Question about Miele CVA4070 Coffee Maker
Miele coffee machine stuck in rinse mode - Miele CVA4070 Coffee Maker
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
Posted on Mar 15, 2010
heatman101
  • 43501 Answers
SOURCE: After i descaled
Turn off the power and let it off for a few minutes... that should reset the machine...
heatman101
Posted on Nov 25, 2010
  • 1833 Answers
SOURCE: i have a miele coffee CVA 610 system, I went thru
According to your problem, I think there is the problem with programming of the machine. So reprogram the machine, you can take help for reprogram from user manual of the coffee machine. Check also the electric input section and the electric outlet.
Posted on Jun 13, 2011
  • 128 Answers
SOURCE: miele coffee machine is stuck
pull the stainless steel dispenser cover straight down as far as it will go. now push it firmly up as far as it will go. if the error message still appears, repeat, but push up faster and harder. there is a switch monitoring the position of the central jets to make sure they are installed. you have to push up hard enough to close that switch. sometimes you have to slam it pretty good, but dont go crazy on it. just give it a firm touch.
Posted on Jul 19, 2011
  • 115 Answers
SOURCE: My miele coffee machine stucked
Hi Amy, Sounds like a vaccum valve is faulty. Try opening the steam tap and leavig it open while heating. If this fixes your heating, up then that is your problem. If its still not working then you have either a faulty heatig element or a faulty pressure switch. I do not recomend repairing this yourself as you could potenitly harm yourself. If my first solution works, then just live with it. Once its heated, the faulty vaccum valve plays no more part in the machines operation. Its only works for heating up. You can hit the top of it to free it, but then it might not seal off when machine has heated. It will constantly leak steam. Dazza REPAIRER
Posted on Sep 24, 2011
My meile machine is stuck in the descaling mode
When you start the cleaning cycle, Don't stop the process by pulling the plug! Turnthe unit off from inside wait 5+ seconds & turn back on and thecleaning cycle should restart... If you do not use a cleaning TAB..Open& shut the LOOSE coffee Door under the drawer (Top Left) and thecycle will continue.
May 23, 2014 | Miele CVA4070 Coffee Maker
IT STUCK IN CLEANING MODE. AND WONT RESET. WHAT DO I NEED TO DO.
This is normal behavior for a Miele machine, it is a safety feature. You have to clean it.
Use the cleaning tabs you have that came with your machine, if you don't have anymore, get them here http://www.amazon.com/Miele-05626080-Cleaning-Tablets-Packet/dp/B001BNV3GK
Clean the machine normally by opening the machine up, removing the storage tray, and dropping the tablet down the ground coffee shoot and letting the machine lead you through the cleaning.
Hope this helps.
May 31, 2011 | Miele CVA4070 Coffee Maker
Miele CVA 5060 descaling is stuck
Did you figure this out? I've got the exact same problem.
Sep 05, 2009 | Miele Coffee System
No program mode in Miele CVA620 espresso machine
my miele cva 620 coffee machine not working only the LED screen lit up and nothing else? any ideas.
Apr 10, 2009 | Miele CVA2650 Stainless Steel Espresso...
Gaggia Titanium stuck on RINSING CYCLE
Let it rinse it may run for some time.
you will not be able to remove the brew unit as it is engaged to be rinsed.
Nov 17, 2008 | Gaggia Titanium Espresso Machine
Where can I buy Miele coffee system instruction book?
You have to buy descaling tablets from miele.  You turn the knob to program mode and keep pushing the enter button until you get to descaling.  You put two descaling tablets into your water reservoir and replace into unit.  Put containers under the steam valve and the hot water wand. Press enter.  Turn steam valve al the way on.  Keep an eye on the containers.  The process takes about 30 to 40 minutes.  The message will appear 'Descaling finished." Turn steam selector to O and press enter.  Display will read "rinse machine, fill watertank.  Fill tank and return to machine.  Place empty containers beneath hot water dispenser and steam nozzle again and turn steam selector fully on. Allow water to run through system completely.  When process is finished, display will read "Rinsing Finished."  Turn steam selector to O and press enter  Program selector is on Program Mode and display will read Descaling, Timrt, unit is no descaled and ready to use.  Turn program selector to on.
Jul 24, 2008 | Miele Coffee System
Miele Coffee System Descale
New unit... Started the cleaning process and the unit is stuck in CLEANING... Pulled plug & no help, now what??
Thanks, Smokey
May 10, 2008 | Miele CVA4070 Coffee Maker
Miele Coffee maker cva 615 coffee will not come out
The screens that the coffee grinds are squeezed in between are clogged. You need to remove the brew unit, remove the bottom screen, (should be one phillips screw in the center) and scrub the screens clean. You need to clean all of the really fine holes out so that the water can pass through. To prevent this in the future, use the rinse cycle on the machine frequently and also take the brew unit out and rinse it under hot water everytime you dump your waste unit.
May 05, 2008 | Miele CVA615 Espresso Machine
Miele CVA4070 Coffee Maker Logo
254 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
