Question about Music
What cable is needed between a Digitech gsp 21pro effects processor and a Fender super60 rack?
2 Suggested Answers
  • 5603 Answers
SOURCE: replacement encoder pot for a Digitech Vocalist VR rack unit?
Digikey.com and Mouser.com have encoders.
Their online catalog should help you find a replacement. Analyze how many detents it has AND the circuit board layout and number of pins.
DO NOT be surprised if you have to shorten the shaft to match the original one.
Posted on Jan 06, 2010
Im looking for a manual for a digitech gsp 2101 studio tube preamp processor the standard model not the artist model??
Find one here: http://www.manualslib.com/manual/380759/Digitech-Gsp2101.html
Mar 07, 2015 | Music
Why won't my digitech 21pro save my program changes. I know how to chage parameters and save those changes yet when after saving them and shutting down the unit, when I fire it back up it goes
Did you try changing the battery yet? It uses a lithium battery to keep the settings in memory and those eventually die. People forget that old electronics needed juice all the time.
Jan 06, 2015 | Music
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I need instrution manual for a digitec rp100a guitar effect
The manual you are looking for can be found right here:
ftp://ftp.digitech.com/pub/PDFs/Manuals/RP100A%20Manual%2018-1867V-A.pdf
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Oct 22, 2010 | DIGITECH Guitar Effects Model No Ddm
I have a crate cpb150 amp i want to connect it to my digitech gsp2101 via livewire stp-202 cable what is the correct way?
I can understand your confusion... and a lot depends how you are going to use this. There are some caveats regarding the connections,
If you use the 1/4 outputs on the GSP, there is a speaker modeling like function that is NOT available, that IS available IF you use the XLR outputs.
The STP is an "Insert Snake" which is not really what you want as it is intended to send and receive (audio going both directions in the cable.
If you want that speaker function, then you should get two XLR to 1/4 TRS cables and go from the XLR's on the GSP to the Left and Right inputs on the back of the Crate. Your audio or guitar then is connected to the GSP guitar input.
If you connect the guitar to the crate and then use the STP, Plug the TRS single connector into the Left/Mono/send/rtn on the Crate. The Send cable of the Y should go to the Send jack on the back of the GSP and the return should go to the left return jack of the GSP. This connection I would NOT recommend as it will be noisier and you will lose the stereo effect capabiltiy since the effect is inserted as a mono.
I believe you would be happier with using the XLR's to carry left and right to the Crate and run your inout to the GSP. In short, you have the wrong cable to do the best job.
Jan 30, 2010 | Crate Music
Replacement encoder pot for a Digitech Vocalist VR rack unit?
Jan 06, 2010 | Music
I am getting a fuzzy sound from the vocalist 4 on my guitar, almost like if you strum the strings and forgot you "stored" your pick between the strings.Can you help? Thanks
This MIGHT be typical digitizing noise that can occur with a digital effects processor when the signal level is too LOW. The signal gets down in the noise because it only uses a few bits of data which means LOW resolution in the effects processing.
Make sure your guitar is producing the level required by the vocalist.
Weak battery in amped guitar is common...REMEMBER always send the signal between devices at least at half the max volume to keep a decent signal-to-noise ratio.
ALWAYS use instrument grade cables between the devices and speaker cables for speakers... NEVER use the incorrect ones for either of these functions. They should be labelled.
Dec 26, 2009 | Digi-Tech Digitech Vocalist Live 4...
I'm using an external reverb (T.C. Electronics Nova) through the effects loop and I can only get verb out of one channel (left I think) and in fact it seems that the "stereo" section (knobs etc.) have no...
The external effects when used would require an effect processor with left and right channels. You need four cables total for the effects... the two channels out to the effect unit and two cables to bring it back to the power amps.
Remember to use your pan controls if you want certain inputs to go more to either the left or right outputs.
Oct 15, 2009 | Fender Passport Deluxe 500watt Sound...
Digitech rp6
Try contacting their service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply PS0912 which should still be available. Hope this helps.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
The correct order for Effects pedals.
Personally, I like to have all "tone effects", such as wahs, distortions and equalizers in front of "time effects" such as phasers, chorus, flangers and delays. See my set up in the photo. Guitar input is from right to left, starting with the wah pedal.
Tom, 30yr player
May 15, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Music Logo
13 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
