-WMSP1 active subwoofer.
Check power transformer, D401 bridge rectifiers and IC301 power amplifier out chip. Any of them is bad.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | JBL PSW-D110 Speaker
When i play cds on my SonySA-VA100 system the song skips
you need to remove the lid/cover expose the laser diode use a cotton bud wipe it clean,is this your only cd player in the house? and unstable mains power coming in can cause odd things to happen with cd's. the other thing is to add some lub to the motor that drives the cd spindle,again if this does not get up to speed it wont play properly.
Jan 06, 2010 | Sony SA-VA100 System
Can't Remove the Subwoofer from the factory Enclosure.
i would get a reprint from the ford service manual,before bending the subwoofer frame.it will only cost a couple bucks and expose the dark secrets that ford come up with
Jul 03, 2009 | 2001 Ford Explorer
I am looking for a diagram or picture as to how to get to the speakers to replace them on a 97 villager??
Section 15-03: Speakers 1997 Villager Workshop Manual DESCRIPTION AND OPERATION Radio Speakers All vehicle sound systems are equipped with radio speakers (18808) located at all four corners of the vehicle. The radio speakers are mounted in the RH front door (20124) and LH front door (20125), as well as behind the quarter trim panels (31012) in the rear of the vehicle. The Ford Super Sound Audio System has the addition of a subwoofer mounted in the RH quarter trim panel.
Radio Speakers, Front Door Removal
  1. Remove the front door trim panel (23942). Refer to Section 01-05 .
Trim Panel(s), Door Front
Removal
  1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
  2. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
    Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
  3. Remove the three cover caps and front door trim panel screws.
  1. Remove the one front door trim panel capped screw from the door pull handle.
  2. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
  3. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
  4. Remove the front door trim panel.
Door Electrical Connections
Removal and Installation
Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
Removal
  1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
  1. Remove the front door watershield by carefully detaching it from the adhesive.
  1. Remove the four front door radio speaker screws.
May 20, 2009 | 1997 Mercury Villager
I need to know if my pioneer dehp4900ib has a detachable faceplate
Hello tvan71,
Yes, the front panel is detachable.
The following removal and installation instructions are on page 6 of your manual. 1) Press OPEN to open the front panel. 2) Grip the left side of the panel and pull it gently outward. Take care not to grip it too tightly or to drop the front panel and protect it from contact with water and other fluids to prevent permanent damage. 3) Replace the front panel by holding it upright to the unit and clipping it securely into the mounting hooks.
Hope this helps. If it does, please rate as "FixYa".
Apr 24, 2009 | Car Audio & Video
How to conect my ipod to car stereo KDC-MP205
Here's a link to the instruction manual -->LINK<-- .
It goes into detail to setup the aux input.
Plug iPod into front 3.5mm jack on front and follow the setup instructions.
Regards
Philip
Jul 22, 2008 | Kenwood Car Audio & Video
27 people viewed this question
 Grubhead
Grubhead
