Question about Dishwashers
How do i move control panel temperature from 65 degree to lower number
I washed my dish washer at 65 degree to clean it i want to put it back now to 40 degree but i cant get it to move back i usually press the black button and hold it down for a few seconds but it not moving it back
    New Friend:
  • 24 Answers
Have you tried a small squirt of WD40 round the knob
Posted on May 15, 2014
marked
  • 6487 Answers
SOURCE: MDB 8750 Dish Washer Doesn't start the Wash Cycle.
Yes this can be a touch pad failure that may need to be replace again , because with this type of device usually the touch pad is easy to get bad...
Good luck........
Posted on Aug 19, 2008
  • 1214 Answers
SOURCE: Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Posted on Jan 24, 2009
MNfisherman
  • 11896 Answers
SOURCE: dishes not clean
Make sure the water valves are turned on. Make sure spray arms are not clogged. You may have to pull out machine to access water vavles
Posted on Sep 04, 2009
Macmarkus
  • 2605 Answers
SOURCE: I have a SHU43C05UC/22 Bosch Dishwasher. The
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the serial number so you may want to contact Bosch to inquire if yours is affected.**
http://microsites.boschappliances.com/safetyrecall/dishwasher/
or
Bosch dishwasher hot-line 1-800-856-9226
1-800-856-9226
Before calling, have the model and serial numbers on hand. A live operator can be reached at the hot-line 24/hrs day.
Those not affected by the recall still can be a problem but easily fixed. As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Your control WILL differ in appearance, however the issue, the service and all the same info applies...except the part number. Yours will be # 431692**
**Flip this over and inspect the solder joints, it will be obvious when you see it...the cover for your models control comes apart in a similar manner**
This is where and what to look for, except I`ve re-soldered this one already...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed, other-times it will eventually stop or display "1".
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control ( # 431692 @ approx. $150 - $250USD...$167.99 at "searspartsdirect.com" ) and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 31, 2010
SOURCE: GE PDW9700 - The dishes do not get cleaned
Same as above problem: I have had this dishwasher for less than 4 years and the dishes as of about 2 years ago stopped getting cleaned. I use the recommended dish liquid and rinse and lightly clean the dishes before I put them in.
What a piece of junk!! gs
Posted on Dec 30, 2010
The dishwasher runs through it's cycle but does not clean the dishes properly and leaves a cloudy film and smears on the inside of the machine and the dishes
    Common Problem
  1. Confirm the wash water is hot
    1. Try heated wash(sani wash) if available
    2. Run hot water in sink to warm up before starting
    3. At least 120 degree Fahrenheit water temperature
  2. Open door check wash arm position start washer for a minute
    1. Confirm wash arm has rotated
    2. Check for plugged spray tips at either end of wash arm.
    3. Use small tweezers to remove
    4. Check for rack and dishes interfering with arm rotation
  3. Place cup in upper rack with opening up cycle washer.
    1. Confirm that cup quickly fills with water
    2. Not washing check water level in tub mim 1 1/2 inch
  4. Discontinue use of rinse/dry liquid additive.
    1. Confirm rinse/dry additive not leaking from dispenser into tub
    2. Washer detergent contains sparkle additive and too much sparkle/rinses/dry additive will coat dishes
    3. Try alternative wash detergent that contains minimal rinse/dry additive and use without liquid rinse/dry additive.
  5. It will take several wash cycles after the elimination of rinse/dry to purge the oily film from dishes and machine..
  6. If success "joy" is achieved with no additives then cautiously add back wash detergent with additives. Additives are important to facilitate drying and protecting the glassware china from leaching. The leaching process permanently etches the surface of glassware leaving a cloudy appearance.
Jan 03, 2016 | Dishwashers
I have always set my M7DH45B2A at 60 percent (it's in the basement). Lately it runs all the time and the humidity does not go below 65 percent. It seems "stuck" there even if I lower my...
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.
1. The humidity extraction level is set to HIGH. Lower it to 32-35%.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 65 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. It's rare in a unit younger than that. But, it can happen.
I hope the above helped you. Please let me know and thanks for choosing FixYa.
Aug 10, 2011 | Maytag M7DH45B2A Dehumidifier
A couple of times I've found that the dishwasher tablet I'm using (Finish) hasn't dissolved correctly. I found it in the cutlery box the last time. I've been putting it on the 65 degree...
