My kindle won t turn on
My kindle is fully charged i tryed the on off button it turned turned on then froze its a fire hd
  • 846 Answers
SOURCE: non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Posted on Jun 08, 2010
SOURCE: Kindle locked up and now can't get it to turn on.
I have the same problem. The screen saver is partially frozen on the screen on the upper right corner and then blank down the rest of the right side. The rest of the screen is readable and I'm able navigate (turn pages, select different books, etc).
Did you figure anything out? Help!
Posted on Aug 08, 2010
  • 94 Answers
SOURCE: KINDLE FROZE WON'T RETURN TO HOME TURN PAGES,
You can try these steps! good luck!
  1. Plug the Kindle into a wall outlet.
  2. Ensure the Kindle is charging (the indicator light should be on).
  3. Wait 2 minutes.
  4. If necessary unplug the Kindle and reset by moving and holding the power switch for 15 seconds before releasing it.
eBookBoy
http://digialreader.freeforums.org
Posted on Jul 09, 2011
  • 457 Answers
SOURCE: Kindle light is orange when
Try to slide and hold the on switch until after the power light blinks three times (should happen after a little more than 5 seconds). Release the switch after the blinks and the Kindle should start up.
This is only necessary if the Kindle was switched off by the same method before, or if the battery was completely drained. A short nudge of the power switch merely puts it in and out of a power-saving sleep mode, the prolonged hold really cuts / reinstates power.
Posted on Jul 23, 2011
Testimonial: "Nope, nothing. I tried plugging the usb into my laptop. The Kindle doesn't show up or it says no data/driver found."
  • 331 Answers
SOURCE: kindle fire screen is blank
Try doing a hard reset of your Kindle Fire as advised on the Kindle Fire Support web site for dealing with Screen problems
If you still have a problem after doing the above, then you follow the additional steps advised on the above web page, i.e. ensure the Kindle Fire is fully charged (the power indicator has changed from Orange to Green) and that you have the latest Software Updates installed (assuming you can view the screen to do so!).
Posted on Jan 08, 2012
Kindle fire
James, You have to make sure the Kindle is charged, try holding the button longer, maybe even up to a minute, hopefully that will do it. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." You can also do a search on google for this issue, seems there is a lot of info. on this problem.
Kindle Fire HD how to reset when locked up EpicReviewsTech CC
12 major Kindle Fire problems and how to fix them
My kindle won turn on Is it the battery Kindle Fire HD
HDX will not boot
Jun 19, 2016 | Amazon Kindle Fire HDX 7
Won't take a charge.
Armend, Could be a bad charging port. Press and hold on button for 15-20 seconds a couple times to see if it will reset and power up before trying anything else. Check the attached links, videos,instruction and guides on kindle charging problems. Good luck
Kindle Fire Won Charge Fix
Reset Kindle Fire When it Won Turn on or Charge
Apr 08, 2016 | Amazon Kindle Fire HD
Fully charged. Why doesn't it turn on?
Ruby, try pressing and holding on button or you will have to reset.
Amazon Kindle Won Charge Quick Fixes
Mar 12, 2016 | Amazon Kindle Fire HD
Kindle will not shut off-goes to shut off or cancel but wont move. doesnt charge well-doesnt always hold charge
Patricia, Using the power switch, you can forcibly reset your Kindle device. This reset will shut down the Kindle without accessing the shutdown command from within the Kindle's operating system, a particularly useful tool when dealing with a frozen Kindle. To initiate a hard shutdown, Kindle disconnect from its charger, slide and hold the power switch for about 20 seconds. This will force the Kindle to shut down, now it can be restarted normally.
Check links below for charging problems.
Troubleshooting Kindle Fire That Won Charge
Kindle Fire not charging
9 common problems with the Kindle Fire HD and how to fix them
Feb 25, 2016 | Amazon Kindle Fire HD
I can turn my kindle on but can't get any thing else to work.
Reset Kindle Fire When it Won't Turn on or Charge
www.lovemyfire.com > Kindle Fire Problems
However, sometimes when it locks up you can't tell because the screen goes dark, either ... it's already on but is locked up and thus won't charge or work properly. ... 15 minutes to make sure it gets enough charge, and then try turning it on again. ... If this tip (or anything else on my site) helps solve your Kindle Fire problem ...
Amazon.com: Customer Discussions: My Kindle won't charge
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Jan 3, 2013 - If you can't see a Contact Us button on this page, then go to .... What canI do? I sent an e-mail to Amazon but have not heard anything. My Kindle is frozen and won't ...
Mar 31, 2014
How to unlock a Kindle. Lock won ...
Jan 27, 2014
Kindle paperwhite won't turn on
Nov 6, 2013
My kindle won't turn on....green ...
Dec 12, 2011
More results from www.amazon.com
Jan 16, 2016 | Amazon Kindle Fire HD
My kindle fire HD is fully charged but will not turn on
Try holding down the power button for fifteen seconds to reboot it.
Feb 23, 2015 | Amazon Kindle Fire HD
Why won't Kindle turn on or charge?
Maybe it's not completely off. Hold down the power button for at least 20 seconds. The hit it again to turn it back on.
If it's not charged, after doing that, you'll need to plug it in for at least 15 minutes.
You may have to do a factory restart. Try the things on this list and if all else fails and you have to perform a factory restart, this will show you how.
http://www.lovemyfire.com/kindle-fire-reset.html
Sep 07, 2014 | Amazon Kindle Fire HD
The kindle won't turn on
It is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't turn on at all this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
Dec 31, 2012 | Amazon Kindle Fire HD
Kindle fire screen is blank
Jan 08, 2012 | Amazon Kindle Computers & Internet
18 people viewed this question
jasbo
jasbo
