Water won`t stop filling tub - Washing Machines
  • 25 Answers
If it's still filling when machine is switched off then water valve needs replacing.if it only overfills when machine is running the pressure pot could be blocked or the hose to the pressure switch could be split or the pressure switch might need replacing
Posted on Jun 24, 2009
Water will not stop filling up the tube
IF YOU MEAN YOUR TUB WON T QUIT FILLING THE WATER LEVEL SWITCH HAS A TUBE ON IT ITS IN THE CONTROL PANEL THE SMALL HOSE IS PROBABLY OFF THE SWITCH AND IT CANNOT TELL THE TUB IS FULL
Jun 19, 2014 | Frigidaire FWS1339A Top Load Washer
Machine keeps filling up, replace pressure switch, still nohting, keeps filling up?
Hello dwl770 - If your washer won't stop filling up with water and overflows the tub, check for one of these problems:
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off and on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
2) There could be a problem with the water level switch. Call in a professional.
3) There is a pressure switch hose that is attached to an air dome. This switch tells the washer that there is water in the tub and allows the agitator to start.
- Remove the control panel and you will notice a small hose. See if it popped off of the air dome. If it did, secure it with a zip tie.
If water flow continues, but drains out immediately, then raise the drain hose above the highest water level line of the tub. Do not seal the drain hose to the discharge pipe. This could cause a siphoning action.
Sep 30, 2012 | Frigidaire FEX831CS Top Load Stacked...
1) Turn off the electricity to the washer. If the water *stopped* filling when power was disconnected, the problem would usually be in the control system of the machine. If the water still continues, then the plunger in the water valve is either stuck open or slow to close. Try turning the water faucets off an on a few times. This small joltmight unstick the water valve. If not, it will need replacing.
The water won't stop filling up the tub causing it to over flow.
it could be the pressure chamber is blocked up with old hard soap or the pressure switch is jamed
May 28, 2012 | Maytag Neptune FAV6800AW Top Load Washer
My washer won't stop filling with water
either the pressure hose is plugged with debris from the base of the tub up to the pressure switch or the pressure switch in the upper side area or behind the control panel is bad,follow this small hose from the tub base pressure dome up to a round shaped plastic component usually about 3" diameter,this is your pressure switch,when its filling remove this hose off the tub and blow into the end of the hose off the tub,if the switch is good you will hear a click and the water will stop and the machine will start,then you know hose is blocked
May 11, 2012 | Hotpoint Washing Machines
My Whirlpool washer fills up but won't stop poring into the washer. Is this something that is repairable?
Your water level switch could be defective. This switch has a plastic 1/4 hose connected from your tub to the switch. (should be easy to find.) Make sure this hose is connected to your tub and switch and the line has no holes. It is easy to test the switch by disconnecting the line from the tub and while water is flowing into your washer, Blow into the line. The pressure will stop the water flow. If not, Bad level switch.
Level switch part# W10339333
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Whirlpool WTW5100SQ
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
GE Spacemaker Washer/Dryer. Model # DDPI380GAMWH. Water won't stop filling. It continues to fill during all cycles. Fills during agitation. Agitates inproperly. It agitates in short pulses as water...
Thanks for choosing FixYa and welcome. This sounds like a problem with the water level switch in the washer. It controls the amount of water entering the tub. It is probably defective. You may want tomake sure the switch is getting power first by testing the wires with a voltage meter.
Jun 18, 2011 | Washing Machines
Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
May 20, 2011 | Kenmore 24042 Top Load Washer
Water doesn't stop filling tub and tub overflows
the water level sensor is not working and needs to be replaced
Aug 31, 2009 | Washing Machines
Open Questions:
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
