Question about LG GD510 Cell Phone
My phone is not showing the icon past android
Hd switched off my phone and when again switched on its not showing anything past android
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 53 Answers
Try to reflash the ROM with a recovery boot image, google the process for your cell or contact nearest service center.
Posted on May 16, 2014
My phone shut down is a coolpad 5560S.SPO25 nothing come on but the android robot and it keep's saying android system recovery
Make sure it's more than half way charged.
With the phone OFF..
-hold down both volume buttons at same time.
-while holding both volume buttons press power button for 2 seconds.
-It should display recovery more, if not try again.
-When android icon shows, press home button.
-A screen with restore choices comes up.
-Use volume buttons to choose the best restore for you.
(choose wipe data / factory reset in your case) simply because there is an problem with the bootup system file. This should work. Wish you the best.
Aug 16, 2015 | Android Cell Phones
How do you activate the front camera?
Click the camera icon on your cell phone. And then click switch camera icon.
Jun 09, 2014 | Blu DASH 4.0 D270s UNLOCKED GSM Android...
Motorola Atrix 2 doesn't go past the at&t start up screen
Has your Motorola Atrix HD stopped responding? Is your Atrix HD frozen on a lit up black screen as though the screen is getting power but will not turn on? Will the phone not power on? Is it completely dead? Here is a tip that can fix it in less than 25 seconds.
Sometimes the Motorola ATRIX HD (MB886) OS 4.0-4.1 just gets a little confused and doesn't want to work. On most other Android phones you would just pull out the battery count to 10 put it back in and then be good to go.
But guess what... you can't pull the battery out of the Motorola Atrix HD, thankfully Motorola (my 2nd favorite Android manufacture) built in a solution.
Before we start getting into troubleshooting make sure that you have tried to hold the power button down for 15 seconds to see if there is any response.
Also try and charge the phone with the original charger that came with the phone. If the battery of the device has drained to zero percent then it can take a few minutes to a couple of hours for your battery to start charging correctly again.
If you have tried holding the power key and have already tried charging it with its original charger and there is still no response, then proceed to the next part of these instructions.
What you need to do is a Simulated Battery Pull. Here is how you do it
  • Step 1: Make sure that the power is completely off. I know it doesn't want to turn on and that's part of the problem but make sure that the phone is not plugged into a charger either. Note: if the keys on the bottom of the device are lit then the phone is on, if there aren't any lights currently showing or lit up then don't worry about whether your phone is on or off, simply proceed to step 2.
  • Step 2: Hold the Volume Down button and then the power button and continue to hold these 2 keys for 20 sec (count out loud it could take 15-30 sec).
  • Step 3: The phone should power cycle, powering back on to full.
  • Step 4: Enjoy, your phone should now be working 100% and you should be good to go. If it happens again just do the same thing.
  • Step 5: if it didn't go through then try it again. Seriously try it a couple times this should fix the issue, if not proceed to the next step.
If the simulated battery pull doesn't fix the issue and the Atrix HD still doesn't power on or it's still showing a black screen then the problem might be more serious.
Try this instead
  • Step 1: Make sure the power is completely off and that the phone is NOT plugged into a charger, just like we did before.
  • Step 2: This time instead of the Volume Down key use the Volume Up key. Hold the Volume Up and the Power key simultaneously for 20 seconds and see if anything pops up on the screen.
  • Step 3: Release the Volume Up and Power keys if/when you get any response.
  • Step 4: If you get some options then use the volume down key to cycle through your choices. Look for an option to restart or reboot. (don't do the wipe data/factory reset option... yet... that's kind of a last resort)
  • Step 4: Once the option is selected use the power key to make the selection.
  • Step 5: The phone should reboot and you should be good to go.
If it doesn't, which it should, proceed with the second method again but select the wipe data/factory reset option mentioned in Step 4 above. The Reset is going to wipe everything from the phone and if it is a software bug that's causing these issues then it will fix it. It will wipe everything from the phone though (good and bad) so use this as a LAST resort.
If the keys on the bottom of the phone are lighting up and or you seem to be getting messages or calls but you just can't see anything on your screen then chances are high that your display malfunctioned and will need to be replaced.
Apr 24, 2014 | Motorola Mobility At&t Atrix 2 Mb865 - 8gb...
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
When I power up phone it will only display green android icon and android word flashes .
Have you tried loading the deafult factory wiped image?
It might be that the boot loader doesn't work or is bugged, in this case you will have to take the phone to someone that has a Developr kit for Android, USB cable and a default - working image from the vendor of your mobile. I guess you should take it to service, if it's still in warranty, otherwise it shouldn't cost you too much.
Jan 01, 2014 | Universal STAR N8000 Android 4.0 WCDMA...
I need an owner's manual for a A7100 GSM Unlocked 4" Android Smartphone
Go to setting (Cog icon)
Go to Lannguage and Keyboard ('A' icon)
Go to 'Sewlect Language' (Top of sacreen choice)
Choose your language.
Jan 23, 2013 | HTC Desire A9191 HD Gsm Android Unlocked...
Keeps showing lg screen and flashing
Android is corrupted. You need to factory reset it. Hold volume down and home buttons while turning it on. You can let go of those buttons once the screen changes to the Android loading icon.
This will erase everything from your phone - so good idea to keep things backed up for incase it happens again.
Near as I can figure, this happens when:
- phone battery is allowed to die
- pull battery from phone when it is still shutting down (hard to tell when it's finish)
Dec 28, 2012 | LG Optimus Net P690 Touchscreen Android
How to c hangemycobykirosfromchinesetoenglish
go to settings...
then select phone settings...
then select language....
choose english.
if its already in chinese and ur not able to read anything.. then click on the icon grid that reads as settings in the url image below....
copy and paste the url given below and click on the icon that says settings.... then follow the instructions.
http://www.geeky-gadgets.com/wp-content/uploads/2010/12/Coby-Kyros-MID7015-Android-Tablet.jpg
hope u got ur answer.
Feb 21, 2011 | Coby Kyros 716829701508 Tablet PC
G1 boot up error
when i turn my phone on it wont go to the android area. instead it shows a picture of my phone with a exclamation inside a triangle... ive tried to reset it and it wont go past this.
Jun 16, 2009 | HTC G1 Smartphone
LG GD510 Cell Phone Logo
46 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
