Question about Sony SS-MF600H Speaker
Sony sa-wmsp1 remove front panel instructions
2 Suggested Answers
Grubhead
  • 5151 Answers
SOURCE: My Sony model SS-MSP1 , SA-WMSP1 , AC120V , 60HZ ,
If it hums on the audio side on all channels it might be the 60hz mains hum getting through. This is caused by the failure of the large Electrolytic capacitors in the power supply.
Another cause of hum (not in the audio) is the transformer. Also parts that hum should be replaced. If you can't pin down a huming part IE where it is. Then use a drinking straw as a stethoscope, by putting one end in your ear and the other over the PC board.
Posted on Feb 16, 2010
What cord do I need to hook subwoofer up
You need the power cord that should already be attached, plus a single RCA patch cord to connect to your source. You could use just one of a typical RCA pair, if that's all you have.
Nov 18, 2013 | Sony SA-WMSP1 Subwoofer Speaker
Need manual for sony SA-WMS230
the Sony SA-WM 230 MICRO SATELLITE SYSTEM is also known as Sony SA-VE230. Follow up link for service manual:
http://www.go-gddq.com/upload/2010-04/10041211301999.pdf
Feb 02, 2012 | Sony Audio Players & Recorders
I have a sony sub model sa-wm20 will it work with this mini system
Read the manual.
http://www.retrevo.com/support/Sony-SA-WM20-Subwoofers-manual/id/752ag408/t/2/
You would use the Speaker Terminal hookup option. Your front speakers would attach to the sub's speaker terminals.
May 02, 2011 | Sony MHC-881 Shelf System
I need the wires to conect two speakers sony sa-va100r
Which two speakers?
http://www.retrevo.com/support/Sony-SA-VA100-Speaker-Systems-manual/id/22986ci669/t/2/
The speakers themselves appear to use standard spealer wire with bare ends. Just get a roll of lamp cord at the hardware store and cut it to the length you need.
Between the two front speakers they require a standard RCA stereo audio cable.
http://www.searspartsdirect.com/partsdirect/part-model/Sony-Parts/Audio-equipment-Parts/Model-SAVA500/0996/0311400/50017803/00001
If you're needing the flat cable the link above is a breakdown of the various components. Perhaps you could contact them and describe which 'wire' you need.
Some other possibilities...
1-777-117-11 CORD (WITH CONNECTOR)(15P)
http://www.encompassparts.com/products/?1-691-777-11
http://www.partstore.com/Part/Sony/Sony/175134713/New.aspx?ModelMfgName=Sony&ModelBrandName=Sony&ModelNumber=SAVA100
Feb 01, 2011 | Sony SA-VA100 System
My Sony model SS-MSP1 , SA-WMSP1 , AC120V , 60HZ , 50W hums.
Feb 14, 2010 | Sony Audio Players & Recorders
The required fuse is 1.6 A / 125V an is blown, I wen to radio shack and bought a 1.6A/250V and it has blown 2 already, what can I do or check to fix it? This is a Sony Sub-woofer model sa-wmsp1.
If power transformer T1 got shorted or its output voltage got shorted for some reason, fuse will blow in Sony SA-WMSP1 active subwoofer.
Check power transformer, D401 bridge rectifiers and IC301 power amplifier out chip. Any of them is bad.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | JBL PSW-D110 Speaker
Possible thermal fuse problem.
I too, took off the back of my Sony TV after I started getting red and green shadows (called retrace lines) around words and people; and blew out all the dust inside hoping that would help. Ironically, I discovered that most problems with rear projection TVs are due to a malfunction located in the bottom FRONT panel, accessed by taking off the front speaker panel and then a wooden panel after that to access the circuitry, specifically this little black box with 6 screws on it. Go to www.SomeLifeBlog.com and this site has photos how to take off the front of the tv and instructions how to fix some common problems that repair people will charge you $300-500 to fix. This man, his instructions, photos, and website were a godsend. Good luck.
Jan 11, 2009 | Sony KP-51HW40 51" Rear Projection...
Receiver
My SA-AX710 overloads intermittently. The problem is a broken solder joint between a pin on one of the power transistor modules and the circuit board. To fix it, I removed the circuit board from the case and resolder the borken joint. Opening the case is easy. First remove the top of the case. Then remove the 3 screws in front. The front panel can then be pulled off. After that, remove all screws holding the connectors on the back. The circuit board can be detached from the case by removing the screws from the top of the board. Broken solder joint is probably one of the most common problems with modern electronics.
Mar 03, 2008 | Technics SA-AX710
What's wrong with TV?
how many times does it flash?
i suspect a bad red tube
sony has a recall on the tubes
http://esupport.sony.com/perl/news-item.pl?news_id=24
Dec 29, 2007 | Sony KP-57WV600 57" Rear Projection...
Sony SS-MF600H Speaker Logo
70 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
