Question about Panasonic Heating & Cooling
My Panasonic AC outdoor unit has to be opened and cleaned frequently as a squirrel enters it and load lots of grass, cloth etc. Any remedy?
  • 164 Answers
How about putting a mesh to surround it?
Posted on May 15, 2014
Testimonial: "Is there a mesh available for such a use?"
bobotfel
  • 236 Answers
SOURCE: heat/ac pump
- If it is a high wall unit yep under charge refrigerant is one of the cause.
- Out of range thermistor is also can also be the cause of tripping outdoor unit with matching blinking light same as low refrigerant.
- Dirty indoor and outdoor can also be the cause
HOW TO CHECK IF YOUR UNIT IS OUT OF FREON
- If your indoor and outdoor is clean start the unit in cool mode and monitor the outdoor pipes. If your suction pipe is icing or dry then your unit is under charge, but if your suction is cold and sweating then the system is ok and sure that the thermistor sensor is defective.
Posted on Jan 08, 2008
bobicehouse
  • 1524 Answers
SOURCE: I am looking for the outdoor AC unit wireing
Atta way.
Posted on Apr 27, 2009
caroldon
  • 17129 Answers
SOURCE: outdoor unit on of my
If this is an old unit is is possible that the compressor is vibrating with the load. check and see if the mounting bushes and the foundation is tight and clamped properly. If not the unit must be removed and plugged well into a good foundation. Also check the mounting bushes of the compressor , If this wont solve there is fault within the compressor , possible low lubrication that make it vibrate which might require a consensus and estimate.-- specially if the cooling is going down.
Posted on Aug 22, 2011
  • 884 Answers
SOURCE: hyundai 24000'btu ac outdoor unit con moter wirig what runing'starting'comon
Three pins Common is neutral. Start is start from relay, Run is run from relay Usually Common at top, Start bottom left, Run bottom right but check a manual if you can find one.
Posted on May 18, 2012
jishatitus20
SOURCE: the outdoor unit doesnt work
out door unit not working how much volt is coming contact voltage
Posted on May 25, 2012
With some loads even very light ones the dryer stops and must be rest every 5 min or so
This is usually caused by a thermal fuse. There are several through out the dryer to ensure it doesn't overheat/cause a fire/damage clothes/ damage parts. Some are a one time fuse and requires repair to get it working again. Since it does come back on after a few minutes, it is probably the thermal breaker on the exhaust line out of the dryer and can usually be fixed by a thorough cleaning of the lint trap to the exhaust ouput, usually outdoors. If this doesn't work, a partial disassemble and deep cleaning of heating elements, squirrel cage, motor etc. I can seem intimidating but not too hard if you take pictures as you disassemble. Don't forget to disconnect the power/turn off the gas.
Aug 17, 2015 | Dryers
Wall AC Unit blows cold air for a little bit then blows hot air. If I turn it off for a while, it will do the same thing.
When you mansion water in the pan, do you mean the indoor coil pan or the outdoor catch "pan"? I've seen some models have a drain plug that's on the bottom of the outdoor panel or underneath. And that plug should remain installed. It uses that water to cool the copper freon tube that curves along the bottom of the outdoor section. With plug removed it can overheat. Basically it does not drain onto the ground outside, it retains its water. And the air entering side of outdoor coil is clean? May sound like repetition(forgive me). The side you see clearly is the air leaving side. The dual shaft motor has a run capacitor that may be weakening. And the outdoor air that passes thru the outdoor coil may be recirculating out then directly back in to the unit causing it to overheat. Anything blocking airflow outside? 10 mins of runtime then shouting down tells me its overheating. It may even be the electrical circuit. Loose connections can cause high amperage, low voltage issue and cause the ac load to over amp. Over amp=over heat. Hope this helps!
Jun 27, 2015 | LG LWHD1800R Wall/Window Air Conditioner
After turning the AC unit on roughly 10-15mins. outdoor unit turns off head unit still on
It sound like you have problem with compressor overheated. Make sure your is clean and correct amount of freon
Nov 06, 2013 | Fujitsu 18C1 Air Conditioner
Lg ac shaking violently when turned on
Sounds like your fan motor is coming loose from the mounts or your squirrel cage is loose or loosening. That's just the air handler, the compressor is outdoors in the condensing unit. Pull that air handler apart and find out what's causing it, or shut it down. This can hurt you if the fan flies out of there.
Aug 21, 2013 | Heating & Cooling
Why does my ac freeze up
Hello, air conditioners will freeze either due to low airflow.....such as dirty filter, dirty evaporator coil, weak or not running blower motor. Also, a low refrigerant charge can cause the unit to freeze up.
Jul 09, 2012 | Danby Heating & Cooling
AC Starts normally but after some time of coolinf compressor in outdoor unit trips. Compressor running light in indoor unit remains on and outdoor unit fan remains on. But no cooling. After a break of...
Probably overheating. Check the outdoor coil and see if it is stopped up with dust, grass etc. If so, disconnect power to the unit, and clean the condenser coil with water or air. Be careful not to bend the fins if you use a water sprayer.
Apr 11, 2011 | LG Heating & Cooling
Maytag dryer isnt as hot as normal
HI I am not an expert but we had the same problem once. It may be that the tube which air flows through to the vented portion has a blockage, of lint ( a lot of it) enought to clog the airflow which is not allowing the unit to dry your clothes in one load. Check both ends of the coiling and the outside vent. good luck
Dec 20, 2008 | Maytag SDE3606A Electric Dryer
Heat/ac pump
Jan 08, 2008 | Heating & Cooling
Heating & Cooling Logo
75 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
