Question about Acer Computers & Internet
Why my Acer s202HL LCD monitor blinking blue light?
Blinking blue on power button.It doesnt turn on. Screen completely black and no light coming from it.
bammbammfran
  • 159 Answers
SOURCE: Power Light Blinking & Black Screen
A blinking blue light indiactes that your power-inverter board is not putting out what it should. It needs an overhaul which may be a simple as changing out the capacitors on the boards.
It could go beyong that to transistors or even a bad bulb.
It will have to be opened up to do that.
A picture may show visual signs of damage. If you can take one and email it to me , I'll take a look.
Fran
Posted on Oct 18, 2008
SOURCE: Dell Blinking Power Light
Just wanted to say Thank You for the info on this site. I had the same problem as previously posted. When powered up, the monitor showed a fast flash of the desktop and then went black, with the power indicator flashing green. I read the posts, purchased the capacitors and the 4 - 2sc5707 transistors through ebay. I ordered them on the 6th and rec'd them today. I only had one bad capacitor and one transistor that checked bad, but I ordered 5 caps and 4 transistors. When ordering the caps be careful of the height of the caps. I found this to be a problem because I ordered the 50v, 105 degree Panasonic caps that didn't fit with the enclosure attached, so I used the 4 good caps removed previously and replaced the bad one with a 470uf, 50v. 85 degree cap from Rubycon I found among my spare parts. Installed the parts and the monitor is working properly (for the last two hours) so I'm happy for as long as the repair lasts. Thanks again for the info.
Posted on Jan 09, 2009
  • 152 Answers
SOURCE: gateway monitor, black screen with blinking power button
wjfarm48, Sure sounds like a power supply problem. How old is it? How many hours of use? Do you understand what a switch-mode-power-supply and an inverter supply is? If not, then here are your options. Check with Gateway to see if there is a swapout program. You box up and ship them your monitor+cash, and they return a REFURBISHED same model with new CCF tubes and inverter/SMPS. When you box up the monitor, follow this lead. "A 3 inch thick layer of breathable air shall be the only thing touching the lcd front panel" Next option is find some local TV/Monitor repair guy who can get parts and or replacement boards/CCFtubes from Gateway. Last but not least, is to repair yourself. Not Recomended.. But do a search on lcd monitor repair or Bad Capacitors In LCD Monitors or Repair of SMPS in LCD/FPD Monitors. Also check for videos on YouTUBE related to lcd monitor repair just for your own info. Here 's what you are dealing with. The light that makes your FPD bright white is generated by Cold Cathode Fluorescent Tubes (2) that require 600-1200vac at high frequency that is generated by an INVERTER which gets 12-24vdc from the SMPS. Almost the same technology is used in the new style screw-in curlie-que Compact Fluorescent light bulbs. Only they call the inverter a electronic ballast. Anyway, thats about all the info I have. Let me know how you make out in you quest to get your LCD up and running again. I'm louie12fix on fixya or lmistyrel@ aol.com BYE for now.
Posted on Apr 03, 2009
  • 1684 Answers
SOURCE: Dell LCD Monor light keeps blinking green, screen
Your monitor has a bad power supply board. This happens often on LCD monitors because of the heat buildup in them. If you can solder them go to our web site at:
www.ccl-la.com/badcaps.htm We have a step by step dis-assembly and repair guide for your monitor. There are several versions of the E173FP some end in b , f, or c so be sure to check your monitor.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 27, 2009
I have ac Acer S202HL LCd monitor. When I booted up one day it didnt come on.
first check with your both power supply out put is coming 19 Volts dc.
if its not coming check with multi meter primary and secondary of your adopter continuity.if no continuity replace with proper working adopter.
Nov 07, 2013 | Acer S202HL LCD Monitor
I just bought an acer S202HL LCD monitor and I came with no instructions Just pieces. I need to find out how to attach the stand to the monitor.
http://www.manualowl.com/p/Acer%20Computers/S202HL/Manual/82561
images?q=tbn:and9gctpxijrdqvna5o4shkopa9nys0_cz5la7mnust5rxnxgdozyaryna
Free Acer S202HL manuals!
Problems with Acer S202HL?
Ask a new Acer S202HL question
i cant get a closer look at the diagram
how many screws did it come with
Ensure that the base is locked onto the monitor stand arm
hope this helps you
Nov 28, 2011 | Acer S202HL LCD Monitor
VL 1919 power button blue light blinks and screen
Yea I fixed it ..bought a new monitor......I tried the old monitor on two other PC's same problem.....
Nov 23, 2009 | Computers & Internet
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
Blue power button flashing with blank screen
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try.
If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
Jan 03, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Fran
Oct 18, 2008 | HP vs19 (Silver) 19" LCD Monitor
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Blinking lights when PC is turned off
This works if you boot the monitor with a pc, open the osd menu and go to reset. reset the monitor.
Dec 08, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
303 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
