Question about ASUSTeK COMPUTER Computers & Internet
Asus p5kplvm/s E2200 intel core 2 duo with ami bios v0401, how and what can I update the bios to?
  • Nivesh Rajpaul
    Nivesh Rajpaul May 15, 2014
    Please note that the issue im experiencing is that the computer does not boot the windows anymore, states that the BOOTMGR IS COMPRESSED, What is the reason for this?
    Brigadier General:
  • ASUSTeK COMP... Master
  • 3,400 Answers
Posted on May 15, 2014
myob247
  • 1342 Answers
SOURCE: Update Bios
Actually it does.
They should work together. Are you sure you have it seated properly? Are you getting any beeps?? Using correct memory modules???
Tested HERE
Posted on May 04, 2008
mdsaeed67
  • 849 Answers
SOURCE: Product comparison
deal 2 is definatly better, go for it
Posted on Oct 28, 2008
  • 11 Answers
SOURCE: Upgrading CPU on Asus PSBW-LA motherboard
Dealing with OEM PC's can be rather difficult. Most of the specifications on those chips are the same, except the FSB (Front System Bus). The E6300 is 1066MHz and the E6550 is 1333MHz. I don't believe that this is set by jumpers (i'm 95% sure). I would look into BIOS to see if it is an available option to change (though most of the time this setting is set on AUTO). There is a chance that you will need to provide a BIOS update. If you chose to do this be very careful as this is dangerous. Should something interupt this (power outage or something like that) your computer could become useless. Definitely make sure to do a lot of research and preparation before performing an update.
Posted on Mar 25, 2009
SOURCE: Computer won't resume after standby (os: vista)
Make sure all Vista updates have been installed, and check the ASUS website for any bios updates. I believe that motherboard had a known issue with stand bye.
Posted on Oct 20, 2009
darkpain
  • 316 Answers
SOURCE: Is it Asus mainboard P5VD2-MX SE
Hello,unfortunately no my friend but you can put Core 2 Duo E6700 (2.66GHz,1066FSB,L2:4MB,rev.B2) or if you want more speed Core 2 Extreme X6800(2.93GHz,1066FSB,L2:4MB,revB2)
Posted on Feb 03, 2010
Bios problem what are new drivers bios
P5B-E Plus Uses 100% All High-quality Conductive Polymer Capacitors! - Support Intel® next generation 45nm Multi-core CPU
- Intel LGA775 Platform
- Intel® Quad-core CPU Ready
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® P965/ ICH8R
- Dual-channel DDR2 800/667/533
- Fanless Design - Stack Cool 2
- PCI-E Gb LAN/ 8-ch HD Audio
- AI NOS™ / AI Gear / AI Nap
- SATA on the Go/ 1394/ Noise Filter
  • Another option is through the Internet. Launch the utility:
Start > Programs > Asus > ASUSUpdate
Follow the directions.
There is also ASUS EZ Flash.
Make sure that you do have a copy of your current or original BIOS, if you have the CD that came with the MoBo then you are golden.
Sep 20, 2011 | ASUS P5B-E Motherboard
What arethe compatible components of this kind motherboard
CPU P5KPL-AM empty.jpg Valuable Intel G31 uATX solution with FSB overclocking 1600MHz!
