Wiring schematic for k2mcp61p
Power switch wires which wires go to which pin
2 Suggested Answers
leecom72
  • 4806 Answers
SOURCE: k2mcp61p v motherboard. Just need to know which
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Posted on Jul 20, 2009
Need the pin to pin wiring schematics for this model of motorcycle?
    More images for 1990 Kawasaki 650R wiring schematic
    Kawasaki Motorcycle Wiring Diagrams - ClassicCycles.org
    www.classiccycles.org/1852/597943.html
    Kawasaki Motorcycle Electrical Wiring Diagram Schematics. ... Kawasaki GPZ600 GPZ 600 Electrical Wiring Harness Diagram Schematic 1988 to 1990 HERE ...Kawasaki KZ650 Z650 KZ Z 650 B Electrical Wiring Harness Diagram Schematic ...
    Owner Center - Kawasaki
Jan 21, 2016 | Motorcycles
Do you have switch schematics
No diagram available, but wiring is as follows: PPL/BLU wire connects power from FUSE 21 in the interior fuse panel; Pin 1 - WHT/PPL to RF window switch; Pin 2 - YEL/PPL to RF window switch; Pin 3 - WHT to RR window switch; Pin 4 - YEL to RR window switch; Pin 5 - N/C; Pin 6 - WHT to LF window motor; Pin 7 - YEL/GRN to one touch down window relay; Pin 8 - WHT/BLU to LR window switch; Pin 9 - YEL/BLU to LR window switch; Pin 10 - ORG/YEL to interior lights system. A second PPL/BLU wire connects the rear cut off switch to the left and right rear window switches.
Jun 21, 2014 | Drills
Why don't the turn signals flash?
Hi Hey777, you may have a faulty turn signal module or wiring connector, check for corroded, broken, or loose pins/sockets, power and ground, with a test light, for more information about your question please visit the website below. Good luck and have a nice day.
Harley Davidson Manuals Mark Workshop
Harley Davidson Wiring Diagrams and Schematics
Mar 27, 2013 | 1993 Harley Davidson XLH Sportster 883
Driver's window
The wiring diagrams for your 2003 GMC Sierra power window circuits are copyrighted material and cannot be posted here. However, I can describe the driver's power window circuit to you.
Battery voltage is provided to the driver's window (master) switch via the ORANGE wire at PIn #2 on the switch connector which comes from the 25 Amp Left Window Circuit breaker located in the fuse block on the left side of the dash.
There is a logic module located inside of the master switch which controls the "Auto Down" feature for the driver's window. When the switch is operated in either the "UP" or "DOWN" position, power and ground is supplied to the window lift motor via the BROWN wire (Pin #1, Connector 2) and the DARK BLUE wire (Pin #3, Connector 2) Thease wires will switch polarity dependin on whether the switch is commanding UP or DOWN.
The schematics show that the ground circuit for the driver's window motor is supplied internally by the driver's window switch module. It is most likely grounded inside the door panel itself - the schematics do not specify. To check for ground, you can test continuity to ground on BOTH the BROWN and the BLUE wires by back-probing them with the switch electrical connector plugged in and the window control switch in the NEUTRAL position. They should both have ground.
When the switch is operated, one will remain ground while the other switches to power.
Mar 24, 2012 | 2003 GMC Sierra
Rci-2950dx 4 pin microphone wiring schematics
you can't because of the up/down buttons on the mic. the 2950 is a 6 pin and the d-104 is a 4 pin. If you can figure a way to eliminate the u/d switch then go for it. there is a wiring diagram on www.cbtricks.com
Jan 15, 2012 | Midland 1001Z 40-Channels Base CB Radio
Power switch is not working
IT SOUNDS AS IF YOUR NOT GETTING THE WIRES ON THE MOTHERBOARD IN THEIR PROPER PLACES. DO YOU HAVE THE BOOK THAT CAME WITH THE MOTHERBOARD, MOST BOARDS N EED ONE WIRE TO GO TO A SEPARATE SET OF POWER PINS AND THEN ONE GOES TO THE SWITCH. THEY ARE IN DIFFERENT PLACES. ALL POWER SUPPLIES HAVE DIFFERENT WIRES, THE WIRE THAT SAYS PWR GOES TO THE 2PINS ON THE BOARD THAT ALSO SAY PWR, AND THE SWITCH PINS ARE PART OF THE LONG ROW OF PINS WHERE THE SPEAKER AND RESET ETC. ARE LOCATED. YOU COULD PROBABLY FIND A SCHEMATIC OF YOUR BOARD ONLINE IF YOU HAVE YOUR BOARD MODEL NUMBERS.
Dec 31, 2011 | Foxconn Computers & Internet
HOW DO I INSTALL ROGER BEEP ON A GALAXY 33 CB RADIO
Does the roger beep come with instructions? It can vary between beep boards.
Typically it gets installed inline with the mic jack.
There is a wire or pin on the board where the tx wire, and the rx wires go.These wires get disconnected from the mic jack, then a wire goes to the tx pin. Then there is an audio wire that gets connected to the audio wire of the mic jack. Then the black wire to ground, and the red wire to switched 12v right off the power switch.
Here is a schematic of the board connected to the mic jack so you know what pin is what.
Again, I would need to know what roger beep board you would like to install.
Feb 22, 2010 | Galaxy Radios DX-33HML 40-Channels Base CB...
CASE WIRES TO PANEL1 CONNECTIONS
The hdd red wire gooes to pin #1 the hdd white wire goes to pin #3 the power sw orange wire goes to pin #6 the power sw white wire goes to pin #8 The reset sw blue wire goes to pin #7 the reset sw white wire goes to pin #5 the power led green wire goes to pin #2 the power led white wire goes to pin #4.
Now the layout of the pins is the long row (5) pins are the odd number pins 9 being the odd one and 1 is the other end of the row. 2 through 8 start at the pin accross from 1 : : : : . I hope this helps you.
Aug 22, 2009 | PC Chips MB PCCHIPS SiS746FX M848A V5.0...
K2mcp61p v motherboard. Just need to know which
Hi there.
Jul 20, 2009 | Computers & Internet
1996 Dodge Ram Factory Trailer Wiring Schematic
all you need is a cheap continuity tester, any one to help tap on the brakes..7pin is just like the 4 pin w/extra power wire for acc.lites,electric brakes.when you buy the 7pin rec.,comes w/wiring schematic standard to all trailer rec.- you can do it..kev-mn.
Dec 10, 2008 | 1995 Dodge Dakota
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
