Question about Blanco Plumbing
I installed a teknobili pull out tap around 7 moths ago and a leek has recently poped up under the sink. It is were the pull out hose is connected, it seems as though it has worked itself loose and leeked water into the cabnit.Has anyone else had this problem???
    President:
  • 2,692 Answers
This is a common problem, with new faucets, if one did not tighten or re-tighten the hose connection.
Posted on May 15, 2014
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
broii4x4
  • 13 Answers
SOURCE: Delta Signature 470 kitchen faucet leaks when using cold water
well it do or it don't come out if it is old U R better off buying a new, it is the seals that R leaking, then it could B a weld gone bad
Posted on Mar 24, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
  • 54 Answers
SOURCE: leaking under sink and st base on sink
Remove spray head then faucet tighten connection on the spray hose
Posted on Sep 26, 2009
djchillsnyc
  • 151 Answers
SOURCE: sink sprayer hose makes noise
hello, you may have a air pocket in the line try shutting of the water supply and then sqeeze the handle and slowly turn the water supply back on with the hose handle squeezed on till the air is forced out, hope this helps
Posted on Jun 07, 2010
Want to remove present dishwasher for replacement with a new one. How do you do it.
Most dishwashers are housed in a cabinet next to your kitchen sink.
Not knowing how exactly your machine is set up I will just advise you on common setup features and removal.
First open the doors to kitchen cabinet under the sink. If you see two hoses connected under the sink, they most likely are from your dishwasher. One is an inlet hose which would be connected to a water tap. The other would be a drain hose which would be connected via a clamp to the drain under your sink.
Turn off water tap to remove inlet hose. Unscrew or undo the clamp fixing your drain hose to drain pipe. Note when you remove the drain hose the hole to the drain pipe is exposed. You need to block this off as it will leak water when ever the sink is running. I normally get a plastic bag and twist it inside the hole and tape it off.
Next you need to locate the power cord and plug for the dishwasher. This is normally under the sink cabinet as well. However, check either side of the dishwasher. Sometimes they are behind the dishwasher.
Once you have disconnected the hoses, open dishwasher door. Look on the inside walls of the dishwasher. Some models are screwed into the wall of the cabinet so you need to unscrew machine. The screws go in either from the side walls or from the inside roof of dishwaser to your benchtop.
You need to also remove the kitchen kickboard if one has been installed infront of the dishwasher.
When machine is free open the diswasher door and grab either side of door and gently pull machine out. Have someone help you feed the hoses through as you pull out.
If the machine does not easily pull out check again for hidden anchor screws around the edges of the machine or even clamps which fix the hoses to the cabinet.
If you have issues pulling it out see if you can take some pictures and I will help you.
ash
Sep 11, 2011 | Dishwashers
My van leeks water alot from wear the bottom raideator hose connects to the transmisson . I guess thats wear its connected to? how can it be fixed?
You should be able to replace the sections of tubing (available at the auto parts store)
and use radiator type clamps instead of those cheezy factory ones. If the fitting itself
is leaking, you may take it out and use some teflon tape (white plumbers tape)
to make the fitting more secure. If all else fails, I have retapped these with a
pipe tap by having someone hold a vacuum to pull the chips back, then installed
a brass "hose barb" to threaded pipe fitting in place of the original fitting. The pipe tap
size depends on the fitting size itself. (Last one I did was on a ford and that was 1/4
inch pipe tap). You may need to open the hole to 7/16 inch with a drill (Gently of course).
The auto parts store should carry these items as well, but any hardware store should carry
the taps.
Hope this helps.
Mar 26, 2011 | 1989 Plymouth Voyager
Can't get the replacement hose through kitchen faucet
you will need to undo the tap from the sink pull the tap up a little and feed the hose through the hole and connect it to the tap then re fix the tap to the sink most pull out taps are painfull to change the hoses
Jul 13, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Engine light keeps coming on. report say faulty gas cap. changed 4 times. problem not solved. recent tune up. 100km ago.
Check clamps on filler hose and vent hose make sure it's not leaking there.If fuel pump was changed before filler tube connection on tank maybe leeking when under vacumme from perge systme and setting code.
Feb 04, 2010 | 2003 Dodge Ram Maxi
How can I remove this faucet to allow me to replace this fixture?
there is abacking nut & plate securing tap to sink, most are 1/2 inch use long socket to make it easier, also you must disconnect pullout hose from tap (connection also under sink) & remove hose weight located usally at the bottom of pull out hose. Make sure you isolate all water first!
hope this helps
Nov 07, 2009 | Hamat 3-2861ST Everest Pull-Out Kitchen...
I have a brand new LG bottom/slider freezer and I am trying to hook up the water supply for the ice machine to the cold water supply under my kitchen sink. I have purchased a kit inculding a copper pipe...
well I had a plumber connect a new hose it cost me $ 85 but it was properly install, since we added a splitter Home depot recommended but it can't take the pressure and the hose connector will leek. or if you are handy connect a splitter and a new valve
Oct 06, 2009 | LG LFX25960ST Stainless Steel French Door...
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
I have a 2001 Buick Century. I just had my
One good way to find where a coolant leek is coming from - is - when you get home and the car is good and warmed up - "hot".. Park it up on ramps if you have them.. Right after you shut it off - it will build even more pressure in the cooling system.. At this time car is off - open the hood and look (from under the hood and from under the car if you have ramps) for leeks,, listen for the "hissssss".. If the leek is just to small and/or to difficult to find - take it to a shop or oil change place for a compression test of the cooling system to locate the leek..
Hopefully its just a hose leek..
Good luck..
Sep 23, 2009 | 2001 Buick Century
How to remove a cast iron kitchen sink installed
Turn the water supplies off unscrew the hoses,get a flashlight and look under the sink you should see clamps around the top holding it in, unscrew these and pull the sink out.
Len
Feb 22, 2009 | Eljer 212-1088-00 White Dumount Double...
Plumbing Logo
123 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
