Question about Dell Dimension 2400 PC Desktop
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
Is wd 1200jb-00gvc0 hard drive compatible with dell dimension 2400 desk top?
    Sergeant:
  • Dell Expert
  • 504 Answers
That is a western Digital Hard drive compatible with most computers even Dell Computers
Posted on Sep 11, 2014
sandrew
  • 2961 Answers
SOURCE: Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Posted on Jan 26, 2007
Kevin Amandy
  • 37 Answers
SOURCE: dell dimension 2400
Click this link:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
It contains the list of the beep codes for dell dimension 2400.
There is also a guide on how and what to troubleshoot. Motherboards use beep codes to indicate what error might caused the system to malfunction.
Posted on Dec 18, 2007
  • 3940 Answers
SOURCE: dual monitors on my dell dimension 2400
To run dual monitors will require you to install a PCI video card.
Like this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2484223&CatId=319
Posted on May 20, 2008
leecom72
  • 4806 Answers
SOURCE: How to remove the hard drive from my dell
Hi there.
Firstly remove the power cord from the back of the desktop, then turn the unit round so the back of it is facing you, on the right hand side there may be a couple of screws and plastic catches, remove the screws and lift the plastic clips so the side panel opens up, once that is done you will be able to see the motherboard, the hard drive looks like this >>>>>e340c2b.jpegnow depending on the type of dell you have there maybe screws or green plastic strips that holds the HDD in place, if you cannot get it that way then the front panel has to be removed.
If this is the case post back and I'll tell you how remove it.
Good luck and thanks for using Fixya!!!
Posted on Feb 23, 2009
  • 18 Answers
SOURCE: Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Posted on Mar 18, 2009
Cd dvd burner on dimension 3000 desk top with xp light wont come on or tray wont open
sounds like the drive may have failed
Reseat the power cable to the drive
if no change, replace the drive
Jan 22, 2011 | Dell Dimension 2400 PC Desktop
I NEED HELP IN REPAIRING THE FRONT HEADPHONE JACK ON THE TOWER, AND WOULD LIKE TO HAVE ACCESS TO THE SHOP REPAIR MANUAL. DELL DIMENSION 2400 DESK TOP PC, THANK YOU AND KINDLY APPRECIATED !!!
You can just remove and replace the front I/o panel rather than repairing it . The part is not more than 10$. You can get the part from the following site
http://www.txcesssurplus.com/servlet/the-5850/Dell-Dimension-2400-4600/Detail
or
http://www.impactcomputers.com/d0971.html
How to remove the front panel
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/fpanel.htm
Thanks for using fixya
Proton
Aug 20, 2010 | Dell Dimension 2400 PC Desktop
Can't format wd1200jb to 120g only 109g (approx.) tried w/wd DLGDIAG, Win 2000 Pro, XPPro.
You need to format it before operating system loads . You have to insert bootable XP cd as you power up your PC.
Dec 02, 2009 | Western Digital Caviar WD1200JB Special...
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
HOW IS THE WIRING SET UP IN MY DELL DEMENSION 2400 DESK TOP// I AM TRYING TO PUT BACK TOGETHER THE IINSIDE OF THE TOWER NOT SURE HOW IT IS SUPPOSE TO LOOK
Most of the connections only fit in one place ...
Here is the Service Manaul for the 2400 Dimension.
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/index.htm
Jun 13, 2009 | Dell Dimension 2400 PC Desktop
DESK TOP TO WIRELESS CONNECTION
First make sure you have the correct drivers installed, go to the Belkin website to get the latest drivers for your device.
Next make sure that your router is set to broadcast, and that is in Wireless G mode. You can find that information at the router manufacturers website.
Apr 15, 2009 | Dell Dimension 2400 PC Desktop
DEll 2400 - cd-dvd drive stopped working
try to clean the lens using lens cleaner...
Dec 02, 2008 | Dell Dimension 2400 PC Desktop
Adding a video card to dell dimension 4700 desk top
hello
you need a pci express X16 graphics card
here is your computer specifications
here is a good card.
and here you have more.
most important is that the card is pci express x16 compatible
good luck and happy gaming.
Nov 26, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 5000 - Installing extra Hitachi 500GB SATA Hard Drive
you need to turn it on in the Bios so the computer sees the drive, then format it.
Jan 20, 2008 | Hitachi ( 0A30229-20pk) 400 GB Hard Drive
Dell Dimension 2400 PC Desktop Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
