Question about RCA CC4393 VHS Analog Camcorder
241044 ac adapter
Dismanteled above ac adaptor and found burnt trace at L 2 it has no output at j p 62 or jp 63 can you help restore the out put,, after repairing burnt trace i now have 160volts dc across c-6
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
Amp turns on but puts out no sound except for faint noise which dies out after a few seconds.
It sounds like a defective/incorrect AC-to-DC adapter may have caused your problem. These adapter come with different output voltages, AC or DC output and different amperage ratings. AC-to-DC adapters list the polarity of the DC voltage as it relates to the DC power plug and you must match both the devices voltage and power requirements. As for the amp...not working on batteries either, I would suspect output transistors or IC.
May 23, 2014 | Marshall Amplification Marshall MG2FX...
What is the AC adapter specs on the charger for the T5000
No polarity. The adaptor puts out AC , low voltage. Just traced the schematic and found out.
May 04, 2013 | Motorola TalkAbout T5000 2-Way Radio
Cannot connect to the internet. Took the ethernet plug from desktop and it it did not lite up wireless button. Where is the button to turn on internet?
Your guides To help you use your Acer notebook, we have designed a set of ... Note: If you cannot power off the computer normally, press and hold the power button ... your AC adapter: • • • • Do not connect the adapter to any other device. ... 62 62 63 Taking your notebook PC with you Disconnecting from the desktop ...
Jul 11, 2010 | Acer Aspire 5315 Notebook
I misplaced the power adaptor, and found one the fits in, but don't know if has the coorect powers output.. the power adaptor I have for this I rocks IR 4300 is an eblue mainstay with an output of 5.0...
as per irocks page this is the power info for your device:
Power : Self Power : 5V
Adapter : (input)100~240 VAC , (output)5 VDC
you probably may want to check with someone at radioshack if the adapter you found matches above specs
info on your device can be found here
Dec 26, 2009 | i-rocks IR-4300 4-Port USB Hub
SimpleTech 320GB external hard drive power adapter
I have the same drive and it uses an Accurian AC/DC Adapter. It's output is 6.3V. Also the model number is XKD-C1500NHS66.3-12. I hope this helps.
Nov 09, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Motorola t5000 charger polarity
The Polarity of Motorola's equipment is always Center Positive.
Aug 13, 2008 | Motorola T5000 Two Pack 2-Way Radios with...
Need a replacement AC adapter for my Mintek Digital Portable DVD Model: MDP-1030. I have discovered that the Mintek company is no longer is business???? I have called the phone number in my paperwork, and...
I found some used, as is/parts, players with all accessories included, on E-bay. As I only need the AC/DC adaptor, I am elated that I did a search on E-bay.
Jul 02, 2008 | Mintek MDP-1030 Portable DVD Player
The original power specs
As I search the internet I found out no replacement for this kind of the adaptor model number 090-02180-13, there are some people looking for this kind of adaptor is a faulty a pervasive problem with the TV. There are literally hundreds of complaints on the internet. Most deal with a faulty AC Adaptor and the inability of the company to provide a replacement part.
I have a solution for this adaptor problem we better improvised the parts inside. The faulty parts of this adaptor arise in the transformer. This transformer is easily to burnt because of lower amperage. So we make it higher amperage so it can resist the load heat and cannot burnt easily.
Maybe you can do this for yourself, open the adaptor case, when open already look for the transformer, the visual picture of transformer is a bulky metal with many windings. Take this out and bring it to electronic shop that know how to rewind a transformer. Tell them to reworks or rewind the transformer, only the output voltage will be change input is the same. This is the
  • INPUT 100-240 V
  • 12VOLT AT 6 AMP.
This is the result of new specification when the reworks or rewind is finish ,put it back to the adapter box,and then you can use it.This is higher amperage I mean it to you before,it can resist overheating.If ever happens that you can't find in your place know how to do reworks of the transformer here in philippines i do the rewind or reworks of the transformer ,but the problem is.very far to your place it needs shipment to carry this out .I price you 120 dollars including shipment and i assure it to you that adaptor will last long because of higher amperage .
When i search i found a site that can make an ac adaptor only you give the new specification and give where you are using the adaptor give the brand name PLTV-32 and they will make it..try this option also ..LCDPAYLESS.COM
Jun 23, 2008 | Protron PLTV-32 Television
RCA CC4393 VHS Analog Camcorder Logo
77 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
