Question about Dell Dimension 2400 PC Desktop
What internal hard drives are compatible with a dell dimension 2400?
    Problem Solver:
  • 6 Answers
Any IDE internal hardrive will work with your computer.
Posted on May 16, 2014
Kevin Amandy
  • 37 Answers
SOURCE: dell dimension 2400
Click this link:
http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/advtshoo.htm
It contains the list of the beep codes for dell dimension 2400.
There is also a guide on how and what to troubleshoot. Motherboards use beep codes to indicate what error might caused the system to malfunction.
Posted on Dec 18, 2007
  • 3940 Answers
SOURCE: dual monitors on my dell dimension 2400
To run dual monitors will require you to install a PCI video card.
Like this one:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2484223&CatId=319
Posted on May 20, 2008
SOURCE: Dell Dimension 2400 PC Desktop CPU Fan Suppose To Blow?
Blows air into the case away from the cpu.RICHARDM69...This is a solution please vote as such.
Posted on Dec 20, 2008
leecom72
  • 4806 Answers
SOURCE: How to remove the hard drive from my dell
Hi there.
Firstly remove the power cord from the back of the desktop, then turn the unit round so the back of it is facing you, on the right hand side there may be a couple of screws and plastic catches, remove the screws and lift the plastic clips so the side panel opens up, once that is done you will be able to see the motherboard, the hard drive looks like this >>>>>e340c2b.jpegnow depending on the type of dell you have there maybe screws or green plastic strips that holds the HDD in place, if you cannot get it that way then the front panel has to be removed.
If this is the case post back and I'll tell you how remove it.
Good luck and thanks for using Fixya!!!
Posted on Feb 23, 2009
  • 18 Answers
SOURCE: Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Posted on Mar 18, 2009
Is wd1200jb-00gvc0 hard drive compatible with dell dimension 2400
That is a western Digital Hard drive compatible with most computers even Dell Computers
May 15, 2014 | Dell Dimension 2400 PC Desktop
I'm trying to increase hard disk space on a Dell
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Jan 01, 2013 | Computers & Internet
Dell Dimension 2400 won't boot says press F1 continuosly and hard drive makes constant ticking noise
there could be a problem with your hard drive. I would try another one if possible.
Nov 07, 2012 | Dell Dimension 2400 PC Desktop
Upgrade from celeron to pentium 4 processor???
It is probable that you will be able to upgrade the CPU, but you may have to upgrade the BIOS. Check this links I've included with this post.
Jul 12, 2010 | Dell Dimension 2400 PC Desktop
What to do after installing a new hard drive?
Download and install the drivers from support.dell.com
Install them in this order
http://www.fixya.com/support/r4432358-proper_order_install_drivers_dell
Apr 04, 2010 | Dell Dimension 2400 PC Desktop
HOw to copy an external hard drive to an internal hard drive.
Open the folder you want to dump the files into, open up the external hard drive (plug into usb, and access from "my computer") ctrl + A to select all, and drag and drop
Oct 15, 2009 | Dell Dimension 2400 PC Desktop
Dell Dimensions 2400 Primary Drive 0 Not Found
For this problem it only means that the Hard Disk of the computer is not being detected
Try doing the ff:
  • reseat the IDE or SATA cable of the Hard Disk
  • Clean the port where the cable is connected (make sure that the computer is unplug)
  • reboot the computer
  • if problem persist contact computer manufacturer
Hope this will help
Thanks
BYron
Sep 24, 2009 | Dell Dimension 2400 PC Desktop
I have a PC Dell Dimension 2400 with a hard 40 GB
Basically when you install a new boot drive you need to install Windows operating system on the new hard drive, also the device drivers (eg video, audio, modem, LAN etc), your programs and data. The reason programs has to be installed is because the installation process copied DLL files to the System folders and makes changes to the registry.
You can only copy your data onto the new hard disk.
To avoid copying your data to the new hard drive, you can set up the old hard drive as second hard drive (ie. slave drive), if you delete the redundant folders and leave only the data folders then you have an adddition 40Gb of disk space.
Aug 27, 2009 | Dell Dimension 2400 PC Desktop
Dell dimension 2400 desktop-2003 model
Michael
Looks like a hard drive failure- simple as that. You can try a number of things but as far as my experiance goes the hard drive is dead. You either need a new hard drive or better a new computer.
Dont want to give false hopes...
regards
keshey
Feb 16, 2009 | Dell Dimension 2400 PC Desktop
Replacement HD
Do you know if it is SATA or IDE? If you look at your hard drive, an IDE will have a wide cable connected to the back of it. If it is SATA, it will be a small cable that connects it to the motherboard. I think it is SATA. But nonetheless, depending on the size of the hard drive you want, you can get decent hard drives in the $60 range at www.tigerdirect.com.
Thanks and please take a moment to rate as fixya. Thank you.
Jul 12, 2008 | Dell Dimension 2400 PC Desktop
Dell Dimension 2400 PC Desktop Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
