Question about Microwave Ovens
Why won't the glass internal base go around? - Microwave Ovens
  • 54 Answers
There's usually a belt that drives it, probably broken or stretched beyond useful. If you're comfortable opening up the unit, go find it and replace. Identify part from drawing for your model (Google) and order replacement online.
OR, buy a wind-up turntable made for microwaves. Good luck!
Posted on May 15, 2014
Magic chef microwave
There's a fuse that has blown. look for it near the bulb socket or on the main board inside the unit.
Jan 24, 2014 | Microwave Ovens
The glass tray in my microwave won't rotate
The turntable motor is defective and must be replaced to remedy the situation.
Apr 04, 2012 | Whirlpool Microwave Ovens
LG Microwave oven Tried to remove the countertop light bulb. Glass came off metal base still in unit. How do I remove the base, ist screw type bulb?
try using a small potato,push it into the base while turning the potato.it may lock onto the base and unscrew it....UNPLUG IT FIRST...
Nov 16, 2010 | LG LMV1630ST Microwave Oven
Microwave safety after repainting
Too generic...Did you use the high-temp appliance enamel recommended, or a spray...or worse?
Was the rust inside where it can contact food through the circulating air, or on the outer body?
First thought based on how I read the question: Never use that machine again...but that's based on the word "in" instead of "on my microwave".
If the rust was around the door frame, outside the seals, and you used an enamel (of course) then you may be OK...but...
Considering the fact that a cheap microwave is a drop in the bucket when compared to your family's health...Why risk it?
Mar 29, 2010 | Welbilt MR622W Microwave Oven
Handle broke off my GE Advantium 120 microwave door (model #SCA1000DCC03). I just ordered a replacement handle (PRT #WB15X10071) but I need instructions on how to replace it. The screws are hidden inside...
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
Sep 16, 2009 | GE Advantium 120 Convection/Microwave Oven
My door handle is broken. Is it posssible to
You should be able to buy only the door handle and avoid having to replace the entire door. Appliancepartspros.com carries the handle. Just type in the model number you provided and look for item #3 under the parts listing. The part number and price varies based on the color you need. Make sure you order the correct color. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
If you have questions, please let me know. I hope you find this information helpful.
Jul 06, 2009 | GE JVM1640 Microwave Oven
Handle replacement on GE JVM 1860SD
Jul 01, 2009 | Microwave Ovens
GE XL1800 JVM1870SF02
I have the same problem on a Jenn Air. Did you get an answer?
Oct 03, 2007 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
