Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Dell 5130 CDN printers
New black toner installed but still faded prints?
SOURCE: faded stripe down the printed page
I found a solution that worked to eliminate the faded black stripe down the page thanks to a post by slamfix in another forum. The problem is related to ink build up on the blade edge of the black developer assembly in the imaging unit (the imaging unit contains 4 separate developers - yellow, blue, magenta, and black). The solution involves taking out the imaging unit, removing and cleaning the blade edge of the black ink developer until smooth. It took me about 15 minutes to complete and was fairly straightforward.
Detailed instructions with pictures can be found at http://losingambition.com/clp300imagefix/
Posted on May 02, 2009
  • 30 Answers
SOURCE: black printing faded although toner not low
The black developer is defect, you have to call the service to solve this problem. and install FW Update V1.29.12.35
Posted on May 28, 2009
SOURCE: Samsung CLX-2160, keep getting faded
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
Posted on Jun 30, 2009
SOURCE: MY CLP-300 PRINTER IS NOT PRINTING BLACK TXT WELL
Spend a little time searching the topic on google and even this post. It appears that this has been a well documented problem since at least early 2008. The problem appears to be the imaging unit. According to several posts, Samsung has replaced several of the units. I purchased my CLP-300 in November 2008 and it worked with no problems until about 8 months in. The black text would print very lightly on the left side of the page about 1/4 of the way into the page. There was also a streak that ran down the page vertically that disrupted the text. I could change the font to any color and it would print just fine. After replacing several toner cartridges, I just began to print in a dark color for many months. After discovering all the posts on the internet this week, I contacted Samsung today with my documentation and evidence. They basically blew me off stating that I was outside of the 1 year warranty period and there was nothing they could do. I was even hung up on by a Samsung employee named Michael. Tonight I plan to take a hammer to it to relieve a little frustration. I cannot understand why Samsung chooses to ignore this well documented problem. Good luck.
Posted on Jan 20, 2010
Testimonial: "Thank you that sound like my problem will now need to check to see if still under warranty"
SOURCE: Dell 1235cn Laser All-in One Printer - Waste Toner Bin issue
Wash it out with rubbing alcohol and let dry. Apparently there is a light sensor that will throw up this error if the bin is dirty.
Posted on Nov 29, 2010
Why is my printer printing very faded grey text instead of black?
getting low on black toner? When you changed the black toner, did you remember to remove the plastic strip? Silly question, I know, but it happens.
Jul 17, 2014 | Dell 5100cn Laser Printer
1815dn printing is faded
IF this is a high use printer, there are some other things that might be in need of attention. There is a corona wire, drum and drum wiper that are consumables too.
Mar 31, 2014 | Dell 1815dn All-In-One Laser Printer
Dell 2135 fading left side when printing
It's possible that this could also be down to a toner cartridge inside the printer. I would recommend running off a copy of the colour laser test page found here.
The colour bars towards the bottom of the page separate cyan, magenta, yellow and black. Hopefully you will be able to notice that one colour is affected more than the others and replacing that colour may help.
Apologies if you have tried anything similar previously.
Oct 31, 2012 | Dell Office Equipment & Supplies
Black text is faded...shows 40% toner left...colors are printing fine
the toner in the cartridge is a powder and if there is high humidity it sometimes clumps. So remove the toner cartridge give it a shake and replace it. Give that a try. The computer toner estimators aren't always correct, especially if you have a refilled cartridge, and most are unless it was the cartridge you originally received with the new printer.
Jul 22, 2011 | Dell 5110cn Laser Printer
Printed pages are smeared with black
Sounds like a bad toner, or possibly the scanner is dirty. If you look where it pulls the paper through it can have a small speck, but since its on the scanner tself it will put black lines all the way down the paper.
If its larger and smeared the Toner itself is probably bad and you need a new Toner Kit, should come with new rollers and a new cartridge as well.
Mar 01, 2011 | Dell 5110cn Laser Printer
Colours are faded despite all toners at 25% or
If there is black "dust" all over the developer (behind the image drum assembly ) you need to replace the developer; that is uncoated toner prevenitng transference of colored toner.
Jul 30, 2010 | Dell 5110cn Laser Printer
Problem with Dell 1720 printer
Hello
You have to check couple things in this case.
Ensure that the printer cover is closed.
  1. Remove the toner cartridge.
  2. Firmly shake it side-to-side and front-to-back several times to redistribute the toner.
  3. Reinsert the toner cartridge, and continue printing.
Repeat this procedure multiple times until the print remains faded. When the print remains faded, replace the toner cartridge.
or
The imaging drum is approaching full and needs to be replaced. Order a new imaging drum.
Apr 30, 2010 | Dell 1720dn Laser Printer
Black toner replaced; now all black printing comes out faded grey
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 02, 2010 | Dell 1320c Laser Printer
Black printing faded although toner not low
May 27, 2009 | Samsung CLP 300 Laser Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
