Question about Sony DCR-SR47 Camcorder
Remove tape from sony dcr hc47 which won't switch on
magic seadog
  • 38 Answers
SOURCE: sony dcr-trv6 unable to load tape in deck
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Posted on Aug 12, 2007
  • 4 Answers
SOURCE: I have a tape in my Sony dcr-trv 350. It will not eject.
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Posted on Nov 11, 2009
  • 14 Answers
SOURCE: Sony DCR-hc42 video camera problems
Buy a Sony-make head cleaning cassette and play it in the camera for 10 seconds. Do not play for more time, neither forward or reverse the cleaning cassette, otherwise you will damage the head of the camera. This cleaning cassette is to be thrown when it is fully played (and not rewound!).
Posted on Dec 02, 2009
SOURCE: Cannot re-insert the tape cassette into DCR-HC47.
Have the same problem, tryed an authurized repairshop.
They couldnt fix it without sending the camera to an other repairshop with specialized sony tools.
So they could fix it for about 200euro.
Best Regards
Marten in Sweden
Posted on Apr 02, 2010
SOURCE: Sony DCR-HC28E Camcorder tape won't eject
I\'ve got a Sony DCR-HC28E Camcorder power switch off position but it's turn on automatic when I put power AC adaptor in DC inlet and battery not charg
Posted on Nov 05, 2010
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
Sony dcr-pc9 ejects tape when trying to load....not a claening issue..common symptom on this model
Try this:
1. Turn off the Handycam
2. Remove the battery from the Handycam.
3. Remove the AC Power Adapter from the Handycam.
4. Move the Handycam power switch to the ON position.
Note: Leave the switch in the ON position for at least 15 seconds.
5. Move the Handycam power switch to the OFF position.
6. Connect the AC Power Adapter to the Handycam.
7. Turn on the Handycam.
Apr 05, 2011 | Sony Handycam DCR-PC9 Mini Digital...
Sony dcr-trv350 tape wont close
there is a risk of hardware damage.make sure you dont force the tape into the cassette compartment to avoid damage to the unit or tape.here's what you can do.
1.remove the tape from the compartment.
2.ensure proper type and size of tape is used.
3.ensure no packaging material or foreign material inside the compartment.
4.if attempting to record, make sure cassette tape rec/save switch is set to rec position.
5.reinsert the tape, make sure it's properly inserted.
6.if still won't close or tape ejected again,remove tape.
7.reinsert a diff tape.
8.attempt to close compartment.
9.if issue unresolved, press the tiny reset button while cam is powered on (located in the panel where the lcd screen goes to,just below all the other buttons). you may also do a power reset procedure: remove batt, remove ac adaptor,set power switch to vcr, leave the cam without power for at least a minute, switch power back to off, reinsert ac adaptor/batt and turn cam on, attempt to close tape compartment.
if issue persists, service would be needed. hope this helps.thanks:)
Mar 26, 2010 | Sony Handycam DCR-TRV350 Digital Camcorder
How i can watch the tape from dcr-tvr27 with out the camera
of course you need that as a player, or else you have other player capable to play that kind of tape.
Mar 22, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Cannot re-insert the tape cassette into DCR-HC47. The mechanism is not responding. The battery is charged. Any suggestions?
Best Regards
Marten in Sweden
Mar 15, 2010 | Sony DCR-SR47 Camcorder
Dec 29, 2009 | Sony DCR-HC28E Camcorder
Sony dcr-trv270e camcorder not loading the tape
problem resolved by .... 1... switching power off, removing battery and the after reconnecting battery power on + pressing the reset button on camera. This process done a couple of times.
2.. cleaner tape then loaded successfully.... ran this for a minute. 3.. camera now loading tapes as required.
Jun 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
Sony error code
cheak batteries and the tape your using
Feb 03, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
Sony DCR-SR47 Camcorder Logo
35 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
