Question about Dell Latitude E5400 Notebook
How to change boot order in bios of Dell Latitude E4500?
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 35 Answers
Restart the computer and keep tapping F2 function key on Dell logo. Under Boot option ensure boot list option set to LEGACY. You can change the boot order and press F10 to save the setting and choose Exit.
How to change boot order in bios of Dell Latitude  - 24424375-ahfnfufwqeqqiwfe1lyo3tqh-2-0.png
Posted on Jul 15, 2015
Demmy
  • 59 Answers
SOURCE: dell latitude password bios forgotten
Hi, The only way for that is to contact dell support. you're gonna need help from a level 2 tech from austin as they're the only one who has the master password for that.
Posted on Oct 03, 2007
  • 31 Answers
SOURCE: Dell Latitude c640 Disable BIOS memory
Just use recovery console of windows xp bootable media and use the following command.
chkdsk (to check the volume).
fixmbr
fixboot
It happens due to improper shutdown methods which has caused the system volume to corrupt the MBR.
Posted on Dec 15, 2007
Buschchris1
  • 474 Answers
SOURCE: dell latitude d600 series setup
I can help, Leave everything to me!!!!
Im asuming its doing what is called, " The windows boot loop" or as we call it at work anyways.
Dels are known for this.
let me guess, it starts up normally, gets to the windows startup but asks you to pick between 4 different start up options like safe mode.
Do you have your original CD that came with it, or at least a windows XP CD?
You will need one.
What you do is,
1st: Bot from CD. Start the machine with the Winxp CD in the drive, hit F12 for boot options, or whatever key function it is. Do this as soon as you turn it on,
2: select " Boot from CD" and press any key when it askes if you want to boot from CD.
3: It will load like your doing a fresh install of windows. Thats alright, its normal and no it wont re-install windows at this point.
4: Once it loads, it will have some options. Press " R" for repair.
It will go out and to the command prompt after about 5 seconds.
5: Once at the command prompt, type in exactly ( CHKDSK C: /P ) Dont include the ( ) . Then press "Enter key "
6: after it runs the disk check, normally about 3 to 5 minutes, It will finish and go back to C:/
Just type ( EXIT ), Enter key, and let it reboot.
you can remove the disk now or later, shouldnt matter, It will go to the options screen like before, but just let it default to the normal startup, or hit enter.
Windows should now load fine and you shouldnt get that message at startup anymore.
WHY THIS HAPPENED?, you may be asking.
For some reason, certain Dell Hardware and software conflict, usually when you have installed some new program, or for just no reason.
Your Boot Up files get corrupt or cleared and windows needs those to start.
What you did was re-installed those windows files.
Now copy and paste into a word document and print it out in case it happens again. Not likley but it could.
This works with any computer experienceing this issue, usually, unless there is something worse going on.
You can help others now that you know how and become a hero, make sure to charge them $10 though for your time:)
Let me know if this doesnt work and we can try something else.
Good Luck.
Posted on Dec 12, 2008
hokuwho
  • 306 Answers
SOURCE: dell latitude bios reset
The BIOS setup password is stored in NVRAM and can only be accessed with that password. On the bottom of the laptop there is a Service Tag number. Dell support site can use that number to generate a master password for you. http://support.dell.com/support/index.aspx?c=us&cs=19&l=en&s=dhs&~ck=mn If you need further help please post back. Steve Medley
Posted on Jan 19, 2009
  • 9 Answers
SOURCE: dell Latitude 131L bios password
I got my Dell Bios & HDD Master Pasword within a few minutes from http://www.bios-password.kickme.to/
Posted on Aug 04, 2010
DELL LATITUDE d600 WHAT IS THE BIOS BOOT ORDER?
ds not meter what os you have just give the order that you need ,and the thing is that the default order must be floppy,cd-rom ,hdd and after all the other things(at any modern desktop pc )
Jun 22, 2013 | Computers & Internet
D800 cannot change boot order
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart This will set the boot order If this fails you might try some of these Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Feb 05, 2013 | Dell Latitude D800 Notebook
I have problem wiyth Dell Latitude 505 with corrupted windows xp. I can not boot from cd/dvd because it is broken. Can I use external usb DVD and boot from it ?
For that you must put the USB first in the boot order from the BIOS and disable/remove the CD/DVD entry - leave the hard disk in second and nothing else.
Jun 12, 2010 | Dell Latitude D505 Notebook
Can i boot from usb
I'm sorry but the answer is no.
You only have floppy, hard drive and cd-rom options. With some Dell models the USB is seen as a secondary hard drive from within the BIOS so maybe (if your bios supports it) you can change boot order there.
Usually thats not the case so you mainly have to boot from the CD/DVD to install or run a DOS or linux command.
Regards.
Feb 09, 2010 | Dell Latitude C600 Notebook
Purchased latitude d600 from sale how can I install my windows xp
Press F12 as you boot up the Dell and select the CD as the alternate boot device, insert the Windows installation CD in the CD drive and continue.
If you can't select the CD as the alternate boot device then go into the BIOS configuration then the Boot order and select the CD as the first boot device, save and exit. You can change it back after Windows is installed if you wish.
Jul 18, 2009 | Dell Latitude D600 Notebook
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
BIOS!!!
No boot device available means that there is no Operating System available. F12 is the key that will get you into the Dell BIOS, not F2. Once there change your Boot Order to your HDD first. Good luck!!
Sep 25, 2008 | Dell Latitude C640 Notebook
Dell c800 bios
It shouldn't be the Dell Latitude C800 Battery problem,it maybe the KEY Broad or the OS itselves problem.
May 17, 2008 | Dell Latitude C800 Bios Battery (IMP61135)...
Dell Latitude E5400 Notebook Logo
108 people viewed this question
Alun Cox
