Question about Ricoh Aficio 2016 All-In-One Laser Printer
How to clear error code sc551 on gestetner dsm615
2 Suggested Answers
  • 1297 Answers
SOURCE: our Gestetner MP 2000Le have an error sc551 and we can't troubleshoot it using the (Clear mode+107+hold the Clear/stop button) ..can you pls. advice us for other options ? tnx
Enter in the service mode: Clear(yellow key) 107 press/hold Clear/Stop more 4 second,enter in the SP mode open the front cover ,turn OFF the copier,wait 1-2 minutes close the front cover and turn ON the copier.
Posted on Jan 30, 2013
I have a nashuatec dsm615 with a error code sc541.please tell me how to reset this code .thank you
Resetting a machine may cause damage on the costly internal parts inside. The cpu has an ability to detect error codes and what type of error it is on the machine but resetting it will only "FORGET" what has been currently detected but still the problem exists on the machine even it is successfully done. If you will continously use the machine that has been resetted, therefore a possible simple problem can cost serious damage. Just a reminder before resetting. Thanks for using Fixya.
Aug 05, 2013 | Gestetner DSm615 Digital Imaging System
Our Gestetner MP 2000Le have an error sc551 and we can't troubleshoot it using the (Clear mode+107+hold the Clear/stop button) ..can you pls. advice us for other options ? tnx
Jan 30, 2013 | Ricoh Aficio MP 2000 Black and White...
What is the repair code of nashuatec dsm615?
please tell me what is your code in this machine -thanks
Dec 22, 2010 | Gestetner DSm615 Digital Imaging System
Error sc:544
Hi
SC544 error means Fuser Overheat Error 1 (Hardware). This has happened due to Fuser Low Temperature which occurs due to Abnormal Hot Roller Fusing Lamp Lower Limit Temperature Detected. Try turning off & unplugging the copier for 10-20 minutes to check if error code resets. If it doesn
Oct 09, 2010 | Gestetner DSm615 Digital Imaging System
Gestetner Dms615 driver
Sir try this site
http://www.nrgcss.com/drivers/Page1b.Asp?Brand=gest&Usr=&Cat=3&ky=1002292416&Fltr=0&Vw=
Mar 12, 2010 | Gestetner DSm615 Digital Imaging System
Cs580 error
Check the exhaust fan motor,and reset the error code by turning OFF the main switch wait 10 sec and turn ON.
Oct 02, 2009 | Gestetner DSm615 Digital Imaging System
Gestetner DSm615 giving error SC:552,How do i clear it
Are you sure of the code? I don't have the exact manual for that, machine but the number seems strange. "5xx" errors are usually related to the fuser, so could be a bad lamp, thermistor, or fuse. see note to reset (if there is not a problem) as follows:
There are 2 levels of service call conditions.
Level Definition Reset Procedure
"A"
To prevent the machine from being
damaged, the SC can only be reset by a
service representative.
The copier cannot be operated at all.
Enter SP 5-810 (SC code reset) and
select “1”. Then hold down the Original
type key and the OK or ! key at the
same time (this does not require the
main switch to be turned off and on).
Feb 02, 2009 | Gestetner DSm615 Digital Imaging System
Hie I have a Gestetner DSm615 which is giving me error code SC:552.How do i solved this problem?
Enter SP mode by pressing;
  • Clear (yellow) button
  • 1 0 7
  • Press and hold the Stop (orange) button for 3 seconds.
  • Switch off and on the machine.
If SC 552 (Fusing warm up error) appears again, possible causes are;
  1. Fusing thermistor defective or out of position or dirty with toner
  2. Fusing lamp open, and
  3. Power supply board defective.
Good luck and please rate me, thanks.
Machine display an error code sc 500
YOU MUST RESET machin by: press clear mode key(yellow)---enter 107 by keyboard----press clear/stop key (red) for4 seconds--- turn off machin and on
Dec 22, 2007 | Gestetner DSm615 Digital Imaging System
Ricoh Aficio 2016 All-In-One Laser Printer Logo
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