- Intel® Core™2 Quad Ready
- Intel® 45nm CPU Ready
- FSB 1600(O.C.)/1333/1066/800 MHz
- Intel® G31/ICH7
- Dual channel DDR2 1066(O.C.)/800/667
- EZ Flash2 & CrashFree BIOS3
- 8 Channel High Definition Audio
Intel® Socket 775 Core™2 Quad/Core™2 Extreme/Core™2 Duo/Pentium® D/Pentium® 4/Celeron® E1000 Series and Celeron 400 Series Intel® Hyper-Threading Technology ready
*Refer to www.asus.com for Intel CPU support list
Chipset Intel® G31 Intel ICH7
Front Side Bus 1600*/1333/1066/800 MHz (*1600 is overclock speed) Memory 2 x DIMM, Max. 4 GB, DDR2 1066(O.C.)/800/667 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*Overclock speed
**Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
***When installing total memory of 4GB capacity or more, WindowsR 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended. Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
VGA Integrated Intel Graphics Media Accelerator (Intel® GMA 3100)
Max. resolution:2048x1536X32bpp, Horizontal:127.5KHz Vertical:85Hz Storage Southbridge
1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
LAN Realtek RTL8102EL 100/10 LAN
Audio VIA VT1708B 8 -Channel High-Definition Audio CODEC
Anti-Pop Function
Jack-detect & Multi-Streaming
Support S/PDIF Out connector USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel) Overclocking Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz up to 600MHz at 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
Back Panel I/O Ports 1 x Parallel
1 x VGA
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x LAN(RJ45) port
4 x USB 2.0/1.1
1 x COM port
8 -Channel Audio I/O
Internal I/O Connectors 2 x USB connectors support additional 4 USB ports
1 x Floppy disk drive connector
1 x IDE connector
4 x SATA connectors
1 x internal speaker connector
1 x S/PDIF Out connector
1 x CPU/ Chassis/ Power Fan connector
1 x Front panel High Definition audio connector
1 x Chassis Intrusion connector
1 x CD audio in connector
24-pin EPS 12V Power connector
4-pin ATX 12V Power connector
1 x System Panel connector
BIOS 8 Mb Flash ROM
DMI 2.0
AMI BIOS
PnP
WfM 2.0
SM BIOS 2.5
ACPI 2.0
Manageability WOL,PXE,RPL,WOR ,PME Wake Up Accessories User's manual
1 x UltraDMA 133/100/66 cable
1 x Floppy disk drive cable
1 x SATA cable
1 x SATA power cable
I/O Shield
Support Disc Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Form Factor uATX Form Factor
9.6 inch x8 inch ( 24.4 cm x 20.3 cm )
hope this helps
Jul 18, 2011 | ASUS P5KPL-AM - Motherboard - micro ATX -...
Unknown CPU detected, BIOS update required to unleash its full power after update ... hello, can i run an Intel Core 2 Duo e7500 on an Asus p5vd2-vm se i need help plz
hi
yes u can run Intel Core 2 Duo e7500 on Asus p5vd2-vm socket LGA775 .
spec link's
http://www.asus.com/product.aspx?P_ID=2sYAtam7ng8vCngf
http://ark.intel.com/Product.aspx?id=36503
Mar 22, 2011 | ASUS Computers & Internet
No display
update bios if u have programer if you have not programer update via recover proceider check intel website
Dec 23, 2010 | Intel DG41RQ Motherboard & Core 2 Duo...
My intel core 2 duo wont work on the motherboard
maybe incompatible or possibly your board is faulty or your processor is faulty if one is new don't think its not faulty iv had faulty components that cost me a couple of hundred that have just came out of the box so try another processor and if it works its your core duo so replace it if not its your board but first try doing a bios update this an usually solve a few problems if not replace you faulty component hope this has been of help
May 19, 2010 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Oct 18, 2009 | ASUS P5B Deluxe Motherboard
F672cr(m1610)and intel core duo?
The Acer M1610 was available with the following processors: Intel Core 2 Duo, Intel Pentium Dual-Core, Intel Pentium D/4, Intel Celeron D/4 2.0GHz.
Based on this information, It is likely that you can support a Core Duo or a Core 2 Duo, however may be limited to the 2.0GHz models due to clock and multiplier limitations on the BIOS. This may be different if there is BIOS upgrades to support faster processors.
Your best option of the above listed processors will be the Core 2 Duo, however their system specifications report that only the Core 2 with 800MHz or less Front Side Bus are supported.
Also note that the Celeron 430 is a 64bit processor, so it is not likely to work on this system either.
Sep 05, 2009 | Acer Computers & Internet
BIOS Password Problem
The only thing that a bios update would do would update the bio your password info should stay the same maybe your not typing it right try typing with or without cap lock
Mar 10, 2009 | ASUS F9S-B1 Intel Core 2 Duo T7500 2.20GHz...
What is the prize of processor core 2 duo
the cheapest u can get e2200 which is about 60 quid ;)
Mar 05, 2009 | Intel Core 2 Duo E6600, 2.4 GHz E6600...
ASUS MAKING NOISE
2 things come to mind when I hear this; the case fans or the power supply fans. I would check those first to see if they are the problem.
Feb 03, 2009 | ASUS Essentio Desktop with Intel Pentium...
Computers & Internet Logo
143 people viewed this question
Top ASUSTeK COMPUTER Computers & Internet Experts
Steve Kozy
Steve Kozy
Level 1 Expert
Hyun Soo Ryu
Hyun Soo Ryu
Level 1 Expert
Mister Danger
Are you an ASUSTeK COMPUTER Computer and Internet Expert? Answer questions, earn points and help others
