Question about Ovens
Wiring Diagram for AEG Build-in Electric Oven B2.6L
I've an old AEG Electric Oven B2.6L and its just stopped working. Theres power getting to it but nothing happens when you turn it on at all. The fuses are OK and nothing appears to have burnt out. Just whatever setting you have it on - oven, fan oven, grill, any of them nothing happens. How do I get a wiring diagram to sort out whats wrong??
  • Anonymous Mar 13, 2014
    Main oven light does not work but same lamp is OK when placed in the grill oven. Oven model is D4701-4-M 944171272
Can i use 13amp socket for a electric oven
Posted on Oct 25, 2008
You can as a get you by thing but if you look at the main fuse for the oven you will see it is a 30 amp fuse
Posted on Dec 31, 2012
Aeg competence d8800 5
Electronic component failure. As only 5 years old then worth calling a Service Engineer.
Sep 18, 2017 | Ovens
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Dec 31, 2009 | Stoves 720EF Electric Double Oven
My bottom oven is not heating up?
If it is an all electric fan assisted oven, and the fan is working o/k, then the oven element has probably failed.
This is located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Dec 09, 2009 | AEG Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
AEG double oven- fan assisted not heating up
you oven element has failed.
it is located at the back of most electric ovens sometimes at the top,,
the insulation of the element has failed and when you come to remove it you will see visually see the damage... its easy to replace as there are only wires attached to it and only a few screws to undue to get to it..
hope this helps cheers
the washdoctor
Aug 24, 2008 | AEG B2100-4 Electric Single Oven
Oven cuts out after ten minutes and comes back after cooling down.
We have the same problem with our oven, AEG B2190-1.It started on on Christmas day[worst day of year]gets up to temperature after 10-15 minutes cuts out everything switches off until the oven has cooled down, The oven is only 18 months old. We have been told that it is a thermostat problem.
Dec 10, 2006 | AEG B2100-4 Electric Single Oven
B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Nov 21, 2006 | AEG B3101-4 Electric Single Oven
Ovens Logo
1,600 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
