Question about Neff Dishwashers
What is the curly arrow showing up on the on off switch
Hoop will not move to position needle in thee centre of the work
On my Brother, after you select your pattern, select adjust. At the bottom of the adjust screen you will see 2 boxes inside a box. Select that box & choose where you want the start needle position - middle or lower left. Then press the curly arrow to return to the adjust screen
Oct 06, 2017 | Sewing Machines
How can I make my curly hair short but beautiful?
The best thing to do is to look at pictures of celebrities, http://www.stylelist.com has a lot of pictures and tips on how to get your hair cut, they have guides for how to get it cut depending on the shae of your face. Also here's a short guide on short curly hair: http://www.latest-hairstyles.com/curly/short.html
Good Luck
Apr 29, 2011 | Health & Beauty
My Eee PC curs is frozen, I have not been able to get to control panel to restore.. it wont let me use arrows to do so.. please help!!
Plug in a USB mouse. If your windows is still "frozen" then it's likely a system crash else reinstall your drivers by going to the manufacturers website
Sep 05, 2010 | Computers & Internet
What is the use of open curly braces in turbo c?
Curly braces are used in C (Turbo and otherwise) to group statements. A group of statements inside a pair of curly braces is treated semantically as a single statement. For example, a for-loop controls one statement. If you want more than one statement within the loop, you use curly braces to group them together.
Mar 06, 2010 | Microsoft Computers & Internet
Timer doesn't run; should I wire the arrow shown in some way?
the arrows mean that it goes on to what its controlling. the ones that don't have arrows are the ones that the line or hot wires hook to.
that means u hook the wires going to ur pump to the ones with the arrows and the wires coming to the timer hook to the other ones.
Jun 02, 2009 | Intermatic T101 - 24 Hr. Dial Time Switch...
CUR on alpine MRD M 605
check your ground and make sure you battery power is connect properly
Apr 14, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
CUR is showing on the display
The amp will reset when you cut the power off to it. Disconect bat for 30 sec and reconect. But to be honist with u if the wire jumped out and grounded some how during a high level, there is probley internal damage done.
Oct 17, 2008 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
CUR showing on the display
This means too much current, find and eliminate cause of excessie current and turn power off, also possibe power and ground are not big enough .Recommend 4guage wires
Oct 17, 2008 | Alpine MRD-M605 Car Audio Amplifier
Have you measured the DC resistance of the woofer to determine if it's OK? You will need to disconnect it from the amp. Check each voice coil individually.
If you disconnect both speaker wires from the amp, does it still show an overcurrent condition?
Oct 20, 2007 | Alpine MRD-M605 Car Audio Amplifier
"cur" error mrd-m1005
BUT MY AMP KEEPS SAYING CUR AND I ONLY HAVE 1 TYRE R IN MINE AND ITS KEEPS SAYING CUR I REMOVE THE GROUND WIRE TWICE AND IT KEEPS SAYING IT I HAVE A 8 GAUGE AND EVERYTHING THIS **** JUST DONT WANT TO WORK WITH ME SO TELL ME PLEASE
May 21, 2007 | Alpine MRD-M1005 Car Audio Amplifier
Dishwashers Logo
13 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
