Question about Vacuums
Why does my vax rapide not turn on?
My vax rapide does not turn on
    Problem Solver:
  • 27 Answers
The only easy answer would be a bad connection at the plugin receptacle, a bad receptacle, open circuit-breaker or fuse at your electrical panel. Assuming these have all been verified as working
(check by plugging it into a different circuit in the house. If it works then the problem is at the original receptacle and not the vacuum). Then the electrical wiring and components of the vacuum must be checked. This is normally done by a qualified serviceman.
There is no rest button that I am aware of. Make sure the switch is pressed on firmly. The most common problem is a faulty switch, however there are several other possibilities. The vacuum has a simple overload switch that turns off when it is overloaded. Once it has cooled, it will close in again allowing it to work again. This could fail open but it is rare unless it has operated many times previous to not starting now. A more common problem is a broken or open wire. This usually happens at connections and may be burnt open because of a loose connection. Sometimes the start switch on the motor fails or the motor itself fails. Unless you are knowledgeable with working on electrical circuitry the repair should be done by a qualified repairman.
Posted on May 15, 2014
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Vax rapid ultra brushes not turning
Dear Sir:
1) Test the power cord for defective wires, broker,or loose repair
2) Test the switch for open see the diagram
3) See if there are some open fuse.
4) See if the belt is broken, replace.
5)Test the input voltage motor.
God bless you
Posted on May 27, 2012
I need a manual for Vax rapide plus 5130 can you help thank you
Try Googling (vax)(5130)(manual) without parens.
May 12, 2017 | Vax Vacuums
Vax rapide
I brought a rapide ultra carpet washer today , cleaned half of my front room brilliant then stopped spraying water using the trigger on the handle, as the handle comes off for easy storage I took it off, and what\'s happing is when you pull the trigger to release water a piece of plastic pushes on another piece ov plastic to release water and it was not working only by me pushing my finger on the other piece of plastic in side the handle bit, so mines going back ,
Aug 14, 2013 | Vacuums
My vax rapide xl ultimate v-027y brushes not working..new belt fitted and same problem
hello i have a vax rarid xl carpet cleaner when you switch power on just makes a buzzing noise can you help thanks
Jul 15, 2012 | VAX Appliances Vacuums
Dear Sir:
God bless you
May 26, 2012 | VAX Appliances Agilty V123 Upright Wet...
I need an instruction manual for a Vax Rapide Classic carpet cleaner
i have recently been given a vax rapid deluxe unfortunatley it didnt come with the manual.my problem is the water isnt coming out ? please help
Sep 11, 2010 | Vacuums
I need a user manual for a vax rapide deluxe v-026
Hello robin143, the user guide is available here: http://www.vax.co.uk/downloads/pdf/VaxGuideNo22a.pdf
If you need further help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
May 12, 2010 | Vacuums
I was using my vax rapide washer earlier and it blew my trip however noticed that the filter is disintergrating do you think this can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553164
Generic problem for all Vacuums
I was using my vax
Posted by paulxlyn on Apr 28, 2008
I was using my vax rapide washer earlier and it blew my trip however noticed that the filter is disintegrating do you think this can be repaired?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can contact your local vacuum cleaner dealer and if they don’t carry the Vax Model then feel free to contact the Vax Rapide Factory Manufacturer phone number or the website for further information and to order parts if needed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.vaxusa.com/
If you have specific questions and you can't find the answer you’re looking for here, please call our Customer Service Department at 877.894.2031
M-F 8AM-7PM EST or check out our Contact Us page for more information.
Thanks, Don – The Vac Man
Apr 28, 2008 | Vacuums
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits doyou think it can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553160
I have a Vax Rapide
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits do you think it can be repaired?
Go Ahead. Use Us.
Vacuums Logo
71 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
