Question about Refrigerators
Kenmore modle no.253.54703.406 comprssor not running
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: kairak modle#krp89s condenser fan and comprssor not comin on
It is possible that your main contactor is defective.,This in connected at the compressor motor and can be detached. This is the starter contactor for the motor . Now check the lines of the fan for continuity. If there is voltage coming to the compresor and not working you will check the contactor and then the motor. get help if you are unable but keep this information for getting a good estimate for the work that your technician gives you. Hope you try this out. Good day
Posted on Jul 31, 2010
Unplugged Kenmore side by side to move and when plugged back in it has not cooled since in either side.
you may have a broken coolant line under the unit when you moved it.. get under there somehow and take a closer look,.,
Ck
Feb 13, 2011 | Refrigerators
When i switch a/c on i see a/c light on , but only fan no condition , i test all relay , are working i checked the fuse is ok , but i relase no power drwing to the comprssor . i want know where that wire...
Hi:
The compressor clutch wire goes to the pressure switch , which is often located on the side of the evaporator, or in the line going to the evaporator. When there is enough system pressure, the switch has continuity, and if the system is low or empty, the switch is open, to prevent the compressor from running . If your system is fully charged, you can probably guess the switch is bad, but most likely your AC system is low on refridgerant, and keeping the compressor from running.
hope this helps!
Oct 14, 2010 | 1996 Toyota Land Cruiser
Kairak modle#krp89s condenser fan and comprssor not comin on
Jul 31, 2010 | Kairak KAI-KRP89S Prep Table 89""L (3)door...
KENMORE 53504300 WATER ON FLOOR AFTER WEEKEND AWAY, FREEZER THAWED OUT, REFRIGERATOR SEAMS COLD, REMOVED REAR CARDBOARD COVER, FAN IS FUNCTIONAL, HEAR INTERMITTANT CLICKING AT SMALL WHITE BOX AT COMPRESSOR...
You have a bad relay . Replace the " white box " ( it just pushes onto the compressor ) with maybe a small wire to secure it . Take your complete model number , including the 3 numbers in front of the ones you gave , to make sure you get the correct part .
Apr 27, 2010 | Kenmore 53502 / 53504 Side by Side...
The motor doesn't come on.
the first thing to check is the over load relay and start ptc on the compressor. not sure if you can tell if the comprssor is coming on or not.i hope this helps you let me know how things work out.good luck
Jan 22, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Kenmore Refrigerator - The refrigerator, which as purchased in 2002, stopped working yesterday. We had a cleaner clean the house - she pulled out the fridge, and cleaned under and inside fridge - we...
good checks,
one or two more
is the fan next to the compressor working
ar the coils by the comprssor clean
and one lasrt thing
there is a block on the compressor, unplug the unit pop that block off and shake it if it rattles there you go
Oct 04, 2009 | Refrigerators
I have a Kenmore Modle # 10657206601. The frige side is not cold but the freezer is. Do you have a wiring diag ?
is there frost buildup on the lower back wall in the freezer? defrost control/defrost thermostat/defrost heater. is the compressor not coming on but fan next to it is? compressor start relay. is the fan in the freezer running? evaperator fan motor. those are the most common problems. Greg
Jun 11, 2009 | Kenmore 57029 Side by Side Refrigerator
THE ICE MAKER WILL NOW ONLY MAKE A FEW CUBS
Our Kenmore ice maker GSI23 has stopped making ice cubes, the water still flows out the front, the sensor arm is down and we have pushed on the O button numerous times but still no ice. Help please
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Kemore dryer modle 11072622101
There is a white thermal fuse on the blower assy. It has 2 wires going into it. You can , off course unplug the dryer first, take the 2 wires and attatch them together. Your just bypassing the fuse. Bypass it and try running it. If it works replace the fuse. If not, let me know. Hope that helps , dave www.washermd.com
Dec 16, 2008 | Dryers
Refrigerators Logo
19 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
