Question about Refrigerators
JENN AIR jcd2389ges' SIZE,WEITH?DEPTH?HIGH? - Refrigerators
  • 641 Answers
Here is the site for the specs of that machine.
Jenn Air JCD2389GES
Posted on May 15, 2014
  • 1314 Answers
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Posted on Feb 11, 2008
SOURCE: Jenn Air JCD2389GES ice dispenser problem
my ice maker is not making ice.
Posted on Mar 26, 2008
SOURCE: JennAir #JCD2389GES not cooling refrig at all.
Well guess what. Jenn Air / Maytag now has this issue as a recall. So just call them and tell them the fridge is not cooling. They will schedule a recall service appointment. Do be sure they schedule it as a "recall" service appointment or you will be charged.
That sure beats pulling out the hair dryer every time it happens!
Service number is 1-800-462-9824
Good luck
Posted on Dec 02, 2008
  • 28 Answers
SOURCE: I have jenn-air jcd2389ges - the freeze keeps
It could be a bad defrost timer or a bad thermostat. Both are a cheap fix also, check to see if the condenser coil is clean. If it isn't clean it!
Another possibility if it isn't the T stat or defrost timer, the defrost heaters or overload might be bad.
Posted on Jul 09, 2009
  • 13 Answers
SOURCE: i have a jenn-air jcd2389ges that is not getting c...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
Posted on Jun 03, 2010
How do I find a discontinued part for my Jenn-Air Refrigerator Model # JCD2389GES? I need a specific part # 61005056 (black Escutcheon)
if the line is discontinued, that means NO ONE makes it anymore, sorry but there is no way around this one-buy a new fridge.
Jan 05, 2015 | Jenn-Air Refrigerators
How do i replace the water filter
http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Refrigerator-Parts/Model-JCD2389GES/1266/0165000
Nov 13, 2014 | Jenn-Air Refrigerators
Jcd2389ges where is timer located
http://www.partselect.com/PS2061226-Whirlpool-61005988-Adaptive-Defrost-Timer.htm?SourceCode=1&SearchTerm=JCD2389GES&ModelNum=JCD2389GES gives and idea as to where it is located...it's usually in the plastic housing that the light is sticking out of. hope that helps
Jun 09, 2012 | Jenn-Air Refrigerators
REFRIGERATOR REPAIR MANUAL NEEDED
this web sight (fix-ya ) does offer repair manuels I would try it . as for parts info and prices. it will not be in the service . you can also down load this from the web sight .( service maters) from whirlpool . that now has jen air.. hope this has helped you mm feed back pls ..
Jul 23, 2010 | Jenn-Air JCD2389G Side by Side...
I have a jenn-air jcd2389ges that is not getting cold.it runs and works but is not getting cold ..
May 20, 2010 | Jenn-Air JCD2389G Side by Side...
Jenn air jcd2389ges has a sporadic water leak. I suspect that it is occurring during defrost. A clogged line? How do I access this to clean out?
Your plastic lines at the bottom left side of frig have dry rotted from the heat of the compressor. it will leak every time the water comes on to fill the internal tank. I had the same problem and I replaced mine with copper.
Oct 29, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn air jcd2389ges door not closing. My 5 year
it may be no hlp at all
but ive seen this a few times your problem sounds similar
check the soda milk door sometimes that gets jamed and will prevent the door from closing
Oct 08, 2009 | Jenn-Air JCD2389G Side by Side...
JENN-AIR BLOWS WARM AIR
Towards the bottom of the freezer is the water diversion tray for when it defrosts. It is usually made of glass but may not be. Lift that up an see if it is blocked by frozen water ice blocking the cold air vent that recirculates and also feeds into your refrigerator.
If this doesn't help wait long enough and one of the other experts on the site will help you. If it does solve your problem I wouldn't be too surprised as I've seen this so many times.
Well, regards and good luck,
Worldvet
Jun 02, 2008 | Jenn-Air JCB2280HES Side by Side...
Jenn-Air Refrigerator side by side
make sure the two vents inside freezer and refridgerator nside are not blocked....normal range is approx -15 to + 15 in freezer,...and 37-42 in fridge...take temp readings inside of both....a full freezer and fridge retian colder temp more...
Jan 03, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
219 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
