Question about Venturer Audio Players & Recorders
HOW DO i get am/fm on tongtel ipod dock mw1256
I want to connect my ipod to the radio
According to Apple, over 90 percent of new cars retailed in the United States are equipped with iPod connectivity.
The iPod has become such a popular device, that many car stereos are now furnished with a 30-pin dock connector cable in order to link to the portable media player.
But this built-in compatibility is not essential for connecting your iPod to your car stereo. In fact, there are numerous options for integrating your iPod with your car.
Recently manufactured vehicles can support an iPod connection through an auxiliary input.
And FM transmitters can be used to stream your iPod's audio files through an FM frequency. iPods can even be connected to much older car stereos with the use of a tape adapter.
Connect an iPod to a Car Stereo Through the Auxiliary Input
Insert an extension cable with 3.5 mm stereo connectors on each end into the headphone output of your iPod. Insert the other end of the 3.5 mm stereo connector cable into your car stereo system's auxiliary input. Press the "Aux" button on your car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With an FM Transmitter Insert the FM transmitter into the 30-pin dock connector of your iPod. Turn on your iPod to activate the FM transmitter. Select the FM frequency you want your device to stream audio to on your car stereo. Turn on the car stereo and tune it to the same FM frequency as the FM transmitter attached to your iPod. The stereo will now stream audio from your iPod. b> Connect an iPod to a Car Stereo With a Cassette Adapter Plug the jack connector of the cassette adapter into the headphone output of your iPod. Insert the cassette into the car stereo. Turn on your iPod and select media to play. The stereo will now stream audio from your iPod.
http://www.apple.com/ipod/car-integration/ http://www.pcmag.com/article2/0,2817,1865467,00.asp
Feb 10, 2013 | Apple iPod Audio Players & Recorders
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
Ipod will play on tunebase fm but it won't charge it
There are issues with newer ipods not being 100%compatible with all devices. It is done intentionally by Apple to maximize their profits. For example, an FM transmitter charges and plays on one Ipod, but then a newer ipod will play with the FM transmitter, but the ipod display shows that it is incompatible and will not charge. Same issues with a docking station and a radio. All worked with three other ipods, but the newer ones either won't work or charge depending on the device. Even though ipods play with certain devices they may not charge them and vice versa. Thank Apple for that. I hope this helps and good luck!
Feb 02, 2010 | Audiovox Jensen Universal iPod Docking...
IPod beeps continuously while docked.
I had the same issue with my iPod. It might be because your not using the correct size holder for whatever iPod type you have. Or this could be an indication that the speakers are wearing out.
Jan 01, 2010 | Apple iLive IBCD3816DT Portable 2.1...
The ipod dock station on my i home is loose.
i have the same problem i think when ihad my ipod in it i hit my ipod whic bent it and now it only works if i bend my ipod like tilt it and put something inbetween to keep it there... now its only getting worse...
Aug 30, 2009 | SDI iHome iH5 Docking Station, FM...
Cannot lower volume on ipod or am/fm radio
Returned it...I called the manufacturer, they said its defective,return it.
Jan 16, 2009 | GPX iLive IB-R2807DPBLK Portable Music...
Ipod reads: charging not supported
Until recently, iPods could charge by either USB or Firewire. Each has a different power requirement. Many third-party docks and chargers power the dock connect with electricity that meets the Firewire spec, not the USB one. The newer iPods and the iPhone only can charge by USB. Thus if you use a firewire based charger, you get the "not supported" note. I thinkthat's what is happening to you.
Dec 26, 2008 | Emerson iP105BK Shuffel Docking Station...
Ipod wont work
The problem is "ipod dock receiver connector"(connector is fuck), move forward and backwards the ipod just point the ipod can play the songs..
try you!
Dec 25, 2007 | Apple iLive IBCD3816DT Portable 2.1...
42 people viewed this question
Top Venturer Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
