Question about Garden
Mcculloch instructions how to replace primer bulb on mcculloch 2214av
dontbother10
  • 2220 Answers
SOURCE: I have a McCulloch 3200 chainsaw on which I
From the fuel tank to the carb, from the carb to the primer, from the primer back to the fuel tank. The bulb sucks fuel through the carb excess fuel is returned to the tank. HTH
Lou
Posted on Oct 08, 2009
dontbother10
  • 2220 Answers
SOURCE: McCulloch 3216 fuel primer and gas tubes routing?
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Posted on Nov 01, 2009
dontbother10
  • 2220 Answers
SOURCE: Need to remove & replace primer bulb on mcculloch mac 3516
There are 4 different IPLs for this saw. Fuel detail are on multiple illustrations.
http://www.ordertree.com/modelinfo/MCC/22-600035-18-Mac-3516-IPL-211318-01/139.22-600035-18-Mac-3516-IPL-211318-01.1.59.1.html
A helpful video, a few of my suggestions, and a schematic follow:
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 16, 2009
dontbother10
  • 2220 Answers
SOURCE: Mcculloch chainsaw. Model 2116av. Primer bulb is
Hello Jeff;
Your saw is listed here:
McCulloch MTD
Chainsaws 32cc-35cc-38cc Anti-Vibe
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations. The primer is displayed but not listed, and there is no part number. Before you get to deep please contact OrderTree.
http://www.ordertree.com/cms/parts-lookup-help/73.html
Use the IPL as a guide for disassembly/reassembly.
This is typical routing and a couple of hints.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
OMs for McCulloch are tough. harder than replacing the fuel line. Have your saw within easy reach they will want the serial number and a few other things.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322
Good luck with your project. HTH
Lou
Posted on Feb 20, 2010
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
McCulloch ChainSaw Model: 600035-18. Looking for manual. Replacing the Primer Bulb and hoses to fual tank, carborator, and from opposite side of carborator are bad. replaced the lines connected to the...
Hi cmiller290...
The hose in the tank with the filter on the end connects directly to the carburetor input connection.
When the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
To get your manual for your McCulloch chain saw, you need to call 1-800-521-8559, ask for parts, than ask for a PDF user manual,you will need the model number of the saw..
It will be e - mailed to you for FREE.
1-800-521-8559
MONDAY - FRIDAY - 6:00 AM - 4:30 PM (MST)
www.mccullochpower.com
Please take time to rate me
Aug 18, 2011 | McCulloch Garden
PowerMac by McCulloch PM425AV-18 38cc. I have replaced the line from the fuel mixture tank to the primer bulb & replaced the primer bulb. Now the chainsaw won't keep or looses the prime. Now...
Are you sure you have conected the pipes the correct way round, the fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, nearest to the alloy pump cover, the other conection off the carb goes to the shorter conection on the back of the primer, the longer pipe on the primer goes back to the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
HTH
Lou
Nov 15, 2009 | McCulloch Garden
Model #1635 2yrs old used often at home. starts but stalls, replaced spark plug and fuel filter. HELP
I have seen this many times in these Chinese (MTD) McCullochs. I suspect fuel supply lines have failed. What little fuel system detail there is can be found here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/MCC/MCC1635AK/139.MCC1635AK.1.59.1.html
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
HTH
Lou
GL, most saw shops will not repair these.
Oct 26, 2009 | McCulloch Garden
I have a McCulloch 3200 chainsaw on which I installed a new primer bulb and fuel lines. The old fuel lines were broken. I figured out which line runs to the carb from the primer bulb but where does the...
Lou
Oct 08, 2009 | McCulloch Garden
Aug 23, 2009 | McCulloch Garden
Gas primer bubble cracked. How to find replacement
The part your looking for is called a "primer bulb" and is relatively inexpensive (under $3).
The exact bulb you need depends on the model chainsaw you have. Lacking a model number, I've provided a link to a site where you can verify which model McCulloch chainsaw you have and thus, which primer bulb you need to replace your cracked on with.
http://www.mymowerparts.com/partdetail/1125/15474.php
Once on the page, you can enter "primer bulb" in the quick search box and it will show all bulbs for all the chainsaw models available. About the 3rd section down will have the McCulloch bulbs listed.
Hope you find this Very Helpful and best regards!
Aug 15, 2009 | McCulloch Garden
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
