Question about Salter 2001 electronic kitchen scale
The reading on the lcd screen jumps about from one weight to another on my salter 2001 even with new battries, how can i fix it?
Evwn with new battries the reading jumps from one weight to another and wont stablize
kristineluci
  • 30 Answers
SOURCE: Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Posted on Aug 21, 2009
evista_win
  • 10 Answers
SOURCE: my salter 1004SSDR kitchen scale won't show any
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Posted on Sep 10, 2009
SOURCE: E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Posted on Jul 28, 2010
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Posted on Aug 29, 2010
SOURCE: I have a Salter Accu-Glo. I keep getting an error
Here's how I fixed mine. Same model, same EL fault but I cant be sure which of two things fixed the problem. This is what I did:
Turn the scales over so the side you stand on faces the floor. Remove the holding springs on the base of the unit. Keep the unit compressed as you do this.Turn the unit over so it is facing right way up, still keeping it compressed.
Remove the top of the unit to reveal the weighing mechanism and display electronics. I found two faults on mine
#1 the levers had come apart and one side was no longer in contact with the force sensor (EL = element maybe?)
#2 there was some corrosion bridging the tracks on the pcb (green circuit board to the right of the display) (EL = electronics maybe)
Putting the levers back together is a little tricky but if you can do a jigsaw, you can put the parts back together. The only trick I found was to orient the levers at 90 degrees to their normal orientation (i.e. put them on their sides) push them through the gaps in the holding brace then turn them back to be right side up. It was easier to put the center of the levers together first, then mount them properly at each corner.
I scraped off the corrosion on the pcb using a tiny screwdriver and blew off the residue. It seemed to be water or soap and came off easily.
Test it to see if that fixed the problem before you put it together because I found getting the springs back the trickiest part of the job. Test it by pressing the switch on the bottom right foot as you face it it should switch on - do the moving 8 thing, then respond as you apply force to the force sensor.
Putting it back together is the reverse of the removal but this time you should use thin nosed pliers to pull the springs up and over the holding bar.
Posted on Jul 24, 2012
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Sep 12, 2014 | Salter 2001 electronic kitchen scale
My Salter bathroom scales (model 929) are showing an ERR message. They seem to think everything weighs more than it does as if u press gently on them the weight goes up really quickly until limit reached...
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic
tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely?
Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes.
Hello, I just see a online stores
http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
Jul 25, 2011 | Salter Health & Beauty
I have the Salter Scales model 2040, it is currently sent to oz, do you know how to change to grams as there is only 1 button. thanks
I just had a play with mine as I wanted to change the weight mode too.
The solution is this:
While the machine is OFF, press and hold the button for about 5-10 seconds.
The display will go from 8888 to show the weight measurement (lb oz) at the top of the display.
Press the button to select the weight you want.
You should be able to continue with your baking :o)
Hope this helps
Oct 09, 2010 | Salter 2001 electronic kitchen scale
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
My salter 1004SSDR kitchen scale won't show any real weight - just stuck on '5000' which is the max weight in grams, won't switch off, crazy
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Aug 21, 2009 | Salter 2001 electronic kitchen scale
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Salter 2001 electronic kitchen scale Logo
55 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
solver2010
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
