I have a toshiba 2860 copier and it says to close the drawer when it is closed . I have switched the drawers and it says the same thing. How can i bypass the drawer sensor?
  • 135 Answers
Pull the drawer out and look on the back frame in the cavity, more than likely there is a black plastic sensor dangling off the frame hopefully you can reseat this sensor and be on your way
Posted on Aug 05, 2009
Washer is reading ddo. what does that mean?
Hi
Error DDO means dispenser drawer open. This error appears when the washer senses that the dispenser door is not closed. If the dispenser door seems to be closed then it seems to be an issue with the magnet. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch & signals the washer that the drawer is closed. This magnet might have moved from its place and that's why you are getting error DDO. Pull the drawer out and check the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Frigidaire Washing Machines
DVD DRAWER won't open
OK.
I assume the display does not say 'locked' when you press eject.
A DVD drawer is run by a small rubber belt on most of these old machines. This belt can be worn out (Very common)
The DVD drawer position is detected by a switch that can be pressed in or out to detect the drawer is closed or open. This switch can cause the drawer to stay in if it thinks the drawer is not yet closed. Cleaning the switch (Take the DVD drive out and remove and clean or replace the switch) can usually fix this.
A fault with the DVD process cicuit board can also cause this. I would recommend a new machine if this is the case.
Testing:
Bad belt - the DVD drawer shifts a bit when the eject button is pressed.
Bad switch - a whirring sound can always be heard when the DVD is first powered on. May give an error in the display.
Bad process board - Generally, says open forever or close forever and will not change back to normal display. You cannot get any other functions to work after you press eject. Unplug the machine, its normal until you press eject again. (just a generic common thing)
Mar 22, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
Toshiba 2860-changed Toner cartridge-black line on edge of copy
Hi there
send a print / copy through the machine stop the machine via the main switch before toe paper has come out remove the drum unit
you should now be able to see part of your print on the drum if you can also see the black line check for obstructions in the light path if these seem fine the chances are the dev or cleaner blade seals have spung a leak ( time to replace the drum cartridge
Regards Al "alstech"
May 26, 2009 | Toshiba 2860 Copier
CASIO TE2200 Error E010 while drawer is closed
This type of problem is normally caused by a switch. When the drawer opens, the switch closes and the machine goes into 'drawer open' mode to prevent another transaction. The switch or the switch activator has probably failed.
Remove the entire drawer assembly, meaning everything that comes out when the drawer is opened. Use a flashlight and look at the inside rear of the drawer opening to see if you can see the switch. It may be a lever or a button and it may be in line withe the drawer or in may be off to one side. When it is located, try to press on the button or lever. If you can and the machine goes back to 'normal mode' the problem will be identified and you will know that the switch is good. Now you need to locate what actuates the switch to see why it is not making contact. Look on the part of the drawer that should come in contact with the switch. If a small, thin piece of plastic has broken off, tape a small piece of a hard substance in that area. Close the drawer to see if the 'open' message goes away. If id does not, try a thicker piece. Repeat until the 'open' message goes away. When that happens, glue the last piece in place.
If the 'open' message does not go away when the button or lever is press, it indicates that the switch is bad and needs to be replaced. Most of these switches make contact when the button or lever are not pressed. In the short term you could locate the switch and disconnect one wire. That would simulate the button being pressed. You would just need to remember to not start another transaction until the drawer is closed.
Good luck, and please let me know how it works out.
Feb 22, 2009 | Casio Parts Cash Register PC Desktop
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
''place paper in drawer''
Sounds like a paper sensor ; A little black arm that senses paper tray is full, when the tray lifts into position. You might pull the tray and with a flashlight look for any broken parts. I have seen these break when paper jams are removed. This is a Toshiba 2860 correct?
Nov 18, 2008 | Office Equipment & Supplies
Cannot close middle front drawer
you have to take off the left side cover and you see 2 gears close to the middle of printer, those have to be turned to release the clutch for the drawer. The drawer should now slide in.
Nov 18, 2008 | HP Color LaserJet 4500n Printer
Canon printer error 073
The transfer drawer connector or the transfer frame drawer connector is not connected as the front door is closed.
Nov 04, 2008 | Canon imageCLASS 1100 Laser Printer
Nuvera 100 CP
Don't know the model, but, most fuser drawers have a "home" switch behind the fuser assembly either on the rear frame or the rail, not usually on the fuser itself
Jul 21, 2008 | Xerox Office Equipment & Supplies
52 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
