Question about Mitsubishi WS-55809 55" Rear Projection Television
I have a mitshibushi 1800 tv. which will not power up blue light then red nothing happens
When tv is turned on the blue indicator light displays then it goes to red
  • Mitsubishi Master
  • 1,210 Answers
I repaired one these. The convergence board is bad. You will have to change the two STK Ics. These will have, I believe thirteen pins, mounted on large heat sinks.. And that is not the only problem. You will need to resolder this board as there are as many as 15 bad grounds. This board is very thin and you need to exercise care pulling it out,desolder, install and solder in the new ICs. Once again this board is very fragile. Another name for this board, is the signal board, look for all the RCA jacks and RF connections on it. Thanks for asking
Posted on May 25, 2014
milmar
  • 50 Answers
SOURCE: Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Posted on Aug 11, 2008
  • 146 Answers
SOURCE: Lamp light turns red
Yes this is the signal for a bad lamp. Other things can cause this. 1. Look at the new lamp. make sure it still looks good. not broken with little glass pieaces in it. 2. When you turn on the tv, put your ear to the lower back part of the tv near the middle. Listen for the start up of the color wheel (a low high pitch sound only at the start up of the motor). If this is good you will here a ticking sound only if the lamp dose not light.
Now with all this info. If the lamp lights (as seen from the back of the set) and goes out after a few seconds and you did not here the color wheel spin up, the color wheel is bad.
If you here the color wheel spin up and no ticking sound, the Ballast is bad.
The ballast part no. 939P978010
The color wheel is not avialable from Mits. You will have to replaced the light engine. It cost to much. Just buy a new tv.
Posted on Nov 15, 2008
  • 126 Answers
SOURCE: green (power on) light continuously blinking/set won't turn on
This set was designed in such a way that when it is unplugged and plugged back in the LED will blink for around 90 seconds and then stop. During that time you cannot turn the set on. This is the amount of time it takes for the Digital Module to boot up. These units have a problem with some capacitors going bad in the Digital Module and when that happens the LED never stops blinking. You need to contact a qualified repair shop to get it repaired. I have repaired many and the cost is around $250 to $350 depending on where you live. That set is well worth the repair cost.
Posted on Jun 02, 2009
firesnake09
  • 2923 Answers
SOURCE: status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Posted on Feb 14, 2010
salt56
  • 373 Answers
SOURCE: Out of the box green
Only get Welcome screen and green blinking lite. Then shuts off. Buttons locked out also. Need to get software update V41C-11.3 Mitsubishi-tv.com. Go to support then software update. It will ask for model, ser. First and Last name and E-mail. download. http://www.avsforum.com/avs-vb/showthread.php?p=19844230
Has a link about 1/3 way down that will go right to the download. Very helpful.
Posted on May 28, 2011
X322BV-HD*WXC100
Warranty is usually 1 year parts and labor. Contact mfc for warranty service. likely main board.
May 28, 2013 | Televison & Video
My tv will not turn on the red light turns blue then back to red
Check for bad capacitors in power supply for your inverter circuit.
Nov 19, 2011 | Televison & Video
No sound, no picture
If by catscan sound you mean a high pitched whine? That usually indicates that the power section has had a part fail. The capacitors on the main board will cause this. You can take it to the shop but get an estimate first as the repair cost can be close to replacement as the prices keep falling. The repair parts are pretty cheap but the labour isn't.
Jul 24, 2009 | Sceptre X32GV-Komodo 32 in. LCD Television
Element tv.. model # ELCHS261 stopped working
My Element ELCHS261 will not turn on at all. The only thing it does is the red light will turn to blue but no sound and no picture. My troubleshooting items have been changed the batteries in the remote then I unpluged the power for for 30 minutes and still nothing.
Jul 10, 2009 | Element Electronics FLX2211B 22 in. LCD TV
TV Not turning on , but blue power light is on
look in the back, see if the lamp is actually lit. If it is probably not a tv problem. If you can pull up the menu then you probably are on the wrong input. Are the fans running when you turn it on? IF fans are running might be lamp, if nothing is seen through the back.
Apr 29, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
PLTV-26
WHEN I TURN ON MY TV THE LED IS RED THEN GREEN AND GOES BACK TO RED AND NO IMAGE. WHAT COULD IT BE, i ALSO DID A HARD RESET BY REMOVING THE WIRES AS THE TECH HAD SAID AND NOTHING.
Dec 11, 2007 | Protron PLTV-32 Television
Blue power light is on, but no picture is displayed
The light does indicat that there is power to the sety but that doesnt mean that the power supplys working . Theres nothing uyou can do unless your a trained tech. The set should still have a parts warranty. Good Luck
Jul 28, 2006 | GE 27GT616 27" TV
Mitsubishi WS-55809 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