I am guessing you are using the Centigrade temperature scale ... which would be 149 degrees F. 149 is way hot in terms of regular house hold use. Probably just right for a dish washer.
I would expect most tablet detergent would disolve properly at this temperature and with proper water pressure in the machine. You should have plenty of both in this machine. May I suggest you give liquid dish washer detergent a try to see the results?
Jun 01, 2011 | Dishwashers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Feb 22, 2011 | Whirlpool Dishwashers
Had the washer on express wash the error went f24 move selector to whites and seems to be working.what do you think might be the problem? Thank you Duncan
Hi
Error F-24 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). This error appears when temperature sensor fails. It could also appear due to a failed electronic control or due to a wiring failure. Unplug the washer and remove the service panel, check the resistance of temperature sensor using a volt/ohm meter. Take out the screws at the bottom of the panel and then pull it out and down to remove it from the washer. With the panel removed, remove the wires off of the temperature sensor at the bottom front of the washer tub. Temperature sensor should give reading of about 10K ohms (10,000 ohms) of resistance (RX10 or RX1) at room temperature. If the resistance reading of sensor is fine then it is due to a wiring failure or a bad control board. Hope this helps... Please post back if you need more information.
Daniel
Jan 10, 2011 | Kenmore HE2 Plus Front Load Washer
RING OF BLACK ON NEPTUNE WASHER- ORIGINAL GASKET WAS REPLACED YEARS AGO BY MAYTAG WHEN PROBLEM WAS IST DIAGNOSED- NOW IT HAS RETURNED=CAN I USE A SAFE RINSE OF WHITE VINEGAR TO REMOVE IT? ANY OTHER EASY...
Many people use 40 degrees washes almost exclusively these days and the current trend is to use even lower temperatures to save energy ( Do you save as much as you think? Washing at 30 degrees ). Remember that a non-biological powder, doesn't work as well at lower temperatures so washing at low temperatures requires biological detergent for best results. It's also worth noting that bed bugs (or their eggs) are reported to be able to survive washing at lower temperatures and therefore it is recommended that bedding sheets should be washed at 60 degrees ( Related Whitegoodshelp Blog article: Bed bugs don't drown in the washing machine - but at least they get cleaned )
Also, (as mentioned in detail later) a regular 90 degrees maintenance wash is needed.
Washing machines now commonly suffer from a build up of a greasy deposit and bacteria that causes bad smells, rots hoses & door gaskets and blocks the pressure system causing overfilling or spin failure. An even more serious consequence of this problem is that the aluminium based drum spiders can be corroded by this grease and in serious cases can cause one or more arms to break. This is often fatal to the washing machine. Replace the door gasket with this part and wash the inside of the machine at least once a month with a GOOD HE washer cleaner like this one.
Jan 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
How do i clean the washer barrel?
You can take 100ml of vinegar and keep the machine to temperature of 65 degree and start the normal program after this washer barrel will be cleaned completely
Jan 03, 2010 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Cannot get the bottom compartment open to clean filter
Hi
If you want to clean the unit you can also use the vinegar 100ml along with normal mode keep temperature 65 degree start the normal program the unit will be cleaned
Dec 24, 2009 | Kenmore HE2 Plus Front Load Washer
Temp. too hot
First off, the temp adjustment can only be made by a trained service tech, since the dishwasher will need to be reprogrammed to allow for a lower temperature in the rinse cycle but still have the higher temp needed in the wash cycle. Also, since any change in the water temp settings will require a longer wash and rinse cycle to be programmed into the unit.
Of course, you could simply lower the water temp on the water heater that supplies water to this unit, but you'd have lower temp water elsewhere and likely get cited at the next heatlh department inspection on that issue.
Since this is a commercial dishwasher, you might want to reconsider lowering the temp, since health codes and standards for commercial establishments require a MINIMUM water temperarture of 185 degrees F (85 degrees C) for proper operation and to get all the crud off the dishes, etc.
Note, the manufacturer sets these units to the higher temp, 203 degree F (95 degree C) knowing that the water will cool down quickly once the wash cycle starts and the water contacts the dishes, etc. That is also why these units have a added heater element, to help keep the water at the correct temperature needed to both clean AND sanitize the dishes, according to established health standards.
If you really want to change the water temp settings, contact your Hobart service rep and explain the reason you want it lower and see what they say.
Hope you found this very helpful and best regards!
Aug 19, 2009 | Hobart SR24-H Built-in Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
Top Dishwashers Experts
