Nad 6050c cassette deck need to change the belts
Nad 6050c cassette deck I need to change the belts - what are the specs for the belts and are there any specific instructions for doing so?
(Yes, I know it's 26 years old, but I like the sound...)Thanks,Peter McCabe
  • 9 Answers
SOURCE: Source For Replacement Belts
http://www.studiosoundelectronics.com/cassette.htm
http://www.turntableneedles.com/index.asp
Posted on Oct 27, 2007
  • 319 Answers
SOURCE: Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Posted on Apr 23, 2008
Grubhead
  • 5515 Answers
SOURCE: Toshiba cassette deck
Try E-Bay!
Posted on Jan 21, 2009
SOURCE: I need replacement drive belts for an Onkyo
www.vintage-electronics.cc/vbelts.html
Posted on Jul 21, 2009
Grubhead
  • 5515 Answers
SOURCE: Tascam 122MKII - press play no sound, meters don't move
Look for small leaver or any contact switches. They might have become bent out of shape or broken, or have dirt in them, cutting off the sound. Also check the leads coming from the head, they might have become detached or at least you can trace where they join the PC board. If you touch where they join you should get a buzz on either channel.
Posted on Aug 06, 2009
Changing drive belt on nad 6125 cassette deck
You may be lucky enough to find a rubber band that fits. But the quality rubber in a household rubber band is not as good as a belt made for the purpose, and variations in stretch may not affect your broccoli but may be audible in a cassette player. Watch tension and don't put on too tight because it could hurt delicate bearings. I have repaired many items this way also. Bon appetit and good listening! HOW TO REPLACE CASSETTE DECK BELTS INEXPENSIVELY OR FOR FREE
Mar 06, 2018 | NAD Audio Players & Recorders
How do you hook up a Tascam 122 cassette deck to a receiver i tried to hook it up to my Nad 7155 receiver and no sound what am i doing wrong please help
cassette decks have line OUTPUTS. If it records there may be line inputs. Connect the OUTPUTS to the appropriate INPUTs on ur amp. Select the correct input on the amp. If it doesn't work u will need to verify the amp inputs work and that the tape outputs r active.
If so chg the cables.
Jun 02, 2016 | Tascam Computers & Internet
How do i hook up my tascam 122 cassette deck to my Nad 7155 reciever i tried
The RCA outputs sockets on the 122 connect to either tape 1 or tape 2 "PLAY". on the Nad.
The Line In Jacks on the 122 connect to the record of tape 1 or tape 2 rec of the Nad.
If you connect it to tape 1 connect both to that.
To listen to the deck you select either tape 1 or 2 depending which you have connected it too.
May 29, 2016 | Tascam Audio Players & Recorders
My NAD 6040 Cassette deck keeps stopping after a few seconds when in play mode or rewind/forward mode...any solution to this.
The solution is to have a Technician work on it or fix it yourself if you have the ability. I work on decks 12-14 hours a day so this would not be hard to figure out. Probably a belt is due to be changed.
Mar 30, 2015 | Audio Players & Recorders
Nad 6220 cassette deck noise only on play back and meter readings are off the scale on all cassettes
Sounds like a dirty Record/ Play switch. You need to clean it with a spray like Deoxit and exercise it.
Dec 04, 2012 | Audio Players & Recorders
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
My cassette deck Onkyo model Ta 2060 is working slowly
HELLO
By the fault you describe this sounds very much like a belt problem. Take the case off the deck and check the belt(s). Some decks can use more than one belt and you need to look at their condition.
Are they too slack around pulleys maybe? Belts don't last forever and I'm not too sure of the age of your deck. But personally, I would change them all.
Make sure the tape path is clean as well, clean heads, pinch roller and capstan.
Dec 14, 2009 | Audio Players & Recorders
Belt change
You will need a service manual for that model. Task not recommended for novice -- take to pro/tech
Dec 02, 2007 | Sony CASSETTE DECK Single Dual Cassette...
Sony dual cassette deck TC-WR535
i had the same problem of not opening the cassette doors and not running with my sony tc wr535. After I repaced the belts myself with new ones it did run fine! :-) An original sony(!) rubber belt set for the two decks costed me 23 euroos incl pp.
Nov 29, 2007 | Sony CASSETTE DECK Single Dual Cassette...
820 people viewed this question
 Grubhead
Grubhead
