Question about Beko Fridge/freezer Thermostat Genuine 9002752885
How testing cooler birntal thermstat?
We have cooler freez up .why
    President:
  • 2,692 Answers
Thermostat bulb likely lost charge causing it to not turn off. Replace whole thermostat. Bulbs do tn come separately.
Posted on May 15, 2014
Changed thermstat anti-freeze poured out from housing not being tight anti-freeze poured all over motor now it wont start but its turning over
i do have a solution i used but it has to be above freezing. spray the motor down with water it will wash all the antifreeze and stuff away let it dry double check all electrical connections any lose ones check for moisture and shorts. repair any that are messed up then try it.
Feb 12, 2015 | 2000 Chevrolet Blazer
What causes Ice build up on inside back panel of kitchenAide KUWA244PBS?
normally that means yhe defrost thermstat is bad or the heating element that causes the defrost is bad.
Aug 31, 2014 | KitchenAid KUWA244PBS Wine Cooler
My freezer making a loud sound some times the freezer freezes up when'd I defrost it with a hair dryer it deficits but still runs loud
the loud noise is caused by the fan hitting ice..... you have a bad defrost cycle. bad heating element or bad thermstat
Aug 27, 2014 | Refrigerators
Breezair unit freezs up in my wine cooler---- why.
Does it run constantly? If so, an easy test fix is to go to WalMart and buy a timer that cycles in half hour intervals. Play with the on/off settings and see if that stops it from freezing up.
May be the thermostat, which is a fairly easy fix.
May be low on Freon.
Jun 13, 2014 | Haier BC112G Wine Cooler
I have a 1995 Grand Cherokee out a new thermstat
If the engine is getting hot enough it sounds like the flow through the heater core is restricted. When it is hot turn the heater on and feel the radiator hoses. One should be real hot and the other a little cooler, not much. Try taking the heater hoses off and run water from a garden hose through them. Run both directions and maybe it will break something loose. You won't lose much antifreeze by unhooking the heater hoses.
Jan 05, 2010 | 1995 Jeep Grand Cherokee
The oven temp is cooler than the temp read.How can I adjust it?
pop off the oven knob and look at the back of it. sometimes the are two screws that you can loosen and fine tune your temp settings. if the temp is way off i would say you need a new thermstat. its a little bit off work but you could definetly do that yourself and save some money on repair costs.
Sep 27, 2009 | Frigidaire FGF378AC Gas Kitchen Range
It is freezing up inside the cooler
Turn the screw on the back of the unit so that the water is not chilled to such an extreme cold
Jun 20, 2008 | Avanti Hot and Cold Water Cooler
Beko Fridge/freezer Thermostat Genuine 9002752885 Logo
57 people viewed this question
Top Beko Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a Beko Refrigerator Expert? Answer questions, earn points and help others
